I got an hid kit for $79! Here is my feedback... - Page 2 - Diesel Forum - TheDieselStop.com
Old 09-27-2009, 10:22 AM   #16 (permalink)
Ragdude's Avatar
HID's are the best thing since sliced bread if you ever drive at night. Street signs "pop" and much easier to read. Great!!!
Protect the 2nd Amendment!
It's the original homeland security act.
'96 F350,Dually,CC,5 spd.,stock.
'02 Excursion Limited, stock
B100 baby! Bring it home, to the American farmers!
Remember 9/11, and don't become complacent again
Ragdude is offline
Old 11-20-2009, 01:47 PM   #17 (permalink)
Does it make a difference if it's grounded to the battery or frame ???
dieselduke1 is offline
Old 11-21-2009, 08:13 AM   #18 (permalink)
JimTJr's Avatar
My Photos: (20)
What year trucks are you guys running these in? I have heard the 02-04 don't work as well with those housings. That the 05-07 housing works much better.
Are you afraid the housings will melt? Keep your eyes on them. That seemed to be a problem with the HID in the pre 05 trucks.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 11-22-2009, 11:52 PM   #19 (permalink)
Well, I sold the '04 avalanche and bought a '02 suburban. Needed the 3rd row. It also came with the 4x4 which was a plus.
Anyway. Someone asked if there was a difference in brightness from the '02 and the '04? Yes. The headlight is different. I bought both the HID kits from Wholesale Tread Racing Performance Hid Kit Exhaust Headlight Tail light CAT Back and more! so I can compare apples to apples. It's the lense. I think in '04 they went to a clear lense. If that makes sense.
As for the other comment. Your right HID is the new waive. Ride it! I think LED will come around in the near feature. Well see.
Regarding the comment if it will melt. I have a heat gun that measure the hid vs stock headlight. The hid is cooler! 149* stock and 89* hid. I have the photos.
powerstroke7081 is offline
Old 12-09-2009, 12:38 AM   #20 (permalink)
this is a great question.
skew12 is offline
Old 12-29-2009, 07:47 PM   #21 (permalink)
wpzone's Avatar
Can these kits also be used for the driving (fog) lights?
<ul>[*] 2006 F350 CC , SB, SRW, 4x4, 6.0, 3.73, auto, Innovative SCT, MBRP 4" turbo back, Commander Monitor, 2.5" leveling kit, bilstein 5100's, 325/65/18 Cooper STT's, 18x9 Ultra Predator wheels[*] SOLD 2004 F450 Tuscany Conversion [*] 2005 Weekend Warrior CL4005 [/list]
wpzone is offline
Old 12-29-2009, 09:08 PM   #22 (permalink)
Originally Posted by LoweredKlass View Post
I installed bixenons in my truck and just installed HID projectors(H1) in my dads SD. Does anybody elses truck stumble or stall when they turn on theyre headlights, especially after just starting the truck?
Try waiting about 4 minutes so the glow plugs cycle off and see if you have the same problem. If you don't then a bigger alternator will be needed. Test by putting a Digital VOM across the battery terminals.
"Not DOT Approved" = Not approved for Highway Use. Run at your own risk. Just gives the PD a reason for pulling you over.
I must admit that the OEM headlights are the worst I have ever seen on a vehicle.
2OOO F-250 4WD Crew Cab, 248,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator H2O Pump. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 01-09-2010, 08:59 PM   #23 (permalink)
I run 35 watt 4300K on Bosch fog lights pointed down so they don't blind anyone.
If you are running HIDs in stock lights designed for halogen bulbs while looking cool you are blinding the hell out of everyone.
If you didn't put projectors in so that they are contained and provide a cutoff as they should than OUCH.
I have to pull my headlights and heat them in the oven or with a heat gun to split the lens from the casing. Then you need to mount the projectors into the casing and build a cover for the bulb area that has some moisture resistance.
It is a lot of work but done right no PD will pull you over and question what you are doing. Done wrong and you are a target.
I have seen maybe 3 trucks out of say 1000 that have projectors while the 20 or so seen with HIDs are truly blinding people. Yeah it is easy to stick a kit into our trucks but it sure as hell is not responsible.
fun2drive is offline
Old 01-12-2010, 07:45 PM   #24 (permalink)
abjacq's Avatar
doyou know what bulb would go in the foglights?
