Hummer H2 rims on an F350? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 09-14-2005, 03:02 PM Thread Starter
Just as the title suggests... Will the H2 rims fit on an F350 like they will on a Chevy 2500HD? I am in dire need of a new set of rubber for the Ford and I really like the look of the H2 rims on a 2500HD. I believe there will be some modification to the wheels to enlarge the center hole so it would fit. Has anyone done this before or know what may be involved in doing this modification?
Thanks, Tim
moosecountry is offline
post #2 of 8 (permalink) Old 09-14-2005, 03:08 PM
Re: Hummer H2 rims on an F350?
H2's are 8 on 6.5" while '99 and up Superduty's are 8 on 170mm.
Basically the wheel lug pattern is different enough that they won't fit.
Snowtow is offline
post #3 of 8 (permalink) Old 09-14-2005, 03:29 PM
You're just not using a large enough hammer! [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Just kidding, in case you couldn't tell! [img]/ubbthreads/images/graemlins/grin.gif[/img]
Casey_1 is offline
post #4 of 8 (permalink) Old 09-14-2005, 08:11 PM Thread Starter
Ok, so what do I have to do to be able to run that size tires? Or what is the largest I can run without a lift? I liked the H2 tires and rims because due to the offset on the Chevy you do not need a lift.
Tim
post #5 of 8 (permalink) Old 09-15-2005, 12:12 AM
I believe the stock tire size on the h2's are 315/70/17. I have seen guys run 315's on stock rims without a lift, i dont know how well that would work, but i'm pretty sure they rub. 315/75/16 is a little narrow than the tire on the h2 but is just as tall. And they will fit on your stock rims, i would'nt recommend it but they will. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2001 F350 C/C 4x4 SRW, Superlift 10"/dual bilsteins, 39.5" IROK radials, Precision Gear 4.56's; Banks Turbo/wicked wheel, ATS housing, Banks Bighead Wastegate, Banks 4-stage 150hp chip, Banks turbo-back 4" exhaust, AFE stage 2 intake, zoodad mod, coolant filter, Autometer Procomp gauges;
BigSuperduty is offline
post #6 of 8 (permalink) Old 09-15-2005, 12:23 AM
305/70/16... (33x12.5)
00 F-250, SC, Lariat, 4x4, auto, PSD... Smokes a bit :-)
Pulls
282DC Stratos Bass Boat, JohnnyRude Intruder V6/Renegade 25p 4 blade SS prop... outruns most fish :-)
fast_fisherman is offline
post #7 of 8 (permalink) Old 09-15-2005, 11:11 PM
If you have a F350 or a F250 with V code springs you can run Hummer tires on 17x9 rims with only minor rubbing on the front lower valence. The key is 17x9 as anything wider rubs on the fender. My dad has this on his stock 2001. I put V codes on my X and will be doing the same thing.
2003 Excursion Limited-Clean canvas to start my work. V codes, Dukes of Hazzard horn, 35-12.5-17 Dick Cepek FCII on Weld Helos.
*Sold* 2001 Excursion Limited - August build date, no PMR here, Edge Evo, 4in DP back exhaust, Autometer Pyro/Boost/Tranny temp, Boost tube, AFE Stage 2, AIH delete, Sonnax/Tricumulator, V Code Front Springs, MX6 Shocks, DVD/VHS/N-64/TV on 2 LCDs.
*Sold* 99 SD CC SB SRW-Zoodad, Zener diode, boost tube, chipped guaged, dynomax cat back, Donahoe leveled, Bilstein, Procomp 35s, Fabtech Bumper, Yakima Load Warrior.
dnewman9 is offline
post #8 of 8 (permalink) Old 09-17-2005, 11:50 AM
I don't know what year your truck is, but check my sig. I run those tires w/mudflaps, I used big zip ties to pull the inner fenderwell back, no rub, and you can't tell I've rigged it unless you look really close. It has worked well for 9 months. BTW, Chebby rims on your Super Duty? That's blaspheme man!
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
torino73 is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
