How do you remove a roll-on bedliner? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 09-03-2007, 07:10 PM Thread Starter
Own a '99 F350 PSD with what appears to be a cheap roll-on bedliner. The material is separating and flaking off. Would like Line-X to spray, but know they won't shoot over top of this stuff. Can anyone recommend a product or method to remove the old bedliner without damaging the underlying paint? Thanks
2002 F250, 7.3L PSD, crew cab, 4x4, shorty, stock
flounder is offline
post #2 of 13 (permalink) Old 09-03-2007, 07:55 PM
Re: How do you remove a roll-on bedliner?
The only way to get it off is to grind it off. But if you are getting a spray on liner all you have to do is prime any spots you go through to bare metal.
Have fun, I have preached againest those due it yourself bed liners four years.
Wayne B
2000 F-250 XLT PSD 4X4 ESOF Auto, SC, LB, Gauges, Mag-HyTech Trans Pan & Rear End Cover, <font color="red"> (((XM))) Inside</font>, ATV Racks w/ Two Kawasaki Prairie 400 4X4's sitting on them, 25' Rockwood TT. Ashburn, Va. Member # 103
Wayne B is offline
post #3 of 13 (permalink) Old 09-03-2007, 08:08 PM
RDG
My Photos: (16)
My truck had a roll in liner [img]/forums/images/%%GRAEMLIN_URL%%/frown.gif[/img] from the previous owner. It cost me an extra $150.00 to have the body shop that did the Speed Liner spray in liner grind it off [img]/forums/images/%%GRAEMLIN_URL%%/blush.gif[/img].
Bob
TheDieselStop.com Moderator
TDS Member since 12.18.99 # 4366
NRA Member
Retired UAW 383
RDG is offline
post #4 of 13 (permalink) Old 09-03-2007, 10:45 PM
guardrail22's Avatar
buy a used bed with no liner in it
New Truck
2012 F150 SuperCrew Lariat 157" VWE
Traded March 2013
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch
guardrail22 is offline
post #5 of 13 (permalink) Old 09-03-2007, 10:56 PM
Heat... if you get the stuff real hot it will come off... heat gun is what I use.... but it takes forever.... Use a grinder.
2000 F350 Dual, Crew cab, 8ft bed, "The great white beast", Banks modified Garret turbo, Banks Exhaust, 3.73, 4WD, Super chips, Bullydog Trans shift pack, Auto meter gauges, 6.0 tranny cooler, Zoodad mod, SP EBPV/Trans controller, CCV mod coming soon, Foil delete, DIY Tymar and funky running boards.
vanmantraveler is offline
post #6 of 13 (permalink) Old 09-04-2007, 07:04 PM Thread Starter
I think Line-X would probably spray it, but I'd be surprised if they'd guarantee the work with the way the old stuff is cracking and chipping. Don't quote me on that. I know I wouldn't guarantee it. Maybe they won't spray anything they can't guarantee. Anyway, I'll run it over to them this week and get their opinion. Perhaps they can strip it off for an extra fee. Otherwise, I'm not messing with it. I'll either slap in a drop-in, or just learn to live with the way it looks. Thanks for your input.
Words to the wise - If you're considering a bedliner, and you expect to keep your truck for a while, don't use a
do-it-yourself roll-on kit. Pay the money and have it done right. I didn't have that option. You do.
flounder is offline
post #7 of 13 (permalink) Old 09-09-2007, 10:51 PM
jtobbe's Avatar
Roy if you are getting the bed re-sprayed the paint under the bed liner will not matter, However if you pay for mine to be Line-xed I will grind the old one out for you. [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
2012 F350 4x4 Dually
:! 6.7 Scorpion Diesel. Tuxedo Black with black interior, front bucket seats. Ultimiate Lariat package. Factory fifth wheel hitch B&W OEM. Dual alternators. Pullin' a 2017 Sierra 381 RBOK, and a 2011 Glastron GT205 Run-a-bout.
There's something sexy about a truck with big hips!!
Sold
2002 F250 7.3 4X4 Super Crew Short Bed.
DW like's the diesel so much I had to buy her one.
The "Baby Diesel" 2004 VW Jetta TDI. It's nice but it ain't my truck
jtobbe is offline
post #8 of 13 (permalink) Old 09-12-2007, 12:51 AM Thread Starter
Jason,
Careful what you wish for. After all your effort, I may actually come out ahead. All kidding aside, I'll probably just go with a Protecta bed mat, and cut a hole for the gooseneck. Don't know how well it's going to fit with that steel plate across the bed. Here's a link if you're interested:
http://www.americastruckcenter.com/E...ectaBedMat.asp
flounder is offline
post #9 of 13 (permalink) Old 09-12-2007, 01:50 PM
There are several ways to remove it, use one or several of these methods:
1. Hammer and chisel or air chisel.
2. Angle grinder with a knotted wire cup brush.
3. Cut 1 foot squares in the bedliner and then use a 4,000 psi or higher pressure washer.
4. Induction tool. Heats only the metal, the metal melts the bedliner, the bedliner peels out. But, it's not as easy as it sounds and it STINKS.
5. Liquid nitrogen. The liquid nitro at -350 degrees freezes the bedliner then you "break it up" with something.
Smokim is offline
post #10 of 13 (permalink) Old 09-12-2007, 03:00 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Smokim</div><div class="ubbcode-body">
5. Liquid nitrogen. The liquid nitro at -350 degrees freezes the bedliner then you "break it up" with something. </div></div>
not sure how it would work in this situation, but i have used it before to remove rubber sound deadning pieces from cars "factory type" Just go to baskin robins or local icecream store, and get some dried ice. lay it on there and let it freeze the liner, than hit it with a hammer, should break right out with no damage to the bed
-Chris
chrisreedtn is offline
post #11 of 13 (permalink) Old 09-12-2007, 08:28 PM
If it is already separating and flaking off you might be able to just use a good high power pressure washer.
Steve Urban
Semper Fi!
2007 F350, Lariat High Line, SRW, SC, LB, 4x4, 6.0/auto, FX4, Camper Pkg, HD alt, Red w/custom black two-tone, Buckstop bumpers F&R, Warn 16.5ti winch, Line-X, F550 coils, 305/70R18 ProComp XtremeMTs
2007 Apex9.5 truck camper
1973 Bronco (stock), wife's
1973 Bronco (HEAVILY modified), mine
2006 Mustang V6, Screaming Yellow, wife's
2006 F350, Amarillo, SRW, CC, 4x4, SB, 6.0/auto (traded)
2004 F350, SRW, CC, SB, Sport, 4x4, 6.0/auto (bought back by Ford)
SteveIn29 is offline
post #12 of 13 (permalink) Old 09-12-2007, 09:56 PM
A lot of hard work
Seriously though, you are going to have to use a grinder
LAJones is offline
post #13 of 13 (permalink) Old 09-13-2007, 12:10 AM
jeez that bedmat is cheap, id say just do that for a while it is just so so much less than a linex it might be worth it
FOR SALE
2002 F350 CCLB 4x4 Off Road
8" Donahoe Lift, Dual Bilstein 5150 Shocks frt singles in back, Skyjacker Dual Stabilizers, 37x13.50R17 Toyo M/T's on 17" MB Razors, 5" BH Stacks, DP Tuner, Tymar Intake (True Tymar), Autometer Phantom Boost and Trans & Banks Pyro,BTS Valve Body
razorscs is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
