Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 11-06-2009, 11:15 PM   #1 (permalink)
Cowcop's Avatar
Smile Headlights
What year did Ford change to the clear lens headlights on our superduty and will they fit on my 99.5?
I tried projector lights last year and while they look awsome, I do not like the specific patterns they project. I hope to get clear headlights and move into the HID world.
99.5 F-350 S/C 4X4, 6 SPD.,BD Tow Chip,BD 4" Ex.,BD Guages, K&N FIPK & Wrap,BD Exhaust Brake(air activated),RANCHO 9000sx Shocks ,GENTEX Mirror ,C-Btr mirrors, ALPINE CD/Amps/CONCEPT Spkrs ,VIPER Alarm & AUTO LOC VIP System ,PIAA Lts. ,ALUMINUM tool box/dog kennel,cab guard & 5th wheel tailgate
OILGUARD Bypass Filter, DELVAC Synthetic Oil ,DIESELSITE Coolant Filter System & 203* THERM,Texaco Red Coolant ,ATS Turbo Housing,ITP Power Boost KIT ,ITP S.S HPX ,FCII tires on ULTRA MOTORSPORT rims ,TURBO MASTER Wastegate Controller ,BUSHWACKER Pocket Flares ,SPICER Ceramic Clutch ,FIRESTONE Air Bags & Compressor, MAG HYTEC rear diff cover, NC Hornet's CCV mod, ITP Reg. Return Fuel Sys.
Cowcop is offline
Old 11-07-2009, 12:47 AM   #2 (permalink)
2002 thru 2004 have the clear lenses. Silverstar ultras #9007 work real well.
02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 843,784 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
04 Grand Marquis LS sure wish it had a BTS!
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
HighwayPrisoner is offline
Old 11-07-2009, 01:24 PM   #3 (permalink)
Cowcop's Avatar
Smile
Thanks!!
Cowcop is offline
Old 11-08-2009, 10:02 PM   #4 (permalink)
they will bolt right in
can be a PITA though remove batterys for easier access
01 F350 Lariat CC DRW 2x4 Auto (now with 4x4 conversion)
TS chip 50/75/100/120 with PMT1
AFE stage one cross with some k&n fipk parts
Autometer guages (Pyro, Trans Temp, Boost)
Wicked Wheel and TAG 1&2
4" MBRP exhaust (stainless)
Billet grille & 02 headlights
Line-X
PTC triple disc converter, tugger kit, sonnax valves,cooler bypass delete, upgraded internals, suncoast coast clutch drum
future mods:
44boggers is offline
Old 11-09-2009, 07:02 PM   #5 (permalink)
Don't take out the batteries, instead remove the 8 bolts that hold the "Grill Filler" and the whole assembly comes out. This will give you access to the back of the headlights to pull the clips off.
RichZ
2000 White F550 PSD CC, Cabriolet Body, Firestone Air-Ride Suspension, 33.8G Aux Fuel Tank, 3 Pod A-Pillar gauges. TTT mirrors, US Gear D-Celerator, Pre-Pump/In-Tank Mod with Racor 645R30, 203° T-Stat/Bullet Housing, Fleetrite ELC w/filter, SunCoast Tranny w/3 disk TC, Mag-Hytec tran pan, and 6.0 Tran cooler, AIS Air Filter, AIH Plug, CCV Mod, SS HPX, Zoo-Dad, Trailer Saver II Air Suspension Hitch, Brake Smart Controller. Towing a HitchHiker 35.5' LKTG Premier at 16,360#.
RichZ is offline
Old 11-09-2009, 07:11 PM   #6 (permalink)
CHILLLS's Avatar
do the 05-07 head lights fit in the older trucks too?
(99.5-04)
ORDERD--2002 F350 4X4 CC 172
6 SPD OFF RD PAC CAMP PAC
DUAL ALTS 3.73 L/S PSD
8-28-01
CHILLLS is offline
Old 11-09-2009, 07:50 PM   #7 (permalink)
yes they do but the only way ive seen it done is to replace the grill and all
Line-X
future mods:
Old 11-10-2009, 12:38 PM   #8 (permalink)
I just did this 2 days ago on my 99. You don't have to remove the batterys or the grill filler. Just remove the headlights. The "trick" is removing the silver clips. I saw all the tips listed on this forum, but they were ineffective. I used a flat blade screw driver that I heated the tip with a torch & bent it into a "U". I use this tool to remove heater hoses. I used this tool to remove the headlight clips. The clips are spring clips, so they need an impact load to pop them loose. So, I got under the clip with my u tip screwdriver and gave it a sharp yank. The clips pop out without damage & can be reused.
FJK1 is offline
