Bypass Oil Filter - Page 3 - Diesel Forum - TheDieselStop.com
post #31 of 69 (permalink) Old 02-10-2006, 03:46 PM
Re: Bypass Oil Filter
Has anyone had success with gulf coast filters.
Got it as a present and have yet to install it.
Michael
2002 F-350 Lariat, 7.3 PSD/CC/SRW/LB, , BTS Tranny (BEST MOD EVER!), 6.0 Cooler, Van Turbo, Autometer Lunar Pyro/boost/tranny, AFE Stage II, 4" MBRP Turbo back, Gulf Coast Oil Filter Bypass O-1, Cale's 6 program fun twisty knob, Air Dog, Tank Harpooned, AIH Delete, Blue IH CPS, Biltsteins, 3" body lift, 285/75/16 Michelin M/S, Mag Hytec dif cover + Mobile One 75-140w Synth Fluid, 203 thermostat, billet T-stat housing, coolant filter (Dieselsite), Changed from Rotella to Delo (lab results to follow soon), High Pressure Crossover (HPX) flexible line, Alpine, JL Audio, and crazy amounts of Dynomat Xtreme, surgical style tubing in door gaskets, Rhinoliner, just getting started 190k miles....
In GOD we trust...everyone else, VERIFY!
Likethemtrucks is offline
post #32 of 69 (permalink) Old 02-10-2006, 08:07 PM
I know I'll take some crap for this but Amsoil has a good single bypass unit.
Doesn't the Amsoil bypass return have to be drilled in the side of the oil pan? I have wanted a bypass system but do not want to drill the pan. I like what I am hearing about the fs2500 system but since I have a 2wd I don't know if it would be such a good idea to have the hose hanging from the drain hole. [img]/ubbthreads/images/graemlins/shrug.gif[/img] I would like to switch to synthetic but I have 82K on the truck and don't know if it's too late.
2004 F-350 Crew Cab Dually LB Lariat, 6.0L PSD, Dana 4.10 LS, Burgendy red with gold lower tu-tone, Magnum S3 CB, Wilson 5K antenna, Vortex liner, Weatherguard toolbox, MBRP 4" Turbo back exhaust, Air raid box, Quadzilla tuner, High ram intake, Towing a 30' Thor Citation. 110k miles
hangfire77 is offline
post #33 of 69 (permalink) Old 02-10-2006, 09:45 PM
Well, the FS2500 return line is screwed in to the OIL PAN.
man i like the fact that theyre working w/ all that oil in the
pan...BUT w/ the return line in the pan its gonna be a pain in
the butt to collect a periodic oil sample...i really like mo fomoto valve !
bushpilot is offline
post #34 of 69 (permalink) Old 02-10-2006, 09:55 PM
Steve Campbell's Avatar
The FS2500 has a port where you plug a hose in to take a sample, it has a nipple fitting that when you push it up the oil flows and when you release it, the flow stops. It is a really clean way to take a sample.
2012 F250 Lariat 6.7 Golden Bronze 4X4, MBRP Filter Back Duals, Alpine INE-Z928HD, Focal Amp and Speakers and a ton of Dyno Mat, RetraxPro, Clifford Alarm Recon smoked marker/clearance lights, HID Headlights, Rigid D2 Driving Lights (in fog location), Bilstein 5160 shocks,Hellwig Big Wig Sway Bar, Pro Comp 2 Inch Nitro Leveling Kit, Fuel 22" Maverick Wheels , Nitto 325/50R22 Terra Grappler, Westin Bull Bar
Protected by H&K
USP and friends
2006 Hummer H2
(traded for
diesel hope never to go back to the dark side (gas)
2005 F250SD SB 4X4 6.0 Harley Edition (traded)
2003 7.3 F350 DRW 4X4 (traded)
2001 7.3 F250 4X4 (traded)
Steve Campbell is offline
post #35 of 69 (permalink) Old 02-10-2006, 10:56 PM Thread Starter
As far as drilling the pan or not all depends on the make. THe 7.3L has threaded ports already in the engine block that are plugged. When you get ready to install, they supply the wrench to pull those plugs and put in the supplied fittings. No Drilling. The 6.0L however is a different story. When I spoke with the people from FS, I didn't ask specifically about the 6.0L since I have a 7.3L but they did say it was installed in the pan. Hope this helps.
