Fog Light Harness Upgrade - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 10-25-2005, 10:31 PM Thread Starter
Everyone talks about the headlight harness upgrade all the time.... has anyone done a harness for their fog lights yet?
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ Black Interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Icon Lift Kit, Icon 2.5" Piggy-Back Shocks, KMC Beadlocks w/ 33" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Line-X, MotoBar, Gentex Temp/Direction Mirror, Baja Designs 22" Onx Pro Light Bar
RRose is offline
post #2 of 10 (permalink) Old 10-26-2005, 03:35 PM
Re: Fog Light Harness Upgrade
It can and has been done. The problem however, even with the increased voltage and switching to 9006 bulbs, the lenses on the factory foglights distort some of the light output. You can certainly see the difference at least in the one I saw.
wildbill1963 is offline
post #3 of 10 (permalink) Old 10-31-2005, 06:15 PM
Can anyone tell me what the headlight harness is all about? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Mangolia is offline
post #4 of 10 (permalink) Old 10-31-2005, 08:35 PM
guardrail22's Avatar
basically the Ford wiring has a bit of voltage drop inherient in its configuration so you don't get max voltage on the bulbs.
Easiest thing to do is go to WalMart and get a couple of Silver Stars and then order the harness at
http://www.suvlights.com/
so you get full battery voltage on them and enjoy. About $140.00 total.
New Truck
2012 F150 SuperCrew Lariat 157" VWE
Traded March 2013
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch
guardrail22 is offline
post #5 of 10 (permalink) Old 11-01-2005, 03:02 PM
Good info guardrail. Thanks
Mangolia is offline
post #6 of 10 (permalink) Old 11-01-2005, 05:11 PM
dwelch1's Avatar
My Photos: (5)
My XLT didnt come with factory fog lights, I would like to add them in the "Factory" holes in the bumper, what the best to use? whats the best way to switch them?
2015 F-250 Crew Cab, Lariat, 4x4 Magnetic
13K miles so far. Retrax Pro Cover
Relaced My:
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
dwelch1 is offline
post #7 of 10 (permalink) Old 11-01-2005, 05:54 PM
Send a message via AIM to Bobcat698
We carry the Heavy Duty Harness and bulbs for the 9007 and 9008 systems on our site. You could read about the advantage through this link
PURE DIESEL POWER
TS Performance chips, SCT, Edge Products, AFE, Superchips, Diablo, Autometer & Dipricol Gauges, Turbo Air Guides, MBRP & Magnaflow Exhaust, Aeroturbine, ATS, Hypertech, Steroid & 18K modules, South Bend Clutches & more!
Get STACKED with a 4,5,6, or 7 Inch STACK kit!
Call us for your exhaust pipe needs!
Superior Customer Service, FAST Shipping!
Garrett Shields
OWNER
715-254-1833
Bobcat698 is offline
post #8 of 10 (permalink) Old 11-06-2005, 03:38 PM Thread Starter
Hey... does any one sell a 9145 fog light "male" plug. I was thinking.... if I bought two headlight harness'..... and made each harness have a plug for the 9007 headlight and the other for the 9145 fog light... then..... you could have a really clean harness.... one for each side of the truck.... get more light out of your fog lights, and solve the fog light problem by having them on with the high beams. So let me know what you guys think and if you know of anyone that has a 9145 plug.
RRose is offline
post #9 of 10 (permalink) Old 11-06-2005, 10:56 PM
The Best here. But be prepared to pay.
2013 F350 CC Lariat 4x4 6.7L
2003 F250 SC Lariat FX4 6L sold
AK6LPSD is offline
post #10 of 10 (permalink) Old 11-08-2005, 05:55 PM
klhansen's Avatar
My Photos: (180)
If you mean a plug that looks like the bulb base and connects to the existing wiring harness, you could sacrifice a bulb and build your own. That's how I connected my headlight harness. Took the old bulbs, clipped the glass off and soldered to the metal leads coming out. Used one to connect the harness to the stock wiring, and the other for the high/low diode. Harness plugged to the passenger side wiring and diode plugged to the driver's side.
), AIS,
regulated return,
klhansen is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
