cold air intake - Diesel Forum - TheDieselStop.com
Old 03-29-2011, 09:23 PM   #1 (permalink)
timmygarret's Avatar
Feedback Score: -1 reviews
cold air intake
what is the best cold air intake for a 2000 f250 superduty 7.3L powerstoke?? i would like any opinons on brands. how much hp and mph would i gain?
timmygarret is offline   Reply With Quote
Old 03-30-2011, 09:46 AM   #2 (permalink)
Feedback Score: 3 reviews
They add nothing except usually dirtier air. Best flowing and filtering system is the Tymar. next is the AIS ford system. You can also do a DYI with the correct parts. We carry the Tymar, PM if we can help.
The problem with heat shields and routing air through intake boxes is that whenever you direct air flow, you increase restriction. Low restriction is the goal, so using a filter that has the ability to flow large masses of air and then enclosing it in a box yields very poor results. Heat shields do literally nothing. Air flow under the hood is dynamic and not static. It is moving all the time. Hot air will move right around a heat shield at the same temperature and be ingested and the only thing you have caused is turbulence.
Cary
caryt is online now   Reply With Quote
Old 03-30-2011, 11:53 AM   #3 (permalink)
You are not going to gain hp or mph by changing the intake alone, because the stock intake is adequate for the stock engine. However, if you make other mods to increase the hp, then you will need either the Tymar, Ford AIS, or Banks intake to supply the extra air that will be needed.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 149,000 miles, repairs so far: starter, batteries, cps, brakes, tires.
DonWarkentin is online now   Reply With Quote
Old 03-30-2011, 09:48 PM   #4 (permalink)
i have a bully dog 6 position chip and 4in exhaust turbo all the way back. what air system would run best with this then?
Old 04-26-2011, 08:11 AM   #5 (permalink)
for me K&N COLD AIR INTAKE 99-03 FORD POWERSTROKE DIESEL 7.3L is the best!!!
ditzola is offline   Reply With Quote
Old 04-27-2011, 10:25 AM   #6 (permalink)
Good luck with that..
To the OP..answered your question..Tymar period.
Cary
Old 04-27-2011, 12:12 PM   #7 (permalink)
rammertide07's Avatar
Send a message via MSN to rammertide07
K&N is the WORST thing you can put on a diesel. I've seen an intake tube on a 7.3 that hadn't done the CCV mod (so it was oily inside) and it looked like a clogged artery.
Airflow inside an intake box is constant, so really doesn't have time to heat up from the engine bay. I believe the CFM demand for a stock 7.3 SD is 466 CFM (or maybe ^3 inches). Then it goes up from there with tuning. If you have an open intake, then you are sucking in really hot air from the engine bay. The intake box is sealed against the hood. I have seen some people do a diy 6637 intake with a fabricated box around it.
And adding the zoodad mod will make it more of a force fed intake.
AFE, AIS, Air Raid, Volant, S&B....any of those IMO.
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes (Stock, 40 Tow WITH Whsiper tune, 80 Daily Driver, 100 Race, 140 Extreme, 140 smoke show)//Recon smoked cab lights/MM Hubs/Hood/HPx/FRx/GPR switch-Indicator
First vehicle (still driving): 96 F250 XLT 2x4- All factory (injectors & turbo) except straight exhaust. 570k miles
rammertide07 is online now   Reply With Quote
Old 04-27-2011, 03:34 PM   #8 (permalink)
mustangii's Avatar
another vote for tymar
1996 f250 crewcab auto trans 4.10 gears 4x4 7.3 ts 6 pos -idm mod -a real tymar intake -3in dp -4inch mbrp exhaust -3 guages -a big trans cooler-coolingmist water methanol injection -baby swamps and custom tunes by swamps. will it ever be enough?
towing a 2003 keystone sprinter 5th wheel 33.7 ft
mustangii is offline   Reply With Quote
Old 04-28-2011, 01:33 AM   #9 (permalink)
DIY/Tymar with the waterproof Donaldson or the AIS for me. I have both and they are great, the AIS is nice and quiet but still flows well enough for my stock application and filters excellent, as does the DIY open element. The open element intake systems will generate quite a bit of turbo noise, but the flow and filtration tends to be excellent as well. I did not notice any performance differences between my DIY and the AIS I am currently running.
JasonL is offline   Reply With Quote
Old 04-28-2011, 07:50 AM   #10 (permalink)
The Ford AIS. It is quieter, flows better, and filters better than a Tymar. It is also a cold air intake like you asked about. A Tymar is not.
444-4D is offline   Reply With Quote
