heater plug replacement - Diesel Forum - TheDieselStop.com
Old 12-31-2008, 08:54 AM   #1 (permalink)
heavyduty's Avatar
Smile heater plug replacement
so what did you guys do when your heater plug went bad. what did you use and where did you locate it? where did you get your replacement plug and what was the cost for one? out of all the ones out there can you tell me one that will last so i wont have to replace it again. thanks for the replys
1999.5 F250 4X4 Automatic crew cab xlt,harpooned tank,,aem brute force intake, Rancho 9000 shocks, 5406 rancho steering stabilizer, magnaflow dual stainless exhaust, radiator filter, build date 12/08/98
heavyduty is offline
Old 12-31-2008, 10:29 AM   #2 (permalink)
bugman's Avatar
My Photos: (18)
If you are talking about the plug on the end of the block heater cord just go down to a hardware store and get one. You should be able to find one for less than $5.00. It has been quite a while since I even looked for one. If you want one that will last there is a mod that places a plug on the bumper or body of your truck or if you want to go another way just tie the cord up in the engine compartment and pop the hood when you want to plug it in.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 12-31-2008, 10:40 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
If you want one that will last there is a mod that places a plug on the bumper or body of your truck ...
TheDieselStop.Com - Marinco Block Heater Plug Mod
SmokeyWren is offline
Old 12-31-2008, 01:46 PM   #4 (permalink)
heavyduty's Avatar
thanks for the location of the plug thats the one i was looking for whats been the best place to locate one of those plugs for not having any problems down the road from salt or the road conditions ruining the plug
Old 12-31-2008, 02:30 PM   #5 (permalink)
My Photos: (19)
I've had my Marinco for a few years now and being around Chicago I get plenty of salt. There has been no adverse effects on the plug, the wires are fairly tarnished though. But that happened when the first plug went bad. As for placement, that's entirely up to you. Being in the bumper directly in front of the tire it will get all the spray it wants. Don't worry about it, it'll be fine. If you really want to, get a hot glue gun and fill the end with the hot glue to seal it up. Only issue with that is... if you ever need to take the plug off for any reason, you have to remove those wires.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 01-01-2009, 07:51 PM   #6 (permalink)
heavyduty's Avatar
whats the best way to attach it to the vehicle that i wont have to worry about the salt here in michigan
Old 01-01-2009, 10:08 PM   #7 (permalink)
My Photos: (19)
The Marinco Plug comes with a large nut just like any other metal conduit nut. It also comes with three small holes in the outside lip allowing it to be screwed to the surface. I just used the nut and it's been holding well.
BTBBT is offline
