Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 09-16-2008, 10:51 PM   #1 (permalink)
Led Replacements For Dash Lights
Anyone changed out there guage lights with leds? If so what did you you and how difficult was the installation?
2002 F250 (7.3) Garrett 38R Turbo, DP Tuner 80,120, & 140, ,Banks Monster Exhaust, Power Elbow, and Larger Downpipe. Auto Meter Carbon Fiber Gauges (pyro, Boost, Trans Temp, DP Tuner Guage), DIY 6637 Intake, Polished Intercooler Pipes, Donahoe 4.5 Edge Lift, Donahoe Twin Shocks on front and Donahoe Signature Series on rear, Skyjacker Adjustable Track Bar, Eagle Alloy 16x10 wheels, 315-75/16 Dick Cepek FC II Radials, Harley Davidson Chrome Tow Hooks, 2008 Ford SD Polished Rear Differential Cover, Polished Dual Steering Stabilizers, Aluminum Gas Cap Cover, Catch All Floor Mats, Diamond Cut Parking Lights, Billet Antenna.
RBMotorsports is offline
Old 09-16-2008, 11:52 PM   #2 (permalink)
Buckshot341's Avatar
I have seen it done, I believe a member on here did it, he has got a website and everything with some details, I looked through my favorites thought I had it bookmarked but couldnt find it... Anyways I emailed him and talked to him about it, he said how much work do you wanna do and how long do you feel like having your truck down. He did the blue leds and had to put in resistors and such to get it to operate correctly, he said after a while they started going white, and if he had to do it again he wouldnt... I liked the looks of it looks awesome with blue leds everywhere
Its a work in progress: 2001 Ford F-250 7.3 Powerstroke 60,000 miles. Have big dreams for this truck. LT305/75R16 mickey thompson mtx, Sirius satelite radio, Muffler Delete with 6 inch tip at a 45 out the back. KC Slim Lite Off Road lights. Bumper Guard. 2 10" subs with Alpine deck. Garmin GPS. DP Tuner- No start, 1200 rpm hi idle, 60hp Tow, 80hp econ, 100 hp performance, 120 hp Race, 140 hp aggressive. Isspro white dial chrome bezel blue pointer Pyro, Boost, and Trans temp in 3 pod a pilar mount
Buckshot341 is offline
Old 09-21-2008, 03:59 PM   #3 (permalink)
I did it to mine...it wasn't down at all. I have changed my window switches and all the dash lights except for the instrument cluster. I am still trying to figure out how to do that as the ones that I have seen done simply painted the cluser blue as it is a green tinted plastic doing the color change. My LEDs have not chaged to white...its not possible for an LED to change its color. You are gonna be looking for 3mm leds in whatever color you want.
2002 Quad Cab/ Short bed/ Auto/ Volant intake/ DI 6 Pos. chip/ DI boost relief valve/ 4in DP no muff all the way back/ Bob's IC boots/ Bob's A/C bypass valve/ Bob's coolant filter/ 3 Yellow Tops Optimas under the hood/ Vision X HID's/ Focal Utopia components and subs powered by Macintosh and Audison amps/ Switched GP's/ And a Really big wish list!
pilot4life is offline
Old 09-22-2008, 12:33 AM   #4 (permalink)
westvandude's Avatar
I'm not sure if the dash bulbs are 194's or not, but you need to find the exact bulb replacement #, then check out ebay for them (194's in this case listed) New and used LED 194, Parts Accessories, Car Electronics on eBay.ca prob come in all kinds of colours.
2001 F250 4x4 crew lariat 7.3L auto, clear corners & taillights, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, PI Stallion converter, modded valve body, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Walker 21470 BTM muffler, dieselsite boots & coolant filter & HX crossover, Fleetguard LF9027 or LF3630 hi-cap oil filter, Rotella T 15w40, DIY Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck.
westvandude is online now
Old 09-23-2008, 10:21 PM   #5 (permalink)
klhansen's Avatar
My Photos: (92)
That would be FordForgotton. Daryl has all kinds of tricks up his sleeve.
Here's the pics of his LED dash. Superduty Dash Disection
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 09-23-2008, 10:49 PM   #6 (permalink)
chuckster57's Avatar
I LIKE it.. If I thought I had enough time and electronic abilities I might try it. It would match my paint scheme
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually,
1997 Jayco fifth wheel 323 RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction, Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
Train Horns: Pictures here
chuckster57 is online now
Old 09-24-2008, 10:53 AM   #7 (permalink)
Send a message via AIM to ritschner
Try this sight, they have a large selection of LEDs and holders for a reasonable price. SUPER BRIGHT LEDS home
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, Reese 20K Hitch, CondensorGuard, IntakeMod, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, CAC Tube Restrainer, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
Old 10-09-2008, 10:20 PM   #8 (permalink)
Cool upgradeing dash
ok this is what i got 02 f250 4x4 3in lift 315 tires now my question is i have the base mode dash if i bought a top model dash that has boost and pyro would it be able to just plug and play or would there be some rewirering to be done sensors to install that sort of thing i plan to add gages but would like both as a nice up grade any way thanks for the help
KTM357 is offline
Old 10-13-2008, 06:37 PM   #9 (permalink)
autolumination.com has a vast variety of LED's. I just bought some front blinkers and runners and also a cool festoon interior bulb. Kind of pricey but well worth it.
01 F250 EC LB PS: DP-tuner 80-100-120, pricol gauges, tymar, zoodad, fuel pressure shim kit, 4in turbo back,hpx, AIH delete, 203* thremo & billet neck, Home brew bio, 4 in lift with 35' mudders
baroy68 is offline
