f550 : want bigger tires!! - Diesel Forum - TheDieselStop.com
Old 11-09-2009, 06:59 PM   #1 (permalink)
hey guys, so it seems liek its time for new tires on the 06 f550..
i really want bigger tires that will add some height to my truck, i cant seem to find any info about this, can someone please help me with tire size etc?
i deff want something a littlemore aggresive and taller, im sick of getting stuck in the sand and mud, any help would be appreciated, i pretty much want more height without a lift kit.. i tow alot of weight and i dont want to lift it any time soon.. thanks alot brothers
06 F550 dually with bed ,Pioneer z1 touch screen, Kicker component speakers front & back, 3 10" kicker CVR subwoofers, 10K HID headlights&Fogs,3 pod pillar egt boost trans, Banks 4" turbo back exhaust muffler n cat gone, custom 6" lift by RMS, Airaid intake,Zoodad , Bed cover, chrome grille, SCT by innovative xtreme tuned . All runnin on 35's
soon to come: ARP's, injectors, turbo
gmoney69 is offline
Old 11-09-2009, 08:10 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
It's very expensive to move to a bigger size on a commercial-type truck. Your wheels are 19.5'x6" and your tires are 225/70R19.5 G or H.
The next size up, 245/70R19.5 requires wheels at least 6.75" wide, and with the right offset/inset to give you 0.7" more spacing between the dual wheels.
They also make commercial truck tires in sizes 265/70R19.5 and 285/70R19.5, but those require rims at least 7.5" wide and even more spacing between the duals.
When shopping for commercial truck tires, realize that "real truck tires" come in four different types: drive, steer, trailer and all position. The all position tires are usually the most expensive, very few come with an agressive tread, and that's probably what your truck came with from the factory. But if you need more traction, then you want drive tires on the rear axle, steer or all-position tires on the front axle, and trailer tires on the trailer.
Assuming you don't want to spend a fortune on new custom-size wheels, then stick with your stock wheels and go with Michelin XDS2 in size 225/70R19.5 on the rear axle. The XDS2 has a "traction" tread that should fix your traction problem. (Don't even deam about mounting tires that are too wide for your rims.)
Michelin Americas Truck Tires - all tires
Then scroll down the middle column until you see XDS2.
Then maybe the Michelin XRV in size 225/70R19.5 on the front axle.
Michelin Americas Truck Tires XRV®
Of course, if you want to spend the big bucks for new custom-size rims so you can go with bigger meats, then Stockton Wheel will make them for you.
Stockton Wheel Service - Custome Wheels
And RicksonTruck probably will too.
Rickson Truck Wheels and Accessories
Be ready for sticker shock when you hear the price.
SmokeyWren is offline
Old 11-09-2009, 10:02 PM   #3 (permalink)
saw a f550 fire truck last night with 37x13.5x20 mudgrapplers (i think). i talked to the fire chief and he said that they did great with them that wide all around. it was not a dual rear though
spacecwboy is offline
Old 11-09-2009, 10:19 PM   #4 (permalink)
so your saying you cant go taller with stock wheels..?
gmoney69 is offline
Old 11-10-2009, 02:33 AM   #5 (permalink)
i dont really want to go much wider, only a little bit, but i want a couple inches taller.. can anyone point me in the right direction? my tires are pretty bad and need replacing soon
gmoney69 is offline
Old 11-10-2009, 08:36 AM   #6 (permalink)
dlblazer's Avatar
No bigger - there is really only one size of tire produced for that width of wheel. The Rickson wheel website has a nice page speaking to the F550 wheels and why you can't go bigger.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter (no more), Superchips 1705 tuner, Reese Titan, AIS, IPT pre-pump filter kit, in-tank mods, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
dlblazer is offline
Old 11-10-2009, 09:19 AM   #7 (permalink)
According to the Rickson website the 8R19.5 will mount on a 6" rim and are about one inch taller (33.4") than the 225/70R19.5.
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 11-10-2009, 03:12 PM   #8 (permalink)
SmokeyWren's Avatar
My Photos: (44)
That's about what it amounts to, if you want a traction tread. As RD97 mentioned, there is an ancient size 8R19.5 no longer widely available that is a half-inch narrower and about an inch and a half more diameter than 225/70R19.5. Check out Bridgestone R187, Goodyear G647 RSS, and Michelin XZA. But those are all highway rib tread, so I doubt they would meet your definition of higher traction than your stock ties.
