I got an hid kit for $79! Here is my feedback... - Diesel Forum - TheDieselStop.com
Old 03-21-2009, 07:49 PM   #1 (permalink)
I forget my old sign in name and password (dr powerstroke or something). Sigh! Anyway. I told someone I would post after I installed my hid kit. I went with the 5000k 50w and am very happy! I got them from http://www.reedsoffroad.com/hidlights.html depending on what you want. Prices start at $79 w/lifetime warranty! It was plug&play. Easy install. Took me about 20min a side. But, that's because I couldn't decide where to put the ballasts. Any questions regarding this kit or the 6000k 35w I put on wife's Dodge Neon. Ask away. Anything else, I might not be able to help. Only the kits I put in please.
I moved the coupon code to my original post
code: forumcode15x ($15 off)
Coupon code no longer needed. They offer free shipping
Footnote: Before I get someone asking which is brighter...the 5000k 50w is
powerstroke7081 is offline
Old 03-21-2009, 10:18 PM   #2 (permalink)
goats's Avatar
I got my kits from vvme and I have no complants and they cost $66 shipped oh and your wifes neon u better put a relay harrnes kit on or u will be replacing the multifunction switch and plug cause the head lights have no relay so all the power goes threw to switch trust me cause I have a srt4 neon also
goats is offline
Old 03-21-2009, 10:22 PM   #3 (permalink)
We did the hi/lo so it has a replay with kit. The truck I just did lo beam. So, no replay.
Thanks for the tip though.
Old 03-29-2009, 10:57 PM   #4 (permalink)
Also, I got a coupon code for feature buys. Not sure how many times you can use it. But, here is it. Hid's only it says. $15 off! In case someone wants them too
code: forumcode15x
Wholesale JD Lighting TR Lighting Digital HID Kit $79! Car/Truck/Quad-Lifetime Warranty-
Old 03-31-2009, 05:45 PM   #5 (permalink)
Are they a lot brighter than stock? Do people flash their brights at you?
How well do the bixenons work? How well are the ones in your truck focused?
drewkeen is offline
Old 03-31-2009, 07:01 PM   #6 (permalink)
I have the 50w 5000k. At first. Yes. But, I adjusted the head light and not anymore. Wife has the 35w 6000k and she has never got flashed.
They work very well. I am the type "A" person who most business hate I want it right or forget it. These lights are great. I can see everything fine. 100% coverage.
The lm "brightness" is 4x that of a stock head light on 35w and 5x on a 50w.
Does that help?
Old 03-31-2009, 07:06 PM   #7 (permalink)
Sure did, thanks for the reply. I misread it and though the wife had the bixenons...I wonder how those work?
drewkeen is offline
Old 03-31-2009, 07:24 PM   #8 (permalink)
You read right. Wife does have those. Bi-Xenon is hi/lo beam. Works fine. Hi's are not brighter, just changes pitch. I just have the single beam. After, I did her's I didn't think it was worth the extra money since it's not brighter. So, I went with the single beam and saved the money.
Better?
Old 04-21-2009, 02:10 PM   #9 (permalink)
HID question
I installed bixenons in my truck and just installed HID projectors(H1) in my dads SD. Does anybody elses truck stumble or stall when they turn on theyre headlights, especially after just starting the truck?
2002 F350 Lariat CC LB DRW, dual alternators, adj pedals, dual power seats, 6" mitre cut stacks, dual ViAir 400C's going into a 5 gallon tank led to a set of 11 horns with 1/2" airlines and valves!,husky wood grain dash , Diesel Manor overhead console guage kit with ISSpro pyro and boost, G&W turn over goose neck, AFE Stage II, DP F5 chip, stock,40 tow,60 tow, 80 economy, 120 race, Recon smoked LED cab markers and LED smoked fender lights, HIDs, Lit up front to back(all LED), Husky S/S series flaps.
301 hp 597 ft/lb(but needs a tranny, HPOP and to be put on a real dyno)
LoweredKlass is offline
Old 04-21-2009, 02:16 PM   #10 (permalink)
Check the ground. Make sure you mounted it to metal.
Old 04-24-2009, 01:12 PM   #11 (permalink)
Rickie's Avatar
Hmmm. Not DOT Approved. What does that really mean, from a liability and/or legal point??
'00 F250 XLT 4x4 (born on 6/00), manual tranny & hubs, SPA Techniques EGT/Boost Gauge, Homemade HX Crossover Mod & Return Fuel Regulator, Toro Liner, 203* T-stat and Coolant Filter, LUK Clutch, flywheel & pressure plate, Amsoil Dual Bypass Filter
Rickie is offline
Old 04-24-2009, 06:29 PM   #12 (permalink)
No aftermarket HID's are dot approved. None are.
Old 04-27-2009, 01:12 PM   #13 (permalink)
Grounded straight to the batteries
Old 04-27-2009, 08:33 PM   #14 (permalink)
Just a question, do you know if they also sell per piece HID kit (as in only 1 piece and not a pair), because my passenger side headlight got busted when a stupid driver hit my truck. Thanks.
A/C Low Press. Switch
thomatt12 is offline
Old 09-27-2009, 02:06 AM   #15 (permalink)
I wanted a High Intensity Discharge kit which is a very cool light and better visibility especially during night driving. I opted to go with the single beam HID kit too and love it, they are cheaper on ebay but I wanted a warranty so I got it here. sealed beam conversion kits , or you can try one of the vendors.
crug75hid is offline
