Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 12-16-2007, 04:15 PM   #1 (permalink)
FogLight Bulbs
I have an 02 with all clear lenses blue headlights and turn signals...i wanted to replace my factory fog light bulbs with something that was bright white or along the lines of that....anyone have any recommendations and the number of the bulb
i will probably just be running to the local auto parts store to get whatever if that help
daryl4412 is offline
Old 12-16-2007, 04:17 PM   #2 (permalink)
Re: FogLight Bulbs
a 65 watt 9005 bulb fits in the fog light and replaces the 42 watt 9145. i used silverstars but any 9005 will work (ie. if you want that real blue tint)
2001 F250 psd lariat cc sb, build date 08/00, PMT1, 4"turbo back stainless ATS exhaust,4 pos. custom burned Van Aaken quad power chip(stock,+50hp,+75hp,+130hp),airaid intake with prefilter,zoo-dad mod,ccv bypass,intake airheater grid removed,wastegate disconected and locked down,boost relief valve,VDO gauges,sonnax valve and tricumulator springs,24,000# B&M trans cooler,tekonsha prodigy,hella rally 4000 lights,firestone superduty rear airbags,rancho rs9000 shocks, helwig rear antisway bar, Bridgestone Revo 285/75-16
wlihntr is offline
Old 12-16-2007, 09:05 PM   #3 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Re: FogLight Bulbs
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: daryl4412</div><div class="ubbcode-body">I have an 02 with all clear lenses blue headlights and turn signals...</div></div>Just hope you know that the blue color you desire comes at the expense of decreased light output. Sometimes depending on color temperature it can be extremely reduced.
haul_n_horses2 is offline
Old 12-16-2007, 10:13 PM   #4 (permalink)
My Photos: (14)
Send a message via AIM to edub32
Re: FogLight Bulbs
what does the 9005 in the name actually mean?? Does this refer to size?? And are all 9005's the same?
2001 F350 7.3 SCLB 4x4 Off-Road SRW
- DP Tuner, Tymar intake, 35" BFG Mudders, Superlift 6" lift, DiPricol 3 gauge Pillar, 4" SS DP to 5" sidepipe to 6" Chrome tip, WW, Panasonic Deck with 4xInfinity References, Overboost Elim., CCV
edub32 is offline
Old 12-17-2007, 12:17 AM   #5 (permalink)
Re: FogLight Bulbs
9005 is the bulb number...i believe it is a common GM high beam. when you go look at the bulbs it will become obvious....
wlihntr is offline
Old 12-17-2007, 08:14 AM   #6 (permalink)
Re: FogLight Bulbs
Will using a 9005 bulb in the foglights cause excessive heat or any problems? Thanks!
2004 F-350 Lariat SRW <><
315 BFGs, Edge Platinum, ARP Studs, & B&W Goose
1998 Cherokee RockCrawler
NCfarmboy is offline
Old 12-17-2007, 08:31 AM   #7 (permalink)
My Photos: (17)
Re: FogLight Bulbs
No
Old 12-17-2007, 01:46 PM   #8 (permalink)
Re: FogLight Bulbs
Best bulb choice is the Hella Replacement 9005/HB3 Bulb, 12V, 65W +100%, Hella High Performance Xenon Blue..4k kelvin. I have been running them for years.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 12-17-2007, 01:56 PM   #9 (permalink)
My Photos: (17)
Re: FogLight Bulbs
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: caryt</div><div class="ubbcode-body">Best bulb choice is the Hella Replacement 9005/HB3 Bulb, 12V, 65W +100%, Hella High Performance Xenon Blue..4k kelvin. I have been running them for years.
Cary </div></div>Really, the best choice is to rip the faux foglights out of there and to put some real lights in. If you like the look of OEM lights, I recommend the Hella Micro FF lights. Hella Micro FF lights in '02 Superduty
Old 12-17-2007, 03:38 PM   #10 (permalink)
Greg373's Avatar
Re: FogLight Bulbs
Not to hi-jack, but how do you get to the foglamps?
Greg373 is offline
Old 12-17-2007, 03:49 PM   #11 (permalink)
Swellmel's Avatar
Re: FogLight Bulbs
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: haul_n_horses2</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: caryt</div><div class="ubbcode-body">Best bulb choice is the Hella Replacement 9005/HB3 Bulb, 12V, 65W +100%, Hella High Performance Xenon Blue..4k kelvin. I have been running them for years.
Cary </div></div>Really, the best choice is to rip the faux foglights out of there and to put some real lights in. If you like the look of OEM lights, I recommend the Hella Micro FF lights. Hella Micro FF lights in '02 Superduty </div></div>
<span style='font-size: 14pt'>Photo not found in the database!</span>
2002 F350 Red PSD Auto SC/LB SRW 4x4 Tymar Intake 4"Dual Exhaust DI 6 position twisty knob BTS 4R100 Vegistroke V3
Swellmel is offline
Old 12-17-2007, 09:21 PM   #12 (permalink)
My Photos: (17)
Re: FogLight Bulbs
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SwellMel</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: haul_n_horses2</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: caryt</div><div class="ubbcode-body">Best bulb choice is the Hella Replacement 9005/HB3 Bulb, 12V, 65W +100%, Hella High Performance Xenon Blue..4k kelvin. I have been running them for years.
<span style='font-size: 14pt'>Photo not found in the database!</span> </div></div>Pics 3,4,5 and 7 are still in the database. Check out pic 7 for the look from the front. The others show the mounting bracket.
Old 12-17-2007, 09:23 PM   #13 (permalink)
My Photos: (17)
Re: FogLight Bulbs
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Greg373</div><div class="ubbcode-body">Not to hi-jack, but how do you get to the foglamps? </div></div>Take off the grille. Four screws on top and 4 spring clips at the bottom. Then reach down behind the bumper, grab the lamp base and turn.