2000 Ford 7.3L CC 4X4 4" lift, XM radio, FS2500 Oil Bypass, AFE Stage I PG7 intake, 4" MBRP single exhaust, WW, Zoodad, 203*, 40 gallon combo tank, triple gauges and 3 pos DT Tuner chip -- ALL STOLEN from PARKING LOT
DLBartley is offline
post #36 of 69 (permalink) Old 02-11-2006, 02:51 AM
The fitting included in the 6L kit replaces the pan plug. Screws right into the pan boss. I like my fumoto also, so if I go with the FS2500 filter, I am going to use a oil cap return.
If you look at the 3rd page of the install, there is an arrow depicting the sample port.
2013 F350 CC Lariat 4x4 6.7L
2003 F250 SC Lariat FX4 6L sold
AK6LPSD is offline
post #37 of 69 (permalink) Old 02-11-2006, 10:36 AM
FTG-05's Avatar
My Photos: (25)
I will be using the Amsoil BMK-11 single bypass filter mount and the Oilguard oil filter and oil filler caps to hook up the bypass oil supply and return lines, respectively on 6.0. No other interface or connection to the engine. $175 from Oilguard.
Al
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
post #38 of 69 (permalink) Old 02-11-2006, 03:05 PM
Location: Greatest nation on Earth! You don't like it...get out!
So lets see... pro's and con's...
Oil guard ~$300. More if I want shut off valves. I get a specialized kit for the 6.0L with anodized oil filter cap tapped and return line in the anodized oil filler cap. Filters to less than 3 micron. Filters ~11 bucks.
and
FS2500 ~$450 and may still have to buy other fittings if I don't want the return line in the pan and no swivel off the oil filter cap. Still more if I want shut off valves. Filters cost ~22 bucks and they filter to 1-2 micron range.
Which way to go?
'05 Shadow Grey F-250 XLT PSD CC 4x4 LB, Build Date 8/8/04, Lariat wheels w/BFG AT KO 315/70R17's, ID's extreme tunes, Livewire, Coolant filter, Muffler Delete, 5" Chrome tip (10 plus hp there alone), Fomoto Valve, Rotella T Syn 5W40, ZooDad Mod, F350 blocks in back, Fabtech leveling kit in front, Bilstein Shocks, 800+ Watt AMP, 2-12" Subs in custom enclosure behind rear seat, Tonneau cover, Line X, UNGO 2-way alarm with remote start & turbo saver, Garmin GPS, Escort radar detector, AIC and aux backup lights on added upfitter switches, electric trailer brake module...more to come soon.
SLAPS Member#139
'92 Mustang GT, Black on Black and FAR, FAR from stock
Shadow_Grey is offline
post #39 of 69 (permalink) Old 02-11-2006, 03:09 PM
remedm's Avatar
I have the OilGuard and love it easy to install and mount.
No drilling required of any kind, Not even when you mount it to the
frame. IMOP OilGuard did the research for the 7.3, Doesnt sound
like the other guyes did very much research. That is why I choose
OilGuard, the results as far as filtering are pretty much the same. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2002 CC F-350 SB SRW 4X4 TOREADOR RED
DP-TUNER NO-START, MOD STOCK, HIGH IDLE, DRIVE THRU, 40 TOW, DECEL, 60 TOW, 60 ECON, 80 ECON, AND RACE
BTS TRANNY (NUFF SAID)
; 6.0 COOLER
DIESELSITE BOOST RELIEF VALVE, 203^ THERMOSTAT AND HOUSING, MAX A/C VALVE AND COOLANT FILTER
ATS TURBO HOUSING, FORD A.I.S., OILGUARD BY-PASS, 4" MAGNAFLOW STRAIGHT PIPE, SIDE EXIT,
NCHORNET'S CCV MOD, POR-15 OIL PAN
ISSPRO A-PILLAR PYRO/BOOST/TRANS, ISSPRO ENGINE, OIL TEMP AND VOLTS OVER MIRROR
MARINCO MOD, LED ID BAR, HEATED SIGNAL MIRRORS, LED BRAKE AND TURN SIGNAL BULBS FRONT AND REAR
RHINO BED LINER, SIRIUS RADIO
AMERICAN EAGLE WHEELS WITH 305-70-16 NITTO TERRA GRAPPLERS WITH A 2" DONAHOE LEVELING KIT
TRUCK BUILD DATE 1/8/02
BTS BUILD DATE 1/8/07 AT 41K
remedm is offline
post #40 of 69 (permalink) Old 02-11-2006, 04:13 PM
My Photos: (22)
Another big plus for the Oilguard is that you DON'T have to change the element every 10,000 miles. You can pretty much run the element as long as the oil. Heck some people change the element every other oil change. As long as the unit is hot to the touch, it is still flowing.
