HOW TO MAKE LOW BEAMS STAY ON WITH BRIGHTS!!! help wanted - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 07-06-2006, 03:27 AM Thread Starter
I know you can buy the wire loom to make your low beams to stay on with your high beams, but im already making a look for my new 06 headlights and since im already dealing with wiring, relays and shiz i wanted to wire them so i could have the low beams stay on.
Can anyone explain what i need to do.
Thankyou
NOSERVICE4YOU
Early 1999 PSD SC 4x4
Old user name: Noservice4you... it didnt sound welcoming.
Savageduty is offline
post #2 of 9 (permalink) Old 07-06-2006, 06:37 AM
haul_n_horses2's Avatar
My Photos: (17)
Re: HOW TO MAKE LOW BEAMS STAY ON WITH BRIGHTS!!! help wanted
Easiest way is to put a heavy duty wiring harness in to replace the OEM (I got mine from SUVLights.com) and put a diode between the high and low beam terminal in the unused socket.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #3 of 9 (permalink) Old 07-06-2006, 09:01 AM
Tallavana's Avatar
My Photos: (14)
go get a 12v 30/40amp relay.
86 goes to ground
30 goes to 12v with 30amp inline fuse
85 taps into high beam wire
87 taps into low beam wire
use the wire harness behind passenger headlight. I dont remember the wire colors. there are only three wires. one is ground, one is high and one is low. if you can build this relay, you can figure out which wire is which. you will need a ring terminal for the battery, a ring terminal for ground, four shielded relay terminals (they look like speaker terminals but the plastic covers the whole thing), a waterproof fuse holder, two t-taps and two shielded spade terminals( scotch-locks suck use t-taps). if you want to spend a couple extra dollars buy a relay harness. its nicer and you can do away with the relay terminals. you dont need a diode because a relay is a switch, when its off nothing will pass through it and when its on, you dont care about 12v back feeding (at least not in this application).
Light travels faster than sound. This is why some people appear bright until you hear them speak.
2002 F250 Lariat 4x4 Crewcab PSD Shadow Grey/Black
BD X-Monitor, BD Pressure-Loc, SCMT(80),AFE Magnum, 2.5"leveling and 4" block, Bilsteins, Retrax, LineX, Oilguard, MBRP 4" SS, Moto Metal 950 18x9, Toyo A/T 325/60/18, 05 front end w/Harleys, KC 05 light kit w/3 driving lights.
Tallavana is offline
post #4 of 9 (permalink) Old 07-06-2006, 07:55 PM
Send a message via AIM to Bobcat698
Thankyou
NOSERVICE4YOU
This isn't a good idea with the 2005+ headlights! The lenses will melt if you run both filaments for extended periods of time.
PURE DIESEL POWER
TS Performance chips, SCT, Edge Products, AFE, Superchips, Diablo, Autometer & Dipricol Gauges, Turbo Air Guides, MBRP & Magnaflow Exhaust, Aeroturbine, ATS, Hypertech, Steroid & 18K modules, South Bend Clutches & more!
Get STACKED with a 4,5,6, or 7 Inch STACK kit!
Call us for your exhaust pipe needs!
Superior Customer Service, FAST Shipping!
Garrett Shields
OWNER
715-254-1833
Bobcat698 is offline
post #5 of 9 (permalink) Old 07-06-2006, 11:18 PM
My Photos: (14)
I dont know how good it works but why not just buy a "Brite Box" from www.dieselsite.com
2000 F-350 Super Cab,Long Box,4x4,7.3L PSD, Bully Dog Chip,6 sp. LEVER ACTION, Camper Pkg.,200k,Lariat, Clearance lights, White on top,Gold on bottom,Gold interior. 285/75/16 BFG's, Dieselsite.com 203* T-stat, alum. T-stat neck and coolant filter kit with Fleetguard WF2077 filter added.
1993 F-250 Reg. Cab 4x4. XLT. 7.3L IDI, E4OD, 4.10 rear, Fleetguard WF2077 coolant filter. Born: 9/92, 163k, Lumbar bench with armrest. White on top, blue in middle, white on bottom. Clearance lights,DeeZee diamond plate running boards to back of cab. True dual exhausts with glasspacks and 4" stainless tips. Pretty well stock except for Pioneer CD player.
rossman is offline
post #6 of 9 (permalink) Old 07-07-2006, 08:33 AM
Tallavana's Avatar
My Photos: (14)
a bright box works great and is a quality product. They are $100 or you can biuld your own for $8.
post #7 of 9 (permalink) Old 07-07-2006, 02:51 PM
klhansen's Avatar
My Photos: (180)
Here's a PHOTO of where the diode would go. (Took this pic before I installed my diode). Used an old bulb base and soldered the diode leads to it. I have a non-doide plug (shown in the photo) and one with a diode so I could swap them as desired for hi-low together or separate in about the time it took to make this post.
), AIS,
regulated return,
klhansen is offline
post #8 of 9 (permalink) Old 07-07-2006, 06:09 PM
Man-o-man, I was looking for this info that Tallavana described above just last week! I did many a worthless search. I have a ready made "relay harness" and only needed the directions as to which wire went where. Since reading that the '05+ bulbs will melt the heck out of everything I have changed my mind. I guess a little info late is better than none never.
Gerald
'06 F350 XLT 6.0 Crewcab SRW,FX4,6 spd. manual, Arizona Biege Met. BONE stock except for appearance and convienience add-ons: Westin stainless nerf bars, Brown's welding grillguard, Billet grill, Speedliner spray-in, Protecta bedmat,Fumoto valve,Hide-A-Way gooseneck hitch,amber pinch weld lights, Husky floor liners, C-betr mirrors.
'03 6.0 Excursion 4X4 Limited (Wife's ride)stock 'cept for the Ranchhand bolt-on grillguard, 285/75/16's and Fumoto valve.
SOLD! '94F350,PSD,4x4,CC,straight pipe(I HATE CATS!!!),shimmed,ported snorkle,K&N filter,J.D. coolant eye,amzoil-tranny&trans.case,updated PCM.Pro-Comp 315/75/16A/T's,Pioneer cd player,Brite Box,LuK SMFW-LuK 13 clutch,4" Skyjacker lift.
Married so driver carries NO CASH!!!!!
hotcrazee is offline
post #9 of 9 (permalink) Old 07-09-2006, 01:31 AM
Tallavanna helped me do mine ( high beams and keeping the fog light on with high beams, same relay) and i have yet to melt anything, perhaps i am just lucky.
2005 F250 PSD Crew Cab
opie1knobe is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
