Just put Bilsteins on with 2" leveling kit and WOW... now 35" or 37"s on my 05 F250 - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 06-17-2006, 07:21 PM Thread Starter
Location: Greatest nation on Earth! You don't like it...get out!
I just put the 2" leveling kit on, the Bilstein shocks and with my little stock 265's I measure 40.5" from the ground to the leading edge of the wheel well opening. Now I am looking at either BFG MT 35" or 37's on my stock F250 17" rims. I have F350 blocks in back and it measures 42.5" to the top on the wheel well opening. I think I have enough clearance but want to know what size tires you guys have on your stock 17" rims.
Those shocks really are nice. I just didn't believe what I read until I did it for my self.
Let me hear about your combo as close to this as you can.
'05 Shadow Grey F-250 XLT PSD CC 4x4 LB, Build Date 8/8/04, Lariat wheels w/BFG AT KO 315/70R17's, ID's extreme tunes, Livewire, Coolant filter, Muffler Delete, 5" Chrome tip (10 plus hp there alone), Fomoto Valve, Rotella T Syn 5W40, ZooDad Mod, F350 blocks in back, Fabtech leveling kit in front, Bilstein Shocks, 800+ Watt AMP, 2-12" Subs in custom enclosure behind rear seat, Tonneau cover, Line X, UNGO 2-way alarm with remote start & turbo saver, Garmin GPS, Escort radar detector, AIC and aux backup lights on added upfitter switches, electric trailer brake module...more to come soon.
SLAPS Member#139
'92 Mustang GT, Black on Black and FAR, FAR from stock
Shadow_Grey is offline
post #2 of 15 (permalink) Old 06-18-2006, 11:36 AM
NEVRNF's Avatar
Re: Just put Bilsteins on with 2" leveling kit and WOW... now 35" or 37"s on my 05 F250
35's will fit, but 37 i doubt. The BFG's do run a little small compared to some of the other tires. The last leveling kit i did cleared Toyo 35 with a slight rub but i believe the cause was the customers choice of rim ofset. 37 Toyo took 6" to clear without any rubbing.
Tony
01 F350 cc 7.3 with Lots of Xtras
99 F250 xcab 7.3
91 mustang 351 turbo roadracer
NEVRNF is offline
post #3 of 15 (permalink) Old 06-18-2006, 12:00 PM Thread Starter
You do realize I have an 05. I heard 35's will fit stock and since I raised the front 2 inches I figured 37's will fit as long as I don't flex the suspension to EXTREMES.
Let me know what you think.
SLAPS Member#139
post #4 of 15 (permalink) Old 06-18-2006, 12:52 PM
Hey man,
I am thinking the same as you on the tires. I had a 05 with a 6" lift and 37x13.50x20 toyo mt i ended up selling the lift to lower my truck some(long story) I put a leveling kit with my same 20" wheels and 35x12.50x20 nitto mud grapplers. side by side the 37 vs 35 there was little difference. If i would have known that i would have put the 37s on my truck with leveling kit and could have told you if they would fit. The 35" nittos cleared with absolutely no problem.
I now have a 06 with the same leveling kit and 35x13.50x20 pro comp x-terrains on the factory 20" wheels. Absolutly no clearing problems.
I think i would try the 37s if you are talking about the AT tires they measure around 36" anyway.
Check my pics out, you can see my truck with leveling kit and 35" bfg MT on factory wheels
Justin
2011 Sterling grey F250 crewcab fx4 lariat plus package 2" up front 2.5 rear lift 37x12.5x20 nitto trail grapple on factory wheels b&w hitch
2006 Red F350 crewcab FX4 4" skyjacker w/4.5" Donahoe springs 37x13.50x20 Kumho Road venture MT on Factory 20", DPPI exhaust,Edge w/ attitude, B&W turnover hitch
pic link
99BlackStroke is offline
post #5 of 15 (permalink) Old 06-18-2006, 11:37 PM
rednck21's Avatar
the 37's might clear on the factory wheels, but no way with aftermarket wheels. IMHO, little or no lift with huge tires looks funny to me.
2000 F-250, reg. cab, 4x4, XLT, 7.3, built 6/00-forged rods!, DP Tuner F5, AFE stg. 2, MBRP 4", Autometer Ultralight boost/pyro/trans temp gauges, 285 BFG's
2011 F-150, 2wd, XLT, Ecoboost
rednck21 is offline
post #6 of 15 (permalink) Old 06-19-2006, 02:03 AM
I hope you guys like reduced fuel economy and reduced performance because that is going to happen with big meats. There is always a price for good looks......unfortunately.
Larry
02 F250XLT SD CC LB 4X4, Silver, SD Air Lifts, 4R100, Westin Sportsman grill/brushguard, Leer Shell, AIS Severe Duty w/added fender intake, Edge EVO running 80 HP, ISSPRO's w/cubby mount, Rancho 9000X's, Banks 3 1/2" downpipe, BTM, 3 1/2" exhaust front to rear with 5" stainless tip. Sonnex and Tricum's. Fumoto Valve. Royal Purple ATF. Tru-Cool 4590. Tekonisha Prodigy. SP Diesel SSEBTC Exhaust Brake. Like new 88 Vacationeer 11.4' or 2008 Cardinal 31SB, 1992 Bayliner Trophy and the itch to go, baited hooks and the need to fish, loaded guns and the need to hunt.
