Originally Posted by bigbob
I have bought a factory set of fog lights w/ wiring harness and switch for my xlt which I am wiring totally separate from existing light switch. Is removing the bumper the only option for installing the fog lights? If so does the plastic cover below the bumper come off with it? I have found 4 bolts that removes the bumper, are there anymore hidden bolts I should worry about?
some of the bumper have extra supports on the sides that tie back in where the leaf spring is at. So if you don't see that then you just have the 4 bolts. Real easy...
the plastic cover comes off with it... there is a rubber guard that connects from below that you will have to pop out... real easy though..
01 F350 CC LB 4x4 SRW,(w/forged rods), 12.5" Lift, OUO Traction Blocks, Dynatrac Prosteer Ball Joints, SPYNTEC Conversion, 40"ToyoMT, 22"MKW M19's, Hybrids, GTP38R 1.15, BTS Chip, Spearco, Headstuds, 910 Springs, 4" exhaust, Coolingmist Water Injection, BTS Tranny, 6.0 Trans cooler, 05' Conv. w/ Mirrors, AFE2, Isspro Guages, ORU Diff Covers, Hella 500s, Transfer Tank, AMP powerstep, Heat Extractor Hood, custom paint, billet badges, Train horns, Recon lights, strobes!
Truck Pics
Old Truck Pics
