Carbon Fiber Driveshaft - Page 4 - Diesel Forum - TheDieselStop.com
post #46 of 65 (permalink) Old 07-20-2007, 01:17 PM
haul_n_horses2's Avatar
My Photos: (17)
Re: Carbon Fiber Driveshaft
What does the stock shaft weigh?
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #47 of 65 (permalink) Old 07-20-2007, 02:18 PM Thread Starter
Next week after it's installed, I'll have the weights, pictures, and dyno results.
2006 F250 KR 20" Tires, Magnaflow 38" Muffler 4" 4" Turbo Back 5" Tip,PowerShot 2000 Fluidampr, AFE stage 2, Banks Technicooler,SCT, Airfury, Pace Edwards Bedlocker, Bilstein shocks, Fuel Cell, ACPT carbon fiber driveshaft
MARK1959 is offline
post #48 of 65 (permalink) Old 07-20-2007, 10:47 PM
FMTRVT's Avatar
My Photos: (16)
God, I used to make these back in '78 when I worked for Graftek (Exxon Enterprises).
Jack
Truck Pictorials on Facebook. Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
post #49 of 65 (permalink) Old 07-20-2007, 11:15 PM Thread Starter
What were they used for? Were they an improvement over what they replaced. How close were the there balanced tolerances?
I found out that ACPT's has there driveshaft balanced to 1/25 of an once.
MARK1959 is offline
post #50 of 65 (permalink) Old 07-27-2007, 11:58 AM
Got some pictures from Mark. I uploaded them to the photo gallery. The shaft weighs in at 32lbs. It uses a carbon fiber tube with steel spicer components on the ends. There is a steel tube inserted into the carbon tube approximately 6 inches which lets them weld the spicer XL components to them.
Here is a pic of the complete shaft:
Here is a pic of the shaft being weighed:
Proof of the 32lbs:
The shaft has a double cardan CV front with a grease jerk to keep it lubed, it is Spicer XL components (the strongest u-joints on the market). The u-joints are a forged cross design unlike the factory cast pieces:
Spicer XL U-joint at the pinion flange:
Greaseable slip yoke (can't grease the factory shaft without taking it apart):
Pinion Flange:
T-Case Flange:
PSDPlayer is offline
post #51 of 65 (permalink) Old 07-29-2007, 02:39 AM
Any dyno numbers or seat of the pants differences to post yet?
1997 4x4 F350 CCLB Powerstroke, 2005 Front and Rear Axle Swap, 6" Lift and 35 inch Tires, Tymar Intake, Edge Chip, MBRP 4" Exhaust
Doctorsmack03 is offline
post #52 of 65 (permalink) Old 07-29-2007, 06:21 PM Thread Starter
Haven't installed yet. There has been some technical difficulties.
Hoping to get resolved within couple weeks. Not ducking your question but I can't get dyno'd until it fits.
MARK1959 is offline
post #53 of 65 (permalink) Old 07-29-2007, 08:20 PM
$1000 and the sucker doesn't even fit!!! [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Danny Om
01 SC PSD Dually (build date 08-00 w/ PMRs), 8" Edge, dual F&R Doetsch aluminum shocks w/ resevoirs, 37" SSR on all 6 tires, 2" (hub & wheel centric) wheel adapters by Fearless Fred Goeske, Fabtech racing track bars.
APC Projectors (HID 10k), clear corners, clear cab lights, clear dually side markers, Amp-Research retractable side-steps, power rear-slider, Snug-Top canopy, billet grill, and chrome truck nutz!
Fully built motor w/ B-codes, GT42R, and Terminator w/ remote IPR HPOS.
Auto Enginuity Pro-Bundle equipped if you need assistance locally.
duallyduty is offline
post #54 of 65 (permalink) Old 07-29-2007, 08:45 PM
What kind of difficulties are you having.
