gears for 35's, are 4.56's too low?? - Page 2 - Diesel Forum - TheDieselStop.com
Old 03-02-2005, 09:07 PM   #16 (permalink)
dondiesel444's Avatar
Re: gears for 35's, are 4.56's too low??
so 4.30's sound good. where did you get them?
I'll probably just put the $ towards more power and go with gears when (IF) I ever get 38's-40's. unless I can get a smoken deal somewhere on 4.30's
2001 F-250 PSD Crew Cab short bed, 4x4 Lariet, only 97k miles bone stock for now
previous trucks:
2001 F-250 PSD CC SWB 4" lift, 315's, DP Tuner..
late '99 F-350 PSD CC LWB 4" lift, 315's, DP......
early '99 F-250 PSD SC SWB short shifted 6-speed, 5" stacks, 5.5" lift, 4.30 gears, DP Tuner, etc....
1997 F-350 PSD 4x4, 4" lift, 35's, Superchips tuner
TRUCK PICS
dondiesel444 is offline
Old 03-02-2005, 11:43 PM   #17 (permalink)
My Photos: (19)
Randys ring and pinion is where I bought mine.
redrocket
*SOLD* 2001 F-250,Toreador red,ext cab,4x4,BB turbo/1.15 housing,Mini Me's,pushrods,headstuds,AirDog,ATS Stage 5 tranny,DI headers,Hypermax Tapercore,471hp/lost the tq(Dynojet)
*NEW* 2004.5 Dodge Cummins,LB,QC,4x4,Laramie
redrocket is offline
Old 03-03-2005, 12:17 AM   #18 (permalink)
I had a local shop do the install. From what I understand, the 4:30 sets are starting to be hard to come by for the 10.5 rear end. My local shop got their hands on 3 sets and 1 of those sets went into my truck. It could be all BS though?!?
L1
2K2, F350, Lariat, PSD, CC, 4X, LB, SRW, Shadow Gray, 6" Lift w/Centerline Arrows & 35" Toyo MT , 4:30s 4" MBRP SS exhaust, John Woods trans/6.0L Billet TC, AFE stage II intake, Banks compressor wheel, Autometer gauges, Edge Evolution w/line pressure delete.
Loser1 is offline
Old 03-03-2005, 12:59 AM   #19 (permalink)
doubt theyll be a shortage as ford installs them as factory equipment on a lot of their trucks. even if you cant find new ones, junk yards should have them avaliable and you can always look for lifted gassers, so if they have theyre stock gears still...
mikeym is offline
Old 03-03-2005, 01:10 AM   #20 (permalink)
Send a message via Yahoo to ZooDad
I got my 4.30 from a Ex member here that switched them out. You might check with some of them. IF you ever plan to go bigger than 35, go for the 4.30's.
ZooDad
ZooDad is offline
Old 03-03-2005, 02:11 AM   #21 (permalink)
A couple of things to remember. The diesel only has a limited rpm range. A gasser cruises at 3000 these are almost maxed out there.
Also I have found the best fuel economy is 2100 or under. Drop the rpms down as much as you can without lugging it.
99.5 Green F250 Crew Cab short bed. Solid Chrome front bumper, chrome hooks, Chrome flame grill, 2005 Headlights and Emblems, K&N cone air filter, wicked wheel, 5" exhaust 6 1/2 tailpipe,Edge Evolution programmer, Pioneer in dash touch screen dvd player, Directed 200 amp to 4 pioneer 4ways Directed 600 amp to 3 10" JL audio subs, 6" superlift all riding on 4 Chrome 10x20 Helo Maxx 8S and toyo open country A/T 37/13.5/20 looks and runs like new.
jetski86 is offline
Old 03-03-2005, 06:38 AM   #22 (permalink)
most likely I'll go with a bigger lift and tire in the FAR FAR future, and if I did swap for 4.10's I'd kick myslef later on.
That is what I said and it didn't last long [img]/ubbthreads/images/graemlins/eek.gif[/img]
2000 psd CC SB 4x4,
This...That...And-The-Other...
OLD Powerstroke 7.3l
620.8HP/1157.9TQ Dunbar's Dyno 5/26/07
My Pics
New Cummins 5.9l 12v Conversion.
sno_cat is offline
Old 03-03-2005, 09:29 AM   #23 (permalink)
My Photos: (27)
I don't know what to do, I definatly want to get 35's real soon, but I don't wanna swap 4.10's in there, it's not THAT much of a difference to justify the cost. however who knows in the future if I'll go with an even larger tire, 37"-38" is probably the biggest I'd ever want for my needs.
I guess I'll jsut stick with the 3.73's and 35's for now and add some more power mods to make up the difference [img]/ubbthreads/images/graemlins/smokin.gif[/img] unless I can find anyone with 4.30's who'd wanna swap axles.
I've got 4.10's and 38's and the truck does pretty good, especially cruisin down the highway. The 6.0's got 35's and 3.73's and it'll roast em in first and second on level 3! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
IRAQI WAR VET AND PROUD OF IT!
