lifts - front axle placement - Diesel Forum - TheDieselStop.com
Old 11-02-2009, 09:40 PM   #1 (permalink)
Banned
Do any of the off-the-shelf lifts for 99-03 4X4 SDs move the front axle forward? I would like to fit slightly larger tires, but I dont want to hack up the body at the rear of the front fender to make 'em fit. There's so little fender between the tire opening and the forward edge of the door....
Anyone done a custom spring swap to move the axle forward an inch or two? Whats the limit, without pitman arm and steering linkage problems?
Alabamatoy is offline
Old 11-04-2009, 07:19 PM   #2 (permalink)
Never heard of it, sounds like a bunch of custom fabrication. Try getting a higher lift, or else you will be in a world of custom work.
New: 2002 F-350 7.3l Crew Cab, 175k, LB, SRW, Veggiestroke system
Old: 2002 F-350 7.3L Crew Cab, 245k, LB, SRW, DR 4.5" Hanger Drop Lift, Dual-Front Bilstein 5100 shocks, New Trac Bar, 20" Diamo 17k wheels wrapped with 35" Nitto Mud Grapplers, Veggiestroke system, cap with surfboard racks
no_regrets is offline
Old 11-05-2009, 10:27 AM   #3 (permalink)
Feedback Score: 3 reviews
I've never see a reason to need the axle moved forward..what size lift-tires you looking at?
Cary
caryt is online now
Old 11-07-2009, 10:24 PM   #4 (permalink)
IIRC, Icon Vehicle Dynamics(used to be Donahoe) does. Check with them on the suspension(lift) you're considering. I think it's an inch on the 8" suspension that I have on the '03. No chance it will get in to the fender.
'03 F350, 7.3 W/BTS Trans, Silver, XLT, CC, LB, MBRP 4" 304SS, 8" Edge Lift W/7100 Bilsteins, DR Dual Steering Stabilizer, 355/65R18 Nittos on 18x10 Weld Sidewinders, ARE Z-Series Topper, 4 Isspro EV's Hangin' From The Windshield, 12 Strobes Just For Fun
'02 F350, 7.3 W/Auto, Prairie Tan, XLT, CC, LB, MBRP 4" Alumunized, Purchased W/ 97,000 miles Purchased 8/09 STOLEN 7/25/2010 RECOVERED 7/28/2010 Thank You Indpls PD
Silver_Crew is offline
Old 11-09-2009, 01:38 AM   #5 (permalink)
BubbaZ71Tahoe's Avatar
you could run a zero rate or re-drill the perches to move the axle foward...
alcan spring can make you custom leafs that can will push the axle foward
2002 f250 ecsb 7.3,4r100 triple disc converter shift kit, amsoil atf, 60/10.5 DIY Tymar, (ISSPROboost, trans, Egt) PHP FU.
AutoEnginuity in the Lafayette-Houma area
BubbaZ71Tahoe is offline
