Dually to Single rear wheel conversion... - Diesel Forum - TheDieselStop.com
Old 12-29-2005, 01:11 PM   #1 (permalink)
What is needed to convert a 2005 Dually F350 to single rear wheel? Are the axles different?
--John
2004 Expedition XLT
2005 F350 Diesel, Crew Cab, Dually
johndjmix is offline   Reply With Quote
Old 12-29-2005, 02:10 PM   #2 (permalink)
Re: Dually to Single rear wheel conversion...
The rear axles are different. the dually pick up rear is wider, but nothing is needed to just put the SRW wheels on it, they will bolt up. the front, you have to change the hub, and maybe the rotors.
08 f450 KR 4X4, no roof, no tv, everything else
05 KZ New Vision 41ft toy hauler
03 harley roadking classic
03 honda rubicon
05 bombardier DS650
http://i5.tinypic.com/4ue76eq.jpg
6SPDMANUAL is offline   Reply With Quote
Old 12-29-2005, 07:16 PM   #3 (permalink)
is your screen name also your name? send me a PM if you can.
If you can read this thank a teacher...thank a soldier it"s in English.
oicu8121 is offline   Reply With Quote
Old 12-29-2005, 11:14 PM   #4 (permalink)
Yea I dont know where you are but I will trade you all the parts you need with my 06 SRW
racing4funn is offline   Reply With Quote
Old 12-31-2005, 02:36 AM   #5 (permalink)
racing4fun, I sent you a message with my email...
In the meantime, can anyone list ALL the parts that would need to be swaped?
--John
2004 Expedition XLT
Old 12-31-2005, 09:49 AM   #6 (permalink)
1- remove dually wheels
2- remove front spacers
3- remove dually fenders
4- add bushwacker flares
5- use a set of stock or aftermarket single wheels
bruceb63 is offline   Reply With Quote
Old 12-31-2005, 10:01 AM   #7 (permalink)
If you are interested, I'll swap all parts needed to do the conversion, if they will fit, from my 2003 F-350,long bed, SWR....bed, rear end, wiring harness, and all. I'm wanting to convert mine to a dually.
capt205 is offline   Reply With Quote
Old 12-31-2005, 02:43 PM   #8 (permalink)
DrSpeed's Avatar
My Photos: (12)
well, the 99-04's have different axle widths than the the 05+ superduties.
and double check this if i'm wrong, but I think that the DRW and SRW have different bolt patterns as well.
the SRW still have the 8x170mm. the DRW are like 8x200 or something...
2002 F250 SuperCab Longbed CUMMINS 6Spd True Blue
Bellingham, WA
40" Toyo MT's, KMC XD Rockstar 20x12, 12" Lift, Donahoe Racing Signiture Resevoirs, PSC Hydraulic Assist with X-Over Steering, Dynatrac Superduty Combo Kit, Velvet ride Shackles, 4.11 Yukon Gears, Dana 80 Swap with ARB Locker, SSBC V10 8 Piston Caliper Brakes, SBC DD Pulling Clutch, Custom 5" Turbo Back Straight Pipe, Autometer Ultra Lites, Line X, Warn Hubs, AMP Research Power Steps, Retrax Tonneau, Blitz TT, Kenwood System w/JL12W6, 6000K HIDs, Flames by KC Customs, Road Armor Bumpers Front and Rear with PIAAs and Hellas.
MOTOR SWAP COMPLETE!
2003 Cummins ISBe Common Rail - ARP Studs, VGT Twin setup, ATS 3-piece, Smarty Programmer, Edge EZ, F1 Diesel Flux 2 Sticks and Cam, Floor It Diesel Stage 2 CP3.
My Truck Pics -
http://www.truckblog.com/drspeed- Writer and Photographer
DrSpeed is offline   Reply With Quote
Old 12-31-2005, 04:38 PM   #9 (permalink)
So the axle's dont need to be swaped....bruceb63 says there are just spacers...?
--John
2004 Expedition XLT
Old 12-31-2005, 08:13 PM   #10 (permalink)
DrSpeed's Avatar
My Photos: (12)
well, the SRW uses a sterling 10.5" rear, while the DRW uses a Dana 80. the spring pad mounting widths are the same, so you can swap those...otherwise, the DRW axles are wider than the SRW's.
Bellingham, WA
My Truck Pics -
Old 01-01-2006, 06:39 AM   #11 (permalink)
uloadit's Avatar
It be nice if there was some one out there that made a rim that was extra wide and a tire that would fit on it that would fill up the dually fender .That way in MA I don't have to get commercial plates that cast $150 every year .Single wheel trucks can get car plates that are cheeper and renew every 5 years. Dave
2002 F350 XCAB D.R.W.auto 4x4 manual lock.P.S.D.3.73 axl(code-VDH2) (BONE STOCK).15 m/gal empty- 12/gal 19,500Lb piller gauges (ISSPRO)pyro,boost,trans temp-under dash cub mount (V.D.O.)oil pr,volt,eng temp.AIS air filter,baldwen spin on trans filter,RACOR INTERCEPTOR kit primary fuel filter (and fuel heater)6.0 transmission cooler,
uloadit is offline   Reply With Quote
Old 01-01-2006, 09:18 AM   #12 (permalink)
John
Call me with your questions.
Bruce 570-842-0526