Hammer
Check out what I recently bought:
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red">
</font>
Get Your Tuning Here:
and your Fuel kits here:
TheHammer69 is offline
post #41 of 69 (permalink) Old 02-11-2006, 06:07 PM
FTG-05's Avatar
My Photos: (25)
Hammer
That's how I was told to tell if it was still filtering.
FTG-05 is offline
post #42 of 69 (permalink) Old 02-11-2006, 08:37 PM
My Oil Gaurd only cost 200.00 bucks.
2000 F-450,Crew Cab,4x4,Flatbed,4.88 diffs
Sumitomo 245/70R19.5--Centramatic balancers--AIS with Fender Sleeve--Chrome Simulators/Dieselsite--Coolant Filter/Dieselsite--Trans Filter/Dieselsite-- A-C valve/Dieselsite --Oil Gaurd bypass filter--Fumoto valve/Dieselsite--SkyJacker Steering Stabilizer-- 4 Gauge A Piller Pod(pyro,boost,trans,volt)--Muffler delete--AIH delete--Gas Magnum shocks--ITP HX mod--Wolverine Engine Oil Heater--GOLD coolant---CCV mod---ITP Pre pump/tank Kit---WIX prepump Filter/Separator---FIA grill cover---Zoodad Mod---REDHEAD steering box---ROTELLA 5-40 Synthetic---MOBIL 1 syn PS fluid---Magnefine PS filter---STACK single/chrome/5"---
ON THE FLATBED&gt;-- Miller Trailblazer 302-- Suitcase MIG 12vs x-treme-- 2 60" boxes/ 2 36" boxes-- and all the necessities
SKEET298 is offline
post #43 of 69 (permalink) Old 02-14-2006, 01:15 PM
Ok I have to install it but I got the Oilguard as it filters down to about 1 micron and their filters are less money. I went with the bigger unit EPS-60 as it has twice the filter area and only costs $3 more. I figure this will extend the filter change time by at least 50%. I njust need to figure out where to mount the canister as it is about 12" long.
For what it's worth Oilguard also sells fuel filters that are exact replacements with the water screen material and all. In fact they sell all the filters too.
Allen
2005 F350 King Ranch 6.0L,4X4 DRW,5sp auto,4:10 LS, camper pkg, towing pkg, Loaded everything except dual alts and moonroof.
Options/changes...Supersprings for the TC, coolant water filter, Sylvania HV13XV hi-lo's, Sylvania Silverstar 9005 foglites, Brite box+ foglites, Tubular grill inserts, Paregon retractable bed cover, OilGuard EPS 60 bypass filter with Schaffers 9000 5w40 synthetic, Bilstien shocks, PIAA 93360 Super Sporza silicone wiper blades, Husky floor mats, Dash mat cover.
allenf is offline
post #44 of 69 (permalink) Old 02-14-2006, 08:52 PM
OK Skeet,
Where and how long ago??? You knew some one was going to ask. If I could find it for 2 bills I would purchase tonight. That is for a 6.0 truck.
Let me know...pm me if you don't want to post.
Jeff
SLAPS Member#139
post #45 of 69 (permalink) Old 02-14-2006, 10:45 PM Thread Starter
I got the FS2500 today and I plan on installing it tomorrow after I get off work. I will take photos of the system and the before and after photos of set up. I will also try and take a photo of the oils before and after as well.
I will send more later.
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
