Front suspension assist when plowing - Diesel Forum - TheDieselStop.com
Old 11-10-2009, 05:41 PM   #1 (permalink)
I have a 8.5' Western Pro plow with the Ultramount. The setup adds about 900lbs to the front of my F-250. I am sure there are plenty of people out there with this type of setup, what do you use to compensate for the extra weight of the plow? Airbags? Coil spacers (solid not the clamps)?
My truck did not come with the snowplow prep.
Any suggestions would be appreciated.
07 F-250 Harley Davidson Edition PSD 4x4
Upgrades: 08 towing mirror upgrade, 08 center console upgrade, LED tail & third brake lighting, Leer 700 tonneau, Western 8.5' snow plow, 275/65R20 BFGoodrich AT KOs on DC-1 20x9s
enforcer17 is offline
Old 11-11-2009, 11:55 AM   #2 (permalink)
Not sure about you coil over boys, but I just went with some upgraded factory springs, going from a U to an X code on my 250 for the added weight of my plow, and for a inch or so LIFT!
You might be able to get yourself a diffrent code springs and do the same?
2002 F250 PS X-CAB 4X4 SB
Edge EVO2(soon to be PHP's Gryphon) 4" SS Turbo back(no muff) 3367 AIH delete
PowaStroka is offline
Old 11-11-2009, 02:21 PM   #3 (permalink)
Yeah, a bit different, but the concept is the same ... when you went to the X code springs, did that raise the front of the truck, I don't want any height change which is why I was thinking air bags that would be inflated only when I have the plow on.
Old 11-11-2009, 02:56 PM   #4 (permalink)
Yes the X-codes will raise my truck about an 1-1 1/2. But there were other "lesser" codes that were designed to deal with more weight without much lift.
Im sure the coil codes are the same way.
Can anybody else chime in to help here?
On the other hand if there is a airbag system, all though probrably more $$ than the upgraded springs, you cant deny the cool factor of a setup like that.
Old 11-12-2009, 09:31 AM   #5 (permalink)
Air bag system definitely would have the cool factor, my concern is durability. I used them a lot in my muscle car days, though they look a lot better now.
Anyone have the airbags up front on a coil front end? How was the install?