2002 FORD F-250 CREW CAB 4X4 7.3 LITER POWERSTROKE DIESEL
DP TUNER F5 W/ STOCK,HI-IDLE,60 TOW,80 ECONO,100HP,140HP,SMOKE,
DiPricol OPTIX GAUGES BOOST,EGT,FULL SWEEP TRANS TEMP,
AFE STAGE 2 INTAKE,4" MBRP TURBO BACK EXHAUST WITH A 5" TIP,
DETROIT LOCKER,MAG-HYTEC DIFF COVER,LIMO TINT ON ALL WINDOWS,
2 VIAIR 480 COMPRESSORS,8 GALLON AIR TANK,NATHAN P3 TRAIN HORN
THEDIESELMAN is offline
post #55 of 65 (permalink) Old 07-29-2007, 10:03 PM
FMTRVT's Avatar
My Photos: (16)
Graftek was in the sporting goods business, making carbon fiber fishing poles, golf clubs, bikes, etc and started to get into other fields, including automotive.
That was the late 70's and with the gas crunch at that time, the auto industry was looking for ways to save money. We were R&Ding all types of parts - driveshafts, pushrods, swaybars, coil and leaf springs for cars, light trucks and tractor trailers. From all of that work at Graftek is where the use of carbon fiber leafs on Corvettes, CF driveshafts on production F-150s and E-150s, GM pickups, and a host of other items.
The Graftek approach to driveshafts was to use an aluminum tube for the torque and mounting of the yokes, and a covering of CF for stiffness. We were prototyping those for Ford, GM and Dana, including up to class 8 tractors. I think the tractor-trailer leaf spring pack weighted about 35 lbs vs hundreds.
No way would I remember the tolerance that the shafts were balanced to.
Jack
FMTRVT is offline
post #56 of 65 (permalink) Old 07-30-2007, 12:53 PM
CF rims anyone?
I believe there are aftermarket companies advertising cf rims. Not sure if they are real CF but that would be crazy.
redfred18t is offline
post #57 of 65 (permalink) Old 07-30-2007, 06:47 PM Thread Starter
Okay, It came in, tried to install, but the ends of the driveshaft on a 06 is not the same as an 04. Sent, it back last Friday and tomorrow going to take off the driveshaft and get the correct measurements they need to fix the problem. I should have done this in the first place. Tomorrow at least I'll know what the 2-piece driveshaft weighs.
MARK1959 is offline
post #58 of 65 (permalink) Old 07-31-2007, 12:10 PM Thread Starter
Just got done measuring and weighing. Should have back by next week.
The end piece that attaches to the rear end was wrong.
Did weigh it though - 50lbs. I'll be saving 18lbs = 64% less weight that stock
MARK1959 is offline
post #59 of 65 (permalink) Old 08-03-2007, 03:24 PM Thread Starter
Just got tracking number, It will re-arrive this coming Tuesday.
Next week, the mystery will be over. I'll have dyno numbers and
driving impressions.
MARK1959 is offline
post #60 of 65 (permalink) Old 08-07-2007, 04:05 PM Thread Starter
Finally, I've got her one. Now, can I feel the seat of pants difference" YES
I'm going to have it dyno'd later this week. I'm guessing that its going to be about 12-15 rwhp gain. The big difference was the way it shifted between
gears. When I floored it at 10 mph, I use to feel the shifts from 1st to 2nd to 3rd. The feeling of the shifts are gone?? Hope that made sense. But, now I just hear the motor shifting (no more jolts). It almost seems like the
the truck speed shifts from gear to gear. No more hesitations. It's a whole lot different than before. I like it, but I also liked being somewhat thrown back a little in the seat. Now, its more like a rocket, the shifts are quite unnoticeable. I'm know it's quicker. My Powershot 2000 propane system gave me about 24 rwhp - I don't think the carbon fiber driveshaft is going to give me 24 rwhp. - But, maybe 15rwhp. All I can say is that I'm happy that it's finally in and that if I had to go through this again I would.
Will be getting back with you later this week after the dyno
Doug, at go go diesel dot com has been a tremendous help to me.
I wanted to say God bless him, but God bless him.
MARK1959 is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
