Jensen 9311ts in dash DVD player questions - Diesel Forum - TheDieselStop.com
Old 04-02-2008, 05:15 PM   #1 (permalink)
Has anyone purchased and installed this stereo. I saw it at Wally World and it is only like $340.00. Also I need to know how to bypass the e-brake switch to allow it play DVD's while driving. I know, I know, it's illegal, but then again so are alot of things I do. I have read a few reveiws that say it is a darn good unit, but I trust the info I find here well over some site that I have never heard of.
Thanks in advance.
2003 F-350-7.3L-AUTO TRANS-4WD-CREW CAB
4" MBRP COMPLETE EXHAUST
6637 NAPA AIR FILTER
1705 SUPERCHIPS TUNER
QUADZILLA COMMANDER
CUSTOM HEADACHE RACK
CUSTOM ACCESSORY SWITCHES
DAKOTA DIGITAL VOLT GAUGE ON STEERING COLUMN
JVC IN DASH DVD PLAYER
brindleboxer is offline
Old 04-02-2008, 08:59 PM   #2 (permalink)
Buckshot341's Avatar
My buddy got a Pioneer unit from best buy I believe and they installed it, with it being able to play and drive, but it also has a gps and what not in it too, it has all the bells and whistles. Not sure how to bypass the e brake thing though.
Its a work in progress: 2001 Ford F-250 7.3 Powerstroke 60,000 miles. Have big dreams for this truck. LT305/75R16 mickey thompson mtx, Sirius satelite radio, Muffler Delete with 6 inch tip at a 45 out the back. KC Slim Lite Off Road lights. Bumper Guard. 2 10" subs with Alpine deck. Garmin GPS. DP Tuner- No start, 1200 rpm hi idle, 60hp Tow, 80hp econ, 100 hp performance, 120 hp Race, 140 hp aggressive. Isspro white dial chrome bezel blue pointer Pyro, Boost, and Trans temp in 3 pod a pilar mount
Buckshot341 is offline
Old 04-05-2008, 11:28 PM   #3 (permalink)
Just ground the emergency brake wire on the back of the unit or run it to a toggle switch thats connected to ground.
2009 F-350 6.4 4X4 CC SRW King Ranch
2005 F-350 6.0 4X4 CC DRW King Ranch
2000 F-350 7.3 4X4 CC DRW Lariat LE
SPL2K is offline
Old 04-16-2008, 05:15 PM   #4 (permalink)
Harley Davidson F-350 FX4's Avatar
I would be leary of the Jensen. I had one in my last truck, it started really acting up after about 11 months. Now the gears are stripped out.
2003 F-350 Harley Davidson FX4, 6" suspension lift, 35" BFG All Terrains, 6.8 liter V10, Hypertech Power Programmer, Flowmaster 5" exhaust, American Racing Wheels, K&N Cold Air Intake
2000 Nissan Frontier, 2.4L, 5 speed manual, bone stock (daily driver)
Harley Davidson F-350 FX4 is offline
Old 04-17-2008, 05:23 PM   #5 (permalink)
I cannot find it from work, but I also read there is a hidden menu in the Jensen that allows you to by pass the e-brake thing. I am about to install another brand and I just connected the e brake wire to ground so I can do the nav and everything without stopping.
2002 F-250 Crew Cab Long bed 7.3 4x4. Edge w/attitude, Edge Evolution, Triple disk converter, whicked wheel, 203 t-stat, High pressure bypass, BTM, lifted sitting on 35's. Onboard Air, tank, train horns, air bags w/ controller. Custom 86gal AUX tank, Tonneau cover, Dual Din in-dash DVD/NAV.
02Boathauler is offline
Old 04-18-2008, 11:06 PM   #6 (permalink)
stout99's Avatar
My Photos: (5)
Not sure if it's the same model # but a guy I know got one from Crutchfield for about the same price and he had to hook the ebrake wire to a grounded switch to use it like he wanted to. The one he had required you to press the ebrake and release it several times (a sequence). I guess this is an attempt to keep us safe. He wired it to the ebrake and a hidden switch so he could appear legal but passengers could watch it while on the road.
early99 F-250SD Lariat, 4x4, 7.3 PSD, Banks Stinger(4"from turbo back, bighead wastegate actuator, guages, chip), Dieselsite Boots, LUK clutch, Moog balljoints, Leveling lift, Line-X bedliner, 285/75/16 BFG MT(E), Bilsteins, Dieselsite hpx hose, various beauty marks, In need of real tunes!!
stout99 is offline
Old 04-21-2008, 05:30 PM   #7 (permalink)
Appear legal? I know you are not supposed to watch them, but who is going to pull you over to check if it will play or not? The only way they would pull you was if it was on.
I guess you could try and B.S. the cop and say "look it only works with the brake."
I just tied mine to ground that way it always works. I know some of the NAV units you have to be stopped and have the e-brake pushed just to set an address. I like to be able to do so at a stop light if need be.
