Dahl 100 Fuel Filter/Water Separator Installation?? - Diesel Forum - TheDieselStop.com
post #1 of 32 (permalink) Old 07-05-2005, 05:18 PM Thread Starter
I was not expecting the filter to be sooooo big. Installation seems to be straightforward except.....where do I mount it so that it doesn't hang down so low? The truck is a 2001 F250 shortbed. You guys rock; the short amount of time I've been on the forum I've gotten several questions answered.
Hopefully I'll eventually learn enough to provide information rather than only ask for it...
OffroadOUFan is offline
post #2 of 32 (permalink) Old 07-05-2005, 07:06 PM
My Photos: (22)
Re: Dahl 100 Fuel Filter/Water Separator Installation??
I hung mine on the rear driver's seat bolts. They place the Dahl right behind the transfer case on a 4x4. I had only one bolt protruding through the two anchors. So I bought a nut for the one bolt and I tapped the other anchor and inserted a bolt from the bottom. You will have to elongate the bolt holes a little on the bracket to make it fit.
Hammer
Check out what I recently bought:
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red">
</font>
Get Your Tuning Here:
and your Fuel kits here:
TheHammer69 is offline
post #3 of 32 (permalink) Old 07-05-2005, 08:22 PM
haul_n_horses2's Avatar
My Photos: (17)
What Hammer said or make a bracket like this. Actually, I eliminated the bracket and mounted directly to the seat bolts as described by Hammer. There is little clearance issue even when hanging down from the bracket.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #4 of 32 (permalink) Old 07-05-2005, 09:50 PM Thread Starter
Hammer...thanks for the info. Hauln'...thanks for the picture. I got under my truck (non 4x4) and the seat bolts are Perfect [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]. I noticed that I could either drill the holes on the bracket to fit the bolts or drill new holes in the middle. Would drilling bigger holes be too weak in your opininions? Should I drill new holes in the middle for strength? Either way do you know what size and thread count nuts I would need?
How did I miss those bolts.... [img]/ubbthreads/images/graemlins/confused.gif[/img].
Also, did you use a pipe cutter to cut the metal fuel lines? How do you depressurize the fuel line?
Thanks so so so much!
post #5 of 32 (permalink) Old 07-05-2005, 09:58 PM
My Photos: (22)
I ran 3/8" rubber 30R7 fuel line from tank to the filter, I don't use the meatl line any more.
Hammer
I still have the:
<font color="red">
</font>
post #6 of 32 (permalink) Old 07-05-2005, 10:14 PM
JimTJr's Avatar
My Photos: (20)
Use a tubing cutter like for plumbing tube. The fuel system on these doesnt "HOLD" pressure really. The truck starts on what is in your fuel filter housing,,and when the pump starts it keeps the fuel bowl full. I think the HEADS may stay pressurized some,,with a check ball in there...but not sure.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #7 of 32 (permalink) Old 07-05-2005, 10:29 PM
DIESELSITE's Avatar
The supply line is not under pressure at all. It is a suction line. But, to answer the above statement, the fuel system bleeds down completely after shutdown.
Bob
Bob Riley, Owner DieselSite.com
Proud Sponsor of TheDieselStop.com
GOT DIESEL? call us at 888-414-3457
DIESELSITE is offline
post #8 of 32 (permalink) Old 07-06-2005, 04:41 AM
Curiosity begs the question: What is the fascinaion with Dahl? We used them on our equipment fleet many moons ago, and they were not even close to Racor's in quality and filtration.. We dumped a bunch of them in the trash and went all Racor... Have they improved??
Scott
99 F250/PSD/SC/6Spd/chipped/K&N Lovin life
2004 F250/6.0/CC/Auto... Not exactly loving life anymore, gave back to momma ford..
2005 F350SRW/6.0/CC/Auto/FX4... OOPS, I left it on his lot. NO tolerance for stealers that try and screw me..
06 F350SRW/6.0/Auto.CC/LWB/4x4 ordered 5/4/05..
VIN recieved 5/17/05. Truck on the dealers floor 6/15/05
5/18/07 49k FLAWLESS miles.. I love this truck
11/17/07: 59k miles: EGR hiccup.. Still love this truck
12/14/09: 95k HARD working Miles.. Front cover puked water, dropped off at dealer, part backordered.. Still love this truck
Scott B is offline
post #9 of 32 (permalink) Old 07-06-2005, 06:17 AM
My Photos: (17)
I have not done a direct comparison, however the 2 micron filter in the engine compartment uses the same filtration media/principles and I rarely saw any water in the fuel filter when I drained it. The Dahl filter (2 micron in my case) separates several tablespoonfuls of water every 3000 miles. Sometimes it could be measure in multiple oz.s of water. So in my opinion, the Dahl is a more effective water separator and it flows with minimal restriction.
post #10 of 32 (permalink) Old 07-06-2005, 08:40 AM
I just won a Dahl 200 off of EBAY for $43. I'm thinking that I'm going to have to mount this thing on the roof. I had no idea how big it was.
