cheap diesel chip - Diesel Forum - TheDieselStop.com
Old 01-01-2009, 09:34 AM   #1 (permalink)
cheap diesel chip
Has anyone used the "cheap diesel Chip" (e-bay jackass products) $60 ?
ttles714 is offline
Old 01-01-2009, 10:29 AM   #2 (permalink)
My Photos: (19)
What sort of gains do you get with that chip? I don't know if DPTuner increased their prices reciently or not, but for $75 plus shipping both ways they will burn one of their custom tunes right into your PCM and voila you have a very good (some would argue the best) tune in your truck for very little money! And you know it will work well with your truck. I don't think you can beat that deal.
Heck, that's what I did a few years ago and haven't looked back!
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 01-01-2009, 12:16 PM   #3 (permalink)
JimTJr's Avatar
My Photos: (20)
I would bet that is just a 10k mod or something similar boxed up to plug in. (Have a link to it?)
Either way I would steer clear of cheap anything for our trucks, Stay with proven dealers. ( I like Tony Wildman for tuning, he will be my next chip)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 01-01-2009, 12:50 PM   #4 (permalink)
aklim's Avatar
Pretty much a scam. I wouldn't buy that cheap junk. Cheap stuff is usually not good and good stuff doesn't go cheap as a general rule.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 01-02-2009, 07:24 PM   #5 (permalink)
here is the web site
Im a rookie to this. and i'm going to look into your suggestions...I'm not even sure how these chips work. I am going to look into your suggestion to have a program burned into my PCM . I guess that will tie up my truck for a while. thanks
ttles714 is offline
Old 01-02-2009, 09:06 PM   #6 (permalink)
aklim's Avatar
Originally Posted by ttles714 View Post
cheapdieselchips.com open for Online Ordering!!! Im a rookie to this. and i'm going to look into your suggestions...I'm not even sure how these chips work. I am going to look into your suggestion to have a program burned into my PCM . I guess that will tie up my truck for a while. thanks
For $75, Jody can burn you a tune into your PCM.
aklim is offline
Old 01-04-2009, 02:24 PM   #7 (permalink)
ok ??????
Who is Jody ?? And how do I contact him ?
ttles714 is offline
Old 01-04-2009, 03:14 PM   #8 (permalink)
Send a message via Yahoo to vryork
Jody is the owner of DP tuner and you can check out his products at dp-tuner.com website.
2003 XLT 7.3 Liter 4X4 Auto (4R100) w/manual loking hubs, Super Cab, Long Bead, AFE Stage 1 Air Cleaner, Stock 265-75-16 Tires.
vryork is offline
Old 01-06-2009, 08:28 PM   #9 (permalink)
69mach1377's Avatar
Looks like a digital 10-18k device...
2000 F250 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, otherwise mostly stock.
24' 5th wheel camping trailer, no RV parks...just the woods.
2005 VW Passat 2.0 TDI, 40+ mpg hiway
1969 Mustang Mach1 HotWheel, 377 clevor, R&P steering, 3.50 posi, 2003 Mach1 Wheels (17s)
69mach1377 is offline
