Key pad on door dead, HELP! - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 09-14-2008, 09:15 PM Thread Starter
I have an 04 6.0 liter 4x4 long bed Ford. I have had the key pad replaced once by the dealer. They told me it was an aftermarket item and they would not replace it, yet I was able to prove it came from the factory, so they did. The concern is, it stopped working the other day and I want to know if I can get an after market one to replace it and how hard is it? The one I have is not inset into the door, rather it is raised up about 1/2". This is the reason the dealer thought it was after market. Does it have batteries that just died and thats why this has happened twice in 4 years or is it a bad product? Thanks for your help in advance.
2004 6.0 Liter F350 4x4 stock.
Always_Workin is offline
post #2 of 13 (permalink) Old 09-15-2008, 05:22 AM
IIRC, the aftermarket add-on does have a battery, as they were not nard wired in.
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
SOLD:2011 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Sterling Gray Metallic
SOLD:2005 F350 XLT 4x4 FX4 SRW SC SB 6.0 PSD/TS Med. Wedgewood Blue, Dual Alternators, Tow Command, Bypass Coolant filtration.
djousma is offline
post #3 of 13 (permalink) Old 09-15-2008, 08:52 AM
stevedunham's Avatar
My Photos: (6)
It's got a battery inside the size of a nickel. Mine also quit working several years back and I had to dissassemble the unit to get the battery replaced... Problem was, it never worked the same after that... I dicked around with it for awhile but never did get it working again... It's now an unfunctional ornament on my drivers side door...
** SMD '04 F250 6.0 CC King Ranch, '14 F350 6.7 Lariat CC **
Original engine grenaded @ 31,000 miles..! Replacement engine DIY bulletproofed, Gen 4 Injectors, 58V FICM, Blue Spring, IPR Remote Oil Cooler/Coolant Filter, ARP studs, DC Power 270 Amp Alt, BD billet H2O pump, CCV catch can, MBRP Duals, 2 blown Turbos currently running a Garrett, DR Edge 8.5" hybrid lift w/ 5" rear leafs, 37x13.5x17 Swamper M16's, Draw-Tite portable winch mount, WARN xD9000i, WARN Pocket Flares w/ Durabak, 4.56's w/ F&R ARB's, Dynatrac Dana 60 35 spline stubs, Powerslot Cryos/Hawk LTS, Yukon Hardcore 35 spline hubs, 2" wheel spacers,
stevedunham is offline
post #4 of 13 (permalink) Old 09-15-2008, 10:44 AM
ArchitectandBuilder's Avatar
As said, it does have a battery. I replaced mine a few months ago. The unit will start flashing and unlock-lock-unlock the doors (when you activate to unlock) to give a warning when the battery gets low.
The battery is a RayoVac BR2335 Lithium. I was not able to find the battery locally, so I ordered it on the net.
I have not had any issues with mine since I replace the battery.
Hope it helps.
Barrett
Mine: 2003.25 F-350 Lariat CC, SRW,8' bed, 6.0, Torqshift, Toreador Red, Tan Leather, Trailer Tow, Rhino-Liner, Dee-Zee Platinum Box, Adjustable Pedals, Heated Seats, 6 Disk Changer, DVD, 04 Keypad, AIC, 20% Tint, Escort 8500 X-50, Magellan Meridian Color Gps, BFG 285r17 KM2ís. DPPI Dual SS Turbo Back Exhaust,"X" Springs,Issopro EV Pyro,Trans,Boost,Oil Temp, Water Temp, Volt Meter, Air Press., Viair 550C AC, 26" & 29" Hadleys, 2006 Front End, Chrome Tow Hooks, Warn 16.5ti, Billet Cummins Killer Badges, Int. VT-365 Badges.
Diesel_Mom's: (Redhead): Goodbye 2001 EX, Thanks for 4 years. Brand Spanky New 2005 Eddie Bauer Excursion, DVD, Toreador Red</font> , 6.0L Powerstroke, all options including (3) children, (1) 95# Golden Retriever, Goodyear Wrangler 285 MTRs.
ArchitectandBuilder is offline
post #5 of 13 (permalink) Old 09-16-2008, 12:31 PM
My local dealer has them in the parts department. I am not sure of the price, but if it really interest you I could find out and maybe get you one.
2002 F-250 Crew Cab Long bed 7.3 4x4. Edge w/attitude, Edge Evolution, Triple disk converter, whicked wheel, 203 t-stat, High pressure bypass, BTM, lifted sitting on 35's. Onboard Air, tank, train horns, air bags w/ controller. Custom 86gal AUX tank, Tonneau cover, Dual Din in-dash DVD/NAV.
02Boathauler is offline
post #6 of 13 (permalink) Old 09-18-2008, 11:02 AM
How do you get to the battery?
2011 f350 Lariat
rampinator is offline
post #7 of 13 (permalink) Old 09-19-2008, 02:30 PM
You gently pry the cover off. There is a slot on the right hand side, you start there and gently move around it.
Barrett
post #8 of 13 (permalink) Old 09-20-2008, 01:51 AM
GAZ4x4's Avatar
My Photos: (17)
If you need to replace it, or if anyone that has remote control doorlocks and wants to add a keypad, they are also for sale on ebay. Just search for "ford door keypad".
Here is one example: eBay Motors: OEM FORD KEYLESS ENTRY DOOR KEY PAD F150 F250 F350 F450 (item 250297143862 end time Oct-18-08 18:20:56 PDT)
2005 F-250 CC/SB 4X4, 6.0L PSD-Torqueshift
med wedgewood blue,towcommand,upfitter switches
5"procomp lift with 5" Donahoe shocks and rear springs, 35"tires, 4.30 gears
BCP mod, LED taillights, 4"Banks exhaust, Harpooned fuel tank,
Accufab intake elbow, ARP Headstuds
Pioneer avic-D3 with backup cams and ipod
GAZ4x4 is offline
post #9 of 13 (permalink) Old 09-30-2008, 10:33 AM
rcd
The Ford part number is: 7L2Z14A626BA
They are fairly inexpensive, easy to install and easy to program.
2005 F350 CC Lariat FX4. B&W gooseneck w/Companion 5th wheel hitch. Reflex spray in liner. Husky splash guards, Husky floor liners, WeatherTech floorliners. B&W Stow & go.
rcd is offline
post #10 of 13 (permalink) Old 10-12-2008, 04:44 PM Thread Starter
So when you pry this off, you need to re glue it to the door? If you replace the battery, does it loose the code to open the doors? How do you reprogram the remotes?
post #11 of 13 (permalink) Old 10-12-2008, 08:14 PM
NYB
Very good questions. I'd like to know the answers too. Perhaps there is an instruction/installation manual/pdf file floating around on this website, or on the net that will answer these questions?
NYB is offline
post #12 of 13 (permalink) Old 10-14-2008, 10:36 AM
You just program your truck to accept the signal that it is putting out. I don't remember the process, but its just like programing the truck to accept a new remote.
post #13 of 13 (permalink) Old 10-16-2008, 09:16 AM
You do not pry it off, you pry it apart, replace the battery and put it back together.
Barrett
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
