Frame Extension? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 10-22-2006, 01:43 PM Thread Starter
artherd's Avatar
Frame Extension?
I would like to put a 12' utility bed on my 350, that means I need 84" Cab to Axle (CA) legnth.
My options as I see them:
1) Scrap this truck and buy a 2001+ F550 4x4 CC with 84" CA (HARD to find since they only made them from 01-02!)
2) Extend the frame on my current F350, and keep all of my mods, etc. Possibly swap in <with some welding for new spring perches> an F550 D135 axle (and regear the D60 in front.)
Issues: Pickup frames are a little wider, utility box will have to be sized to fit, and an axle swap will require cutting and welding new spring perches, not too bad.
My biggest question: can I have a quality frame shop extend the pickup frame nearly 2 feet without compromising the integrity of the entire vehicle?
I would add an uprated weight sticker to the 350 to about 15000lbs (and get 450/550 front adapters, and use 19.5" OEM wheels/tires) when it's all said and done.
What do you think?
- 99 F350 CC, LB, Dually - 01/98 Production Date - Tommy Gate hydraulic liftgate (awesome & highly recommended.)
- 19.5" Goodyear G622s on F550 wheels front and rear.
- F550 brakes. 1050CFM thermostatic 2nd tranny cooler. Prodigy brake controller.
- 4" exhaust to the turbo. 4-pillar EGT, TRANS, WATER, BOOST.
- Ford Ambulance APCM/AIC. Severe Duty AIS.
- Code 3 2100 LED Lightbar, Perimiter Strobes, LED-X lights, Electric (firetruck type) warning horn & PA.
- 4 batteries, Xantrex 250A automatic battery combiner/splitter.
- Dual Xantrex Prosine 2.0KW inverters for 110/220v, Laser printer/copier, plasma cutter, welder.
artherd is offline
post #2 of 7 (permalink) Old 10-22-2006, 06:48 PM
Re: Frame Extension?
What about this?
http://www.railerbed.com/home.html
Cheers
Mark
2003 F-350 SRW 4x4 CC SB XLT Sport, Auto, stock 7.3l, 285/75-16 Toyo MT's, TJM snorkel, front & rear ARB diff locks, diff breathers, Aerotank 55 gal repl tank, Viair 450H compressor, 3 gal air tank, Bilstien shocks, Ute Ltd front bull bar / bumper, Warn 12,000lb winch, X-springs, dr 2" spring pack, dr 2" rear blocks, dr adj track bar, Hella FF4000 lights, custom centre console, Locking drawer under rear seat, Espar D5 heater w/camper connects, custom roof rack, Bushwacker fender flares, rear seat modification and cargo platform, custom rear bumper step. 4Wheel Campers "Hawk" camper with custom interior CAMPER IS SOLD
Photos:
and
MarxF350 is offline
post #3 of 7 (permalink) Old 10-22-2006, 10:44 PM
JimTJr's Avatar
My Photos: (20)
Well, I dont know exactly how much money you have, but so there would ONLY be one weld, I think I would find a frame from another truck,, make the cut on yours where you want the splice to be,,and cut the other one two foot forward of that,,when you put the rear section on,,it will be two foot longer, then ONE WELD and some bracing would be much easier to do,,, just a thought.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #4 of 7 (permalink) Old 10-23-2006, 12:18 PM
...My biggest question: can I have a quality frame shop extend the pickup frame nearly 2 feet without compromising the integrity of the entire vehicle?
I would add an uprated weight sticker to the 350 to about 15000lbs (and get 450/550 front adapters, and use 19.5" OEM wheels/tires) when it's all said and done....
[/ QUOTE ]A quality frame shop should be able to extend the frame in a safe manner that keeps the strength of the original frame. But is the original frame as strong as it needs to be for what you want? One thing that comes to mind is what is the strength differance between the F450 frame you want to replicate and the F350 frame you wil be using? What I mean is, are the F450 frame rails made of thicker steel, are they taller/wider rails, etc? Even a seemingly insignifigant increase in the size of a frame rail can make a large differance in its strength.
I don't know how things are where you live and I hear some states will register the vehicle as what ever weight you tell them it is but I believe only a certified upfitter can legally change the actual GVWR of a vehicle.
Not saying it can't be done, just pointing out something to consider when making your decision.
Steve Urban
Semper Fi!
2007 F350, Lariat High Line, SRW, SC, LB, 4x4, 6.0/auto, FX4, Camper Pkg, HD alt, Red w/custom black two-tone, Buckstop bumpers F&R, Warn 16.5ti winch, Line-X, F550 coils, 305/70R18 ProComp XtremeMTs
2007 Apex9.5 truck camper
1973 Bronco (stock), wife's
1973 Bronco (HEAVILY modified), mine
2006 Mustang V6, Screaming Yellow, wife's
2006 F350, Amarillo, SRW, CC, 4x4, SB, 6.0/auto (traded)
2004 F350, SRW, CC, SB, Sport, 4x4, 6.0/auto (bought back by Ford)
SteveIn29 is offline
post #5 of 7 (permalink) Old 11-29-2006, 08:55 PM Thread Starter
artherd's Avatar
What about adding extra steel in either L channel or C channel?
artherd is offline
post #6 of 7 (permalink) Old 11-30-2006, 06:07 AM
NCHornet's Avatar
What do you think?
You don't assign the weight sticker, a goverment agency will need to evaluate what you have done and they will assign a new weight rating. I doubt you will ever come close to having the same weight rating as a F550, there are lot's of differences. I would probably look for what you want and buy it already made from the factory. But I don't like headaches.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #7 of 7 (permalink) Old 12-05-2006, 07:36 PM
Check for a utility bed installation shop in your area. They do it all the time and know the correct way to go about it.
early 99 PSD F250 sb/sc 4x4 Auto Blue/Silver Med flint int.
BTS program 80tow/100tow/100Daily/120xtreme, Air Raid Intake, Autometer Ultra Light on A-pilar, 4" Turbo back W/Staight pipe, Gutted EBV, crimestopper cs2016fm, Triple clutch converter, Boone's automotive Transmision, BTS Valve body
Babb is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