2008 F250 FX4 6.4
SUPERF350 2006 F350
POWDER COATED CAC TUBES
PROJECT TRUCK 85 F250 4X4 6.9 6.0 IN IRAQ
superf350 is offline
Old 03-03-2005, 09:44 AM   #24 (permalink)
as many others have said, i think that you could actually get by with 35s and 3.73s. now, if you tow regularly, then i would consider gears. can you add some HP and torque to compensate if you do not add gears? yes, but what was done to address the shifting points and eliminate some stress on the tranny?
i have 4.56s in my truck and i am running 37s. this truck USED to be a daily commuter (50k in one year), and the 3.73s were fine running up and down the freeway at 75mph. now that she is used to primarliy pull my toyhauler, i moved up in gears. i can no longer run 75 without hitting 2500 rpms, but i feel better that the tranny likes me a whole lot better when it's got 12k in tow...
so, try running with 3.73s for a while... it might work fine for what you are looking to do...
2003 Ford F350 Crew Cab Long Bed 4x4, 6" Edge all spring lift with Adjustable Panrod Bar and Dual Steering Stabilizers, 37" BFG Mud Terrains, 4.56 Richmond Gears, DPPI Turbo Back Dual Exhaust, Autometer C2 Gauges on A Pillar, aFe Proguard 7 Intake, Reese Titan V Hitch, B&W Turnover Hitch, BrakeSmart controller, ORU Air Overload System
My truck pictures
double is offline
Old 03-03-2005, 10:12 AM   #25 (permalink)
I have a 6-speed so I don't have to worry about stressing the tranny any. I don't tow with this truck, thats what I have a Mack for! so for just cruising around I guess 35's and 3.73's will be fine. I am happy with the 3.73's and 295's now I am just affraid I'll lose lots of power when I switch to 35's...
previous trucks:
TRUCK PICS
Old 03-03-2005, 11:33 AM   #26 (permalink)
If you don't use the lowest forward gear of the 6 speed to get rolling you might play with that in the gear calculators since that will be about like stepping up the gears in the rear ends.
I am wanting a slide in camper and it is so heavy it looks like a 450 is going to be needed. Problem is the stock gears suck on the road when unloaded so I may wind up with some tires for when unloaded and then run the factory rims and tires when loading the slide in camper if I want to do things that way.
One consideration I am looking into is how well the low gear of the 6 speed will help get the load moving even with non stock tires.
But I am still learning and not close to ordering so maybe I am wrong on this concept.
ducky is offline
Old 03-03-2005, 11:50 AM   #27 (permalink)
I used to have 35's and went down to the 295's, it is a noticable difference but not huge. I have 3.73's and I tow 10,000 lbs about 20K miles a year and it towed fairly well, but it does better with the 295's and gained some mileage back towing.
Trinity
Early 99 6spd (Eaton Fuller Knob), 285x75 MTR's, DI 4 POS Chip, Walker BTM, listening to XM Delphi skyfi, pulling 24 ft full of Mechanical Bull, heading to a bar near you!
Truck pics
tsaelens is offline
Old 03-03-2005, 12:56 PM   #28 (permalink)
I spent some time using some long ago forgotten Algebra skills and I managed to put this formula together to calculate ACTUAL RPM w/ different gear ratios and such.
RPM = Overdrive ratio of tranny x mph x gear ratio x Revs per mile / 60
Overdrive ratio = Overdrive ratio for my 4R100 tranny is .71. Of course you can calculate RPMs for any gear that you would like. This can be useful for the manual guys.
mph = Whatever speed that you would like to know your RPM for stick in here. I tested speeds of 70 & 75 mph.
gear ratio = Stick the considered gear ratio in here. The options I was considering for my new 37s were the 4.10s and the 4.33s.
Revs per mile = The hell w/ just guessing by using 35s or whatever. I looked up the actual Revs per mile that the manufacturers list for their tires on their websites under "sizes & specs." This is MUCH more accurate and it REALLY changed the results of this calculation.
For instance, w/ 35" BFGs (revs/ mile are 600 for the 35x12.5x16.5) and with 3.56s you would be turning 2428 RPMs!!! There goes the fuel economy.
After looking and doing some simple calculating, for me, the 4.10s are EXACTLY right for my truck w/ the 37s I'll be running.
The truck will turn 1919 RPMs at 70mph and 2056 RPMs at 75mph which should be about perfect for fuel economy and a bit less of a gap between 3 & 4th gears than my current 35s w/ 3.73s.
So I will have a bit slower RPMs (faster gearing) than w/ stock tires w/ 3.73s but a bit faster RPMs (slower gearing) than my current 35s w/ 3.73s. It should be great!
Early '99 7.3 Superduty. Built 3-98
Built motor. Homemade "Big Oil", GT42R Big frame turbo. Rods and junk to keep it all together.
http://community.webshots.com/myphot...ecurity=MuSLdj
Suns_PSD is offline
