Diesel Filler neck and cap for auxillary tank - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 04-28-2007, 04:06 PM Thread Starter
I'm building an auxillary tank that will mount under my truck. I would prefer to find a filler neck that takes an OEM style threaded cap. Any ideas where to locate such a part? a stock 06 filler neck is over $100 from the dealer. I may try the local JY but I'm afraid it will be all gas stuff there.
06 Red F250 Crew Cab 4x4 6.0L XLT sport
Justin00Stang is offline
post #2 of 4 (permalink) Old 04-28-2007, 05:01 PM
JimTJr's Avatar
My Photos: (20)
Re: Diesel Filler neck and cap for auxillary tank
I would guess any Super Duty filler neck would work. (Off Powerstrokes anyway) And you need the rubber connecting hose, and weld a neck onto the tank it will fit.
(How are you fabricating an aux tank for UNDER the truck?
Where are you going to put it under there?
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #3 of 4 (permalink) Old 04-28-2007, 05:08 PM
I just picked up a filler neck off of a 99PSD from a junk yard for $65 for the neck, cap and hoses to the tank. Stealer wanted $171. Call around, it is worth it.
Keep Strokin'
: Early '99 F350 CC LWB 4X4
Annoy A Liberal
Work Hard, Succeed, Live Happy!
Family of 5 saved by Grace.....
strokin_early_99 is offline
post #4 of 4 (permalink) Old 04-28-2007, 05:51 PM Thread Starter
Its going between the transfer case and main tank. My truck is a CC short bed 4x4. If it was not for the 4wd I could run a much larger tank. This tank will be about 18gal, it will hang about 1" lower than the stock tank, but still higher than the cat.
I figured 18 gal would give me plenty of extra range, but after towing my dyno trailer with a car on it I was getting 10.5-10.9mpg (about 11,500 lbs for dyno trailer with car). With just the dyno trailer (8,000lbs) I get around 13mpg.
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