2000 f350 crew cab short bed 2wd. Glowshift guages, magnaflow stainless exhaust, DP Tuner. paid 3,000 for the 245k miles it had. up to 260000......SOLD
1999 f250 ex cab short bed 4x4 K&N air filter DP Tuner (stock, 80 economy, 120 race, 140 aggressive, lope idle) 4in exhaust airbags autometer gauges built tranny 305k miles! -SOLD
1999 f250 ex cab short bed 4x4 350springs 170k built trans DP Tuner (stock, 60 tow, 80 econo, 140 aggressive) 4in banks exhuast glow shift guages 8ft boss plow
2003 f250 crew cab lariat 4x4 240k miles, 9'2'' BOSS V plow
2002 f250 crew cab lariat 4x4 355k miles, 8'2'' BOSS V plow
abjacq is offline
Old 01-12-2010, 10:41 PM   #25 (permalink)
I was looking at getting projector headlights so the HIDs would work fine with them right?
83 F250 4x4
Banks Turbo
99 F250 Black, Ext. cab LB, 6" lift, 37x14.50 Maxxis Creepy Crawlers, ranch hand front bumper, DP Tuner 60T 80E 140, k&n air intake, 4" straight exaust
IDI Dude is offline
Old 01-13-2010, 01:23 AM   #26 (permalink)
dwc032's Avatar
BLAH BLAH BLAH, dude you have no idea what you are talking about! I have had drop in HIDS from Retro Solutions for a while know. And I there is hnundreds of people on this forum that have the same. Also have three to four buddies that have the same.
If the Hids are aimed right they will not blind anyone. I never get flashed when my low beams are on. I think HIDS are one of the best mods you can do to our trucks.
Never shall I fail my comrades. I will always keep myself mentally alert, physically strong and morally straight, and I will shoulder more than my share of the task, whatever it may be. One hundred percent and then some.
dwc032 is offline
Old 01-13-2010, 08:39 AM   #27 (permalink)
Phil G.'s Avatar
I am adding as much stainless steel as possible to the back of my truck and keeping it as clean as possible just for those people behind me with HID kits.
I also power my left mirror out towards the left lane at night. It's interesting how fast most of these vehicles that blind you when you look in the mirror to chance lanes don't spend much time behind me before they pass......
http://philztruck.piczo.com/?cr=7 Updated February 2009!
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4.Viper VX790 Alarm/RS w/motion sensor, WD pillar Guages,Alpine W205 DVD head unit with Blackbird 2 GPS, and Parrot Handsfree Blueooth + 7" O/H Monitor,Sirius plug in receiver, Kenwood KAC-8492 720w 4ch Amp driving Infinity 6010CS 6.5" components up front and Infiniti Kappa 62.7i 6.5" 2-way in rear doors, Infinity 611a Class D mono amp driving 2- Kenwood W2509 10" subs in custom box Cobra night-watch w/ dual wilson 2000's, 100gal polished alum fuel tank, Reese 5th hitch, Anderson Tool aluminum TT hitch, Bremen full glass running boards, painted mirrors, grille, door handles,valence,wiper arms,RamMount laptop mount.
Phil G. is offline
Old 01-13-2010, 12:34 PM   #28 (permalink)
I put the bi (high/low) 50 watt 4300k lights in my '02 over a year ago - fantastic light output and no problems. I also installed 35 watters in my driving lamps - also no problems. (both on harnesses). Make sure you do it responsibly - mark on a wall or garage door where your regular low beams hit, then install the lights and adjust to the same point. Only been flashed once in the past year – by someone in a Miata or similar “roller skate” high car – but probably would have been anyway even with the stock lights.
The cutoff on the driving lamps is impressive - very bright up to 18" from the ground, then within one inch higher, nothing - nice and flat. These bulbs (#9145) come with a shield on the glass to prevent going higher and blinding people. I've seen people use the H10 bulb instead, but it doesn't have the shield and shouldn't be used.
Unless you NEVER do anything but city driving go with the bixenon bulbs so you don't lose the high beams. Although the light output doesn't change, the beam angle really does make them high beams.
Keep the color 5K or less for maximum lumens, and to keep you looking "factory".
fishy is offline
Old 01-13-2010, 05:42 PM   #29 (permalink)
dwc032's Avatar
Uh, ok. Whatever. Ive seen plenty of gay stainless steel on the back of our trucks and I dont get blinded from the reflection. Because, THEY ARE AIMED RIGHT!
dwc032 is offline
Old 01-13-2010, 09:06 PM   #30 (permalink)
dikkstarr's Avatar
9005s fit perfect
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline
