Bumper and Grill - Diesel Forum - TheDieselStop.com
Old 01-28-2013, 09:39 AM   #1 (permalink)
Bumper and Grill
can you directly replace the bumper and grill on a 1999 F350 with the same from a 2006 without any mods to the truck?
Bullshot is offline   Reply With Quote
Old 01-28-2013, 12:06 PM   #2 (permalink)
GTman's Avatar
Negative ghostrider.
2002 7.3L F-250 Crew Cab with 230k miles, 6" mitre cut Grand Rock turbo back stacks, 3-pillar ISSPRO EV2 Gauges (pyro, tranny, boost), AIH delete, 05-07 headlights, much more coming soon
GTman is offline   Reply With Quote
Old 01-28-2013, 02:45 PM   #3 (permalink)
69mach1377's Avatar
How about an 03/04 grill in a 2000?
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, otherwise mostly stock.
24' 5th wheel camping trailer, no RV parks...just the woods.
69mach1377 is offline   Reply With Quote
Old 01-28-2013, 06:16 PM   #4 (permalink)
As for a grille change you can do this. This is what I did to my 2002 Ford F350.
Chrome Ford Super Duty/Excursion Grille Conversion
2002 Ford F-350 7.3L Diesel
2.5" Rough Country Leveling Kit
6" Duel Silverline Exhaust stacks
BullyDog Programmer
Coltonwmcc is offline   Reply With Quote
Old 01-28-2013, 07:22 PM   #5 (permalink)
Mongus's Avatar
Yes and no.
I installed this on my 2000
The parts are factory Ford parts.
They are 05 - 07 superduty parts.
Head lights. ( you need a bulb and matching pig tail )
Front bumper and valance.
Grille.
You also need the grille header panel ( $80 )
Mongus rigs;
1992 F-Superduty Dump truck 7.3 - Luk SMF 5spd 5:13 rears-Ricksons 19.5 wheels & tires-Banks get kits.
This is my work hoarse !
2000 F550 - Crew cab -Custom Hood
Harley Flamed Fenders & Doors.
4x4-7.3 - South Bend 6spd 4:88 rears. Loaded ! Volant intake
Hog Performance 4" SS exhaust
Banks wheel, turbine, exhaust brake-Ceramic coated
AFE Blade Runner Spyder
Strickley Diesel Return Fuel & Banjo Bolts
IH up pipes - ceramic coated
Powder coated everything.
Brake Performance-slotted & dimpled rotors with performance pads
DP Tuner 80 Tow
Coolant filter system
Evens Coolant
203 thermostat
Bullet Liner coated Dana 60 front end
2008 F-350 Harley Davidson Crew cab - long bed - 6.4 - Banks-Six gun-Air intake-IQ-Dual Exhaust
2004 Pace American 28' x 9' x 8' enclosed work trailer. 18k GVW. Tri axle - loaded
Custom Built Roll -Off dump trailer. 17yard box. Double dual axles. 20k GVW.
Fully decked 2003 Anni Fat Boy.
Rare "Reaper Tins"
Mongus is offline   Reply With Quote
Old 01-29-2013, 06:31 PM   #6 (permalink)
You guys don't actually read the questions, do you?
Old 01-29-2013, 06:54 PM   #7 (permalink)
ptanner3's Avatar
You got answers from "no" to how to do it and what you would need. Sounds above and beyond to me. Just to annoy you i have a 2008 bumper available that also won't work without modding. :-)
'02 f-250 cc srw 4x4, auto, 4" exhaust, pillar pod w/ post and pre turbo egt, trans temp and boost, black brushguard/bumper, chrome step tubes. bully dog trans kit, ts performance 6-pos chip, stock, high idle, 50, 75, 100, 140, volant air intake
'08 f-350 cc drw 4x4, auto, mini max, 5" downpipe back exhaust. black ranchhand bullbar bumper, S&B intake.
both trucks bought in texas.
ptanner3 is offline   Reply With Quote
Old 01-30-2013, 07:07 AM   #8 (permalink)
Not annoyed at all, I guess I'm just not understanding the answers.
Like: a detailed description of several different trucks ...... took me a while to understand that those were just a bunch of "This is what I have" signature lines.
Coltonwmcc, I believe that this the route I will take.
I appreciate the information and the advice, thanks to all.
Bull
Old 01-30-2013, 09:59 AM   #9 (permalink)
My Photos: (19)
Bullshot, your direct answer is yes and no. The bumper will directly bolt on, the grill and headlights will not. There are plenty of threads dealing with this conversion, if you wish to ask what needs to be done to put those headlights and grill on your truck then it'll be a different subject.
69mach1377, your '2000 grill is the same as a '03/'04 so I don't know what you are asking. The OP asked about a conversion to a different design.
DP-Tuner 80T, Stage I single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is online now   Reply With Quote
