How to swap '05-'07 SuperDuty Front End to your '99-'04 - Page 2 - Diesel Forum - TheDieselStop.com
Old 07-06-2009, 12:03 AM   #16 (permalink)
Badazzharley's Avatar
Thanks for the great info. I am in the process of gathering all of the '05 parts. I do have one question. My truck does not have oem fog lights but am going to add them during the '05 conversion. Do I need the '05 - '07 style fogs or do you use '99 - '04 fogs? I have a lead on a pair of '05s with bulbs and brackets real cheap and assume these are the ones I need. But you know what they say about assuming. Thanks.
Badazzharley is offline
Old 07-06-2009, 05:32 PM   #17 (permalink)
Anyone? I' going to lose out on the lights if I don't buy them soon.
Old 07-07-2009, 10:55 AM   #18 (permalink)
take your chance
CPUMPER is offline
Old 07-07-2009, 11:14 AM   #19 (permalink)
LOOSEWHEEL's Avatar
You need the 05+ fog lamps. The lights are the same but the brackets are different.
2001 F350 CC SWB 6spd WHITE 8.5" on 37's. Currently getting a complete makeover......stay tuned.
Pics
'Everything is possible if you don't know what you are talking about'
LOOSEWHEEL is offline
Old 07-20-2009, 05:24 PM   #20 (permalink)
Conversion looks great! Question about re-using old bumper brackets from my 2002 F350, or what new brackets I'll need to buy to complete the conversion....
These are all the brackets that I can find that are listed for 2005-7 (each one has 1 drivers / 1 passengers side):
1) Description: BUMPER BRACKET, FRONT, PASSENGER SIDE -- A High Quality, Direct Fit OE Replacement Bumper Bracket, Plate Side Rail
2)Description: BUMPER BRACKET, PASSENGER SIDE -- A High Quality, Direct Fit OE Replacement For Bumper Bracket
3)Description: BUMPER FILLER -- A high quality, direct fit OE replacement bumper filler.
4)Description:BUMPER BRACKET, FRONT, PASSENGER SIDE -- A High Quality, Direct Fit OE Replacement For Bumper Bracket, Outer Mounting
Do I need to buy all of the above brackets for the conversion or can I reuse some of the existing brackets from my truck today? If so, do you know which ones? (Let me know if I'm missing any too)....
Thanks in advance... just need to grab the upper valence, chrome bumper and whatever brackets I'll need... have lights, harnesses and grill!
-Lamint
lamintdog is offline
Old 08-17-2009, 11:16 PM   #21 (permalink)
Will the '05 bumper bolt directly to 2000 without changing out grill and header panel? Or will I need new brackets?
jams28 is offline
Old 09-25-2009, 12:06 AM   #22 (permalink)
fairweatherfordfan's Avatar
If you are looking for a grille, lights, or pigtails, check out ebay I bought the 05-07 chrome grill $89.00 w/o ford logo, the lights for 113.00, and the pigtails for 19.99 these links are active sept 2009
bumper:
BUMPER CHROME ford TRUCK 05-06 front 2005 2006 part NEW:eBay Motors (item 370226563981 end time Aug-07-09 00:24:20 PDT)
Grille:
NEW CHROME GRILLE-MESH 05 06 07 FORD SUPERDUTY F350 :eBay Motors (item 390090819737 end time Sep-12-09 20:38:58 PDT)
lights
05-07 FORD F250 SET HEADLIGHT 06 LAMP NEW:eBay Motors (item 270452064863 end time Sep-14-09 11:12:32 PDT)
pigtails
H4 to 9008 Headlight Conversion Harness BEST QUALITY:eBay Motors (item 330353837517 end time Oct-19-09 15:58:13 PDT)
dont by from the dealer unless you want to pay $$$$$$$$$$$$$$
the aftermarkets are just as good quality
good luck
fairweatherfordfan is offline
Old 11-04-2009, 08:00 PM   #23 (permalink)
can you just upgrade the headlight assembly without changing to the new grill and bumper.
2003 F250 7.3 107000 miles
isspro trans pyro and boost guages
AE software
DP TUNER F5 w/ 80tow, 60econo, 100 perform,
drive thru tune, 1200 idle
John Wood valvebody
4" Mbrp exhaust
ATS ported housing, diy tymar
Riffraff FRX and HPX
jarheadman is offline
Old 11-09-2009, 09:20 PM   #24 (permalink)
01f250powerstroke's Avatar
hey
Originally Posted by CPUMPER View Post
Where Did you get the grill? I can't find stock like that other than the dealerships & they are in 400 $ range
You might try your local craigslist. www.craigslist.com That is where I got mine from and I got it for $75 in descent used condition. It took me awhile to find one but it saved alot of money compared to factory. There are also some on ebay that are pre cut to fit a 99-04 factory bumper. Hope that helps
01f250powerstroke is offline
Old 11-09-2009, 10:37 PM   #25 (permalink)
5Rvers's Avatar
My Photos: (10)
I have a 2000 F450 7.3 PSD and I would like to upgrade my towing mirrors with an 03-07 power signal mirrors. Is this doable without major modifications and if I can what is required? I'm assuming new wire harness is required. Appreciate any information.
Thanks in Advance,
Lou
2000 F450 7.3 PSD CC DRW
ISSPRO Gauges
50 Gallon Transfer Flow Tank
Firestone Ride-Rite Air Bags
2005-07 Front clip change
Ford Severe Duty AIS
DP-Tuner
Diamond Eye 4" Turbo Back Exhaust
5Rvers is offline
Old 11-10-2009, 03:17 PM   #26 (permalink)
Thanks in Advance,
Lou
I like the mirror idea too.
2003 Excursion XLT, PSD, 4X2. 167k miles. 18mpg in town. (4" intake and exhaust installed by po).
gager2002 is offline
Old 11-10-2009, 07:41 PM   #27 (permalink)
JimTJr's Avatar
My Photos: (20)
Thanks in Advance,
Lou
Yes it is, (You would have a better response with your OWN post though)
The new mirrors will BOLT right on. You'll need to do the wiring though. Nothing difficult really. (Plugs are not the same I doubt. (Yours are probably round, new ones are more rectangular. If yours are not round, they will be the same, you'll just need to add the wires for lights and heat. (Power will already be there) (I don't know what year they went from round to more square/rectangular, but it was before 03 I know for sure... my 03 didn't need changing.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 12-01-2009, 10:55 PM   #28 (permalink)
that's a great conversion!
skew12 is offline
Old 12-02-2009, 09:19 PM   #29 (permalink)
FORCED FED's Avatar
Great write-up and thanks for the pics! I have purchased a used grille already and plan on doing this to my 01 Excursion in the near future.
FORCED FED is offline
Old 02-01-2010, 05:05 PM   #30 (permalink)
Fairweatherfordfan, i was wondering if the grille you ordered off of eBay seemed to be good quality, If the chrome looks good or has started to peel or anything, I was wanting to do the same conversion but I just wasnt sure about the headlights and grille from ebay.
6.0Stroker is offline