Don.
'97 F-350 XLT,CC,DRW,E4OD,4.10,Transcommand- Deceased
'99.5 F-350 Lariat, CC, DRW, ZF6, 4.10, Lightly Swamped
TruckerDon is offline
post #11 of 32 (permalink) Old 07-06-2005, 11:50 AM
Chinookman's Avatar
Don.
ROFLMAO.... [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
YEAH THEY IS A BIGGUN EH...!!!
That was the same reponse I had when I got the 100 can't imagine how big that babi is....he-he
C-man
2003 7.3 CC XLT Sport short box 2wd dark shadow gray ,AIS Intake Kit, MBRP 4" w/3.5" D/P & 5" SS tip;Wicked Wheel ;Ultra Duty Aluminum Diff.cover JNB kit "HUTCH MOD" and Dahl 100 fuel filter. Silverstar lamps,203 T-stat w/Red billet housing. Fumoto DV w/nipple, AIH mod, Zoodad, Amsoil BMK-11 Oil ByPass Kit,fuel reg. shim @ 0.055 for 65-68 psi. Harpooned tank,Hx Mod, Coolant Filter, Po'man's Fx mod,CCV mod & 6.0 tranny cooler!
Saved by Grace, not by choice
6 turning, 2 burning-Love the smell of JP-4
CH-47C Super 'C' 73'-75'
Chinookman is offline
post #12 of 32 (permalink) Old 07-06-2005, 11:56 AM
Chinookman's Avatar
Kinda hard to imagine a better filter unit that goes down to 2 microns and separates the water so well. OEM filter 10 microns Dahl-2 micron @ 80gph truck needs 40 gph.
Racor good product also but what was used to conclude the Racor is so superior to cause a businessman to trash the Dahl's into the dumpster...?..... [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
C-man
post #13 of 32 (permalink) Old 07-06-2005, 01:36 PM
QtrHorse's Avatar
Don.
I almost bought a new one off Ebay about a month ago as well. Then I found out how tall it was (16.75 inches) but think of this, you probably won't have to change the filter but every 100,000 miles. [img]/ubbthreads/images/graemlins/grin.gif[/img] The only option you have, is to mount it in front of the back drivers side wheel, I believe there is about 18in or room there. That's where I was going to mount the Dahl 150 I was going to buy but bought a little Dahl 65 (same filter Bob's uses in his basic fuel system package) off Ebay for $21.00 shipped and decided to use that one until I get a bigger fuel pump that flows more volume than stock.
99.5 F250 XLT S/C 6SPD
ITP Intank ModsLUK clutch w/ Kevlar pilotAFE Stage1Red Top OptimasReflexxion Cowl Hood
QtrHorse is offline
post #14 of 32 (permalink) Old 07-06-2005, 05:13 PM
My Photos: (31)
I mounted mine like THIS.
It's mounted to a piece of flat stock welded to the frame. It was hanging a bit low for my liking so I actually have it tilted at an angle and it's protected by the skid plate.
Does anyone know if mounting it at an angle (~30*) affects the operation of the unit? I'm not so worried about water seperation, since out here in CA I have yet to get much if any water in my fuel. I have been getting air, even after the in tank mods though. Maybe I have to get myself an air dog. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
BTW- I used a "full flow" valve from McMaster-CARR. It has a larger, full sized opening through the ball valve.
F250 CC PSD, 6-Spd, 4x4, DP Tuner 4 Pos Chip, 4 BD Cat Back, Cat Delete, 3.5 Down Pipe,
, ITP Fuel Sys,
, Home-made Headache Rack,
289 4-Speed 9"
Fat Diesel is offline
post #15 of 32 (permalink) Old 07-06-2005, 05:13 PM
My Photos: (11)
The OEM in valley filter for the 7.3L is also 2 microns.
Also, the flow rate specifications for the Dahl 100 are 40gph recommended and 65 gph max and it will do just fine in our applications with a stock pump.
Larry, keeper of the <font color="red"> New revised </font><font color="blue">"little secrets" </font> CLICK HERE [img]/ubbthreads/images/graemlins/smile.gif[/img]
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font>
, BTS w/Schaeffer's ATF
, ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10 Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets"
, & a 1981 26' Prowler TT(26Y)
Larry M is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
