F250 rear bumper upgrade question???? - Diesel Forum - TheDieselStop.com
Old 01-07-2007, 02:48 PM   #1 (permalink)
Does anyone make a "ranch hand" style rear bumper that retains the stock receiver hitch? I would like a heavier rear bumper, but do not want to remove the stock hitch.
Thanks in advance..........
2002 F250 7.3L.... stock (for now)
amctxs is offline   Reply With Quote
Old 01-07-2007, 02:59 PM   #2 (permalink)
Gumbeaux's Avatar
Re: F250 rear bumper upgrade question????
You can get Ranchhand bumpers in different drops, or at least you used to be able to. To do what you're trying to do, I think you need a 5" drop, maybe 6". Most of the ones you see are 8" and cover up the stock receiver, so they just take them off.
I'd call or email them and see what options they have. I've seen plenty of trucks with ranchhands that kept the stock receiver hitch.
Or you could do what I did on my old truck and get the 8" drop, then bolt a receiver mount to the top of the step. You can still use your ball mounts and all of your other 2" accessories in it, and it's plenty stout.
2004 Excursion 4X4 Limited - All options except 2nd row buckets - 6.0 PSD - X Springs front and 4" blocks in the rear - 295/75R16 BFG AT's - Superchips programmer - Ranch Hand brush guard - Sirius Radio - Infinty speakers, Blaupunkt powered sub - Garmin GPS - ProComp shocks - Thule rack - Custom lifts for rear liftgate My Photos
Gumbeaux is offline   Reply With Quote
Old 01-07-2007, 03:31 PM   #3 (permalink)
i think ranch hand makes one. my south texas rear bumper has a hitch built in (welded), it supports twice the load of the stocker- which is why i went ahead and bought it.
2002 F250
DarkShadowDiesel is offline   Reply With Quote
Old 01-16-2007, 12:35 AM   #4 (permalink)
i do. we can build it however you want it. check my website.
sgrem is offline   Reply With Quote
Old 01-16-2007, 11:48 AM   #5 (permalink)
Ranchhand does make a standard bumper which I think is called an eight inch drop which will allow you to retain the stock receiver hitch. That is what I have on my 99 4x4. The only drawback is you cannot get it with the oval reverse lights as there is no room for them. They build them better and better as the years go on, this one is very solid and is actually partially sandwiched between the factory receiver and the frame.
I do recommend keeping the factory receiver as I've had Ranchhands before that were 10 and 12 inch drops and they had to be welded on or else they would move around on you, some even needed bracing.
early 99 F350 4x4
DieselDeaf is offline   Reply With Quote
Old 01-16-2007, 07:07 PM   #6 (permalink)
Check out the tough country rear deluxe bumper. They look good and very heavy duty. www.toughcountry.com
06 F-250 King Ranch FX4 Blk/tan sct programmer, 2.5" leveling kit, 20x10 diamo 17 karat chrome rims, 33x12.50r20 toyo m/t, 4" turbo back mbrp straightpipe exhaust w/5"tip, pioneer double din radio w/gps
myles05 is offline   Reply With Quote
Old 01-19-2007, 10:12 AM   #7 (permalink)
Rickie's Avatar
Take a look at www.buckstop.biz for their rear bumpers. I think they look nicer than any Ranch Hand products, at least for what the guys have purchased around here, including for our company rigs.
'00 F250 XLT 4x4 (born on 6/00), manual tranny & hubs, SPA Techniques EGT/Boost Gauge, Homemade HX Crossover Mod & Return Fuel Regulator, Toro Liner, 203* T-stat and Coolant Filter, LUK Clutch, flywheel & pressure plate, Amsoil Dual Bypass Filter
Rickie is offline   Reply With Quote
Old 01-20-2007, 01:53 AM   #8 (permalink)
oops. www.ironhorsetrucks.com
Old 01-20-2007, 11:01 AM   #9 (permalink)
Thanks guys, I bought one yesterday. Heading out this afternoon to install.
