Glowshift gages - Diesel Forum - TheDieselStop.com
Old 09-23-2009, 09:42 PM   #1 (permalink)
Glowshift gages
anybody have an opinion on Glowshift gages?
2004 supercrew 4x4 6.0 stock
csf250 is offline
Old 09-23-2009, 10:36 PM   #2 (permalink)
dikkstarr's Avatar
I have those. I have a EGT, boost, and water temp. They work ok and are fairly accurate compared to my old banks gauges. The only things I dont like are they are a little too bright at night and are a little hard to read sometimes in the daytime because the numbers are small and clear insead of white for the back lighting, witch is on all the time. I tired a resistor to dim them a little, but it was too much and shut off the gauges. It might work with the right one. They do match the dash good just too bright, but Im kinda used to it by now. My whole kit with pod was 215 bux.
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline
Old 09-25-2009, 09:37 PM   #3 (permalink)
thanks !! I have been away . Iam thinking on oredering a set trying to figure where I want to mount them I do not want to be blinded at night from bright a-pillar gages!
csf250 is offline
Old 09-25-2009, 10:32 PM   #4 (permalink)
dikkstarr's Avatar
They arent that bright, just brighter than the dash lights. Actually, if the dash lights were as bright as the gauges, it would be perfect.
Glowshift gages-image001.jpg   Glowshift gages-image002.jpg   Glowshift gages-image003.jpg   Glowshift gages-image005.jpg   Glowshift gages-image004.jpg
Old 09-28-2009, 09:51 PM   #5 (permalink)
Thanks for the pic's they look good!!
csf250 is offline
Old 09-29-2009, 11:02 AM   #6 (permalink)
Todes's Avatar
Do you change them manually or do they shift on there own?
7.3L Stroken 4 life!!!
2002 F-250 4x4 7.3L Powerstroke 205K(7/2011)
AIS Intake system, BFG KM 2 Mud Terrains new @ 184680mi (1/28/10), Cab Clearance Lights self install 4/17/10, Foil delete and new IC boots 4/24/10
Todes is offline
Old 09-29-2009, 05:37 PM   #7 (permalink)
dikkstarr's Avatar
They do both. One setting switches through all the colors and the next setting cycles color to color automatically or you can select the color you want manually.