Larry P is offline
post #7 of 15 (permalink) Old 06-19-2006, 09:49 AM
cmirabile's Avatar
My Photos: (9)
I have the Snow plow package, which raises the front 1"-2" So 37's will probably work for you. Check out my low quality pics to see if you like the way it fills out the wheel well. [img]/ubbthreads/images/graemlins/smile.gif[/img]
2005 F-350 XLT PowerStroke Diesel FX4
SCT Xcalibrator2 with Tunes from Innovative Diesel
37 X 12.5 BFG Mud Terrains
5% 3M Tinting
Viper 791XV with Remote Start
152dB Kleinn 3-Trumpet Horn System
Dakota Digital Gauges
T409 MBRP Straight Pipe
AFE Stage II Intake
HARPOONED Fuel Tank
2003 10 Vane Turbocharger
Blacked Out Harley-Davidson Edition Headlamps
ARP Head Studs
AVIC-Z2 In-Dash Navigation System
205cc Elite Sticks
Coolant Filter
Elite Regulated Return Fuel System
FS2500 Oil Filter
HPOP STC Replaced
cmirabile is offline
post #8 of 15 (permalink) Old 06-19-2006, 10:56 AM
Gonkey's Avatar
Go to www.rockymountsusp.com/gallery_ford.htm there is a guy on there with a red 05 sc xlt 4x4 with 2 in spacers and bfg 37x12.5r17 at ko on stock rims.
05 F250 XLT sport 4x4 SC SB 6.0 Auto
Gonkey is offline
post #9 of 15 (permalink) Old 06-19-2006, 02:50 PM
NEVRNF's Avatar
1st off FITTING and WORKING are 2 different things. I bet the first time you go into a parking lot at an angle on a street with a high crown and the ramp of the lot is steep you are going to realize the difference between the two. [img]/ubbthreads/images/graemlins/blush.gif[/img]
Ever seen a truck on an articulation ramp?
2nd the BFG a/t is only 36.3 verses most other 37 being 36.9 so a BFG might fit for a street driven truck.
3rd the rim is way undersized in width which is going to make the tire taller than spec but also narrower.I bet tread life is going to suffer dramatically.
I recently lifted a dually for a customer with 315/75/16. With only 10k on the truck the tires have worn 10/32 in the center already. It is what he wanted and he was willing to pay the price for poor tire mileage.
Tony
99 F250 xcab 7.3
NEVRNF is offline
post #10 of 15 (permalink) Old 06-19-2006, 06:59 PM
cmirabile's Avatar
My Photos: (9)
Not sure if that was directed at me, but I have had them on for 10-15K and haven't had any problems. I won't be going onto any articulation ramps anytime soon, too (I don't have a Jeep here) [img]/ubbthreads/images/graemlins/smile.gif[/img]. I do off roading, but if it was anthing real heavy, I would be getting a lift.
PS. Tread wear seems to be pretty even across the tire. Haven't lost much in this 15K. Although I have rotated an balanced 6 times already. Ask if you want pics [img]/ubbthreads/images/graemlins/grin.gif[/img].
post #11 of 15 (permalink) Old 06-19-2006, 08:00 PM
bigrpowr's Avatar
37's won't fit.
2000 F350 4x4 almost fast
12.27 @112.89
12.80 @ 114.48
727.7 hp (NOS)
bigrpowr is offline
post #12 of 15 (permalink) Old 06-20-2006, 06:51 AM Thread Starter
I'm leaning towards the 35's. I think I'll also go with an A/T tire instead of a M/T too.
Any ideas as to what brand might be better than others...
should I internet order and try to find someone local to mount or find a best price out the door deal locally???
What have your experiences been?
SLAPS Member#139
post #13 of 15 (permalink) Old 06-20-2006, 08:45 AM
NEVRNF's Avatar
PM me and i will talk to my tire guy. Let me know what tire and wheel and i can get you some prices.
Tony
99 F250 xcab 7.3
NEVRNF is offline
post #14 of 15 (permalink) Old 06-20-2006, 01:11 PM
OptimusStroke's Avatar
My Photos: (6)
When you say F350 blocks, I'll take it you mean the taller blocks. Perhaps that is something that changed in the new 05/06 SD.
That is a big misconception on this site that F350 blocks are taller(3.5") and the F250 blocks are shorter(2"). Up until about 03, you could choose what blocks your truck came with as an option. They were referred to as flat landers or haulers(2") and standards(3.5"). This intel is straight from the dealer I used in Co. I've known/used them since 1996.
As for tires, factory rims will fit taller/wider tires than aftermarket. Mostly due to wheel offset, but wheel width is also a consideration. Keep in mind, too narrow of a wheel will hurt your wear/mileage life and can even be dangerous due to improper bead/footprint.
I'm running 35 Toyo A/T's which are wider than normal(13.50). It is fine for traction since the truck is heavy, but I'd go back to standard 12.50 width given the choice. I'm running a 18" x 9.5" chrome aluminum A/R mohave wheel.
Trav
2000 F250,4X4,AFE2 w/PG7,F.A.S.S.,H2e,Spearco 6.0 CAC,Hybrids,Head Studs,FTVB,BD t/c,Fluidampr.
455hp/833tq, Fall Brawl 2007
Sailor for a time, a Patriot forever!
God bless our military forces and God bless America!
OptimusStroke is offline
post #15 of 15 (permalink) Old 06-21-2006, 07:20 PM Thread Starter
Trav,
Yes, I mean the taller 3.5" blocks. I have an '05 so there was no choice when getting a F250. With the leveling kit it sits ever so slightly raked, about 1" inch front to back. I am leaning towards 35's either MT's or AT's. Fuel mileage is no issue right now.
SLAPS Member#139
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
