Upgrades and Aftermarket - GeneralUpgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
my 2001 f250 did not come with a grab handle on the driver side. i keep grabing on to my steering wheel and pulling myself up to get in. i was told by doing that a lot it could mess something up in the stearing. is that true and where could i find a grab handle for the driver side?
The factory grab handle is that round thing right in front of the driver's seat. It will not mess up the steering.
our trucks downunder come with a grab on both sides.
my old 99 after it was converted to rhd, i ended up with the grab. wifey then had none on her side.
but the grab handle is just the same for both side ,just turn it around. i bought one down here for my 99.
to drill the holes though is a different story,you have to get hold of a drill with a 90 degree head, otherwise i would think you would have to pull your window out.
remember measure twice and cut once. mark the plastic on the pillar and cut in small sections ,checking the grab fit as you go. once you get that fit pull it off and drill.i think from memmory i used self drilling self tapping screws
99250
early 1999 ,f250,psd,s/cab,7.3,3.73 ,4*4,short box
harvest gold, snug top cover,xle 4 ,ais filter, bts tranny,v 10 cooler ,
isspro pyro ,trans temp guages.autometer boost
bought new from spokane,wa ,and converted to rhd in australia. sold.
forrest river wildcat, 30rlbs. sold.
06 250, 7.3, bts valve body, tuned by cale at bts.firestone air bags on rear.
cougar , 5er model 309, fitted with full air brakes.
Reason: spelling
You need the buy the handle and the A pillar cover as it is easier if you buy the newer style plastic A pillar cover as it will tell you exactly where to put the handle/bolts. I used 1/4 20 rivnuts to fasten mine.
Call john wood at John Wood Automotive - Home i believe i saw a couple laying around there from 03 and up trucks..probably from when he's done a couple of guage installs. Don't know for sure though...my memory is going bad. I'm sure he'd ship one to u right away if he had it. Sorry John if this is incorrect!
2002 F350 Lariat CC SRW 4x4 LB , Shadow Gray, Edge 4.5" w/ dual bilsteins up front/ Toyo Open Country M/T 315-75-16. Stock Motor 7.3, dual alts / 3 guage pillar pod, Auto Meter/ 5" turbo back magnaflow exhaust w/Aeroturbine muffler & 6" Jardine tip/ Husky 24k 5th wheel / Air Lift Bags.
John Wood Transmission / DP tuner / 08' rear diff cover
I've been pulling myself in via the wheel for 6 years now. No problems at all. I do have running boards though.
__________________ David Murphy www.DieselManor.com info@DieselManor.com Hours: Mon-Fri 8am-5pm EST Telephone: 603-497-2281 ------- Taking the Mystery out of Diesel Performance™
PRODUCT LINE: MBRP Exhaust Systems, aFe, Volant, S&B Intake Systems, Worlds Largest Distributor of ISSPRO EV Gauges, ART Cryo/Slotted Rotors, DiPricol OPTIX, Autometer Performance Gauges, Superchips, Edge Products, CFM+, Vulcan Performance, Mag-Hytec, Stanadyne, and more... - Please call us at 603-497-2281 for technical information or special pricing. --- DieselManor Guaranteed Pricing Policy ---FREE SHIPPING---
24/7/365 Secure Shopping Cart
Over a long period of time of using the steering wheel to pull yourself into the truck it will wear out the internals of the column. It happened to my buddies 94 F-250. The PO put a lift on it and used the steering wheel to pull himself in and wound up having to replace the column itself.
1993 Ford Bronco, 351W, Manual transmission swap (M5OD) THE TOY
1996 Ford F-150, 300 I6, Manual transmission,2WD 157,000 miles, going up for sale to get my diesel
