check engine light after fuel filter change and trany fluid change - Diesel Forum - TheDieselStop.com
Old 01-08-2009, 01:36 PM   #1 (permalink)
I have 62,000 miles and just changed my fuel filter and tranny fluid/filter. About 100 miles later, my check engine light comes on (not flashing, just stays on). The manual says check to make sure the fuel cap is on tight. I noticed mine wasn't loose, but when i turned it, it turned about a 1/8 of turn and then started to click click click.
Any other ideas? I tried to read the DTC's with my SCT X3, but came up with none.
jonlorio is offline
Old 01-08-2009, 07:54 PM   #2 (permalink)
Supporting Member
my03psd's Avatar
Give us some info on your truck...Year,Gas/Diesel..It'll help you get some answers.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 01-09-2009, 06:15 AM   #3 (permalink)
06 diesel. I returned the truck to the stock tune, and the check engine light went away. It is programming now back to the street tune. I guess I'll see on the way to work if the light re-appears.
jonlorio is offline
