Load range E tires - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 02-04-2006, 02:48 PM Thread Starter
Load range E tires
Who is running what for load range E tires? Looking for something in the 295-305 size range, for 16 inch rim. Run 75% highway the rest offroad, lot of snowy/icy roads. Towing a 27' enclosed snowmobile trailer with camper on.
rdr99 is offline
post #2 of 12 (permalink) Old 02-04-2006, 03:21 PM
Re: Load range E tires
On my '99 I run 305/70/16E Toyo open country At's. Excellent all-around tire, plus they have a 50K treadlife warranty.
2005 F-350 CC 4x4 6.0L, Lariat bolt-action. 2.5" Leveling kit, 35*12.50*18 Toyo M/T's, Reflex spray in bedliner. Dieselsite Coolant filter. B&W turnover ball, B&W Companion fifth wheel hitch. MBRP 409 Duals.
Towed vehicle: 2006 Raptor 3712TS toyhauler fiver.(Holy Cow this thing is heavy!)
BigGreenDiesel is offline
post #3 of 12 (permalink) Old 02-04-2006, 05:01 PM
Heard a rumor (I think it was on this site) that BFG is now offering the AT in a LR E. I'll believe it when I buy my next set of tires. Cant wait for that time to come. Agonizing once again over the advantages between Michelline LTX and the BFG AT's.
2002 PSD 350 CC 4x4; AIS Intake w/ Fender Sleeve; Walker BTM; ISSPRO Tranny, Boost, Pyro; CCV Mod; Zoodad; Blue CPS(in the glovebox); Powerslot Rotors w/ Hawk Pads; Baldwin Fuel Filter; LineX Bedliner; Southwest Fabricators Rear Bumper; 285 Michelline LTX M/S's; and a cracked windshield.
92 8' Six-Pac Slide in Camper;
94 Charmac 3 Horse Slant Bumper Pull;
25' 1976 Jayco TT;
nvcowboy is offline
post #4 of 12 (permalink) Old 02-04-2006, 07:48 PM
BFG 285/75/16E's are out, saw them at Costco.
I have the Toyo 305E's. Personally, I would not use them on icy roads. Narrower is better. Normally I use a Mastercraft siped/studded 265E tire in the winter, they are awesome. Ten times better than my studded BFG Trac Edges were. I did not get them on this year and the 305's have been very skiddish comparatively.
2013 F350 CC Lariat 4x4 6.7L
2003 F250 SC Lariat FX4 6L sold
AK6LPSD is offline
post #5 of 12 (permalink) Old 02-04-2006, 09:10 PM
So far I think the only one smart enough to finally get the hint that we want a 35 in. 10 ply for our trucks is Toyo. Brother finally got his off backorder for his 350 CC with 9.5 ft Flatbed and can haul a decent load of wood now. Maybe with the sucess of the Toyo M/T other tire Companies will follow suit.
2003 F350 SuperDuty CC Lariat SB Torqueshift,Front leveling kit, 285/75/16 Toyo MT's,Eagle Alloys,AFE Magnumforce,ITP Muffler Delete, Leer Canopy.
1979 F250 4x4 Built 400 4 speed 4 in.lift
2000 Weekend Warrior 26ft Toybox
2004 Yamaha V-Star 1100 Classic
bikerforchrist is offline
post #6 of 12 (permalink) Old 02-04-2006, 09:37 PM
nitto terra graplers are lr E in a 305
2000 drw psd, 18k mod homemade tymer intake,dp tuner 40 hp ecu 255/85/16 truxus m/t
bansheetroy is offline
post #7 of 12 (permalink) Old 02-04-2006, 10:54 PM
I would have to agree on the TOYO Open Country AT's they are quiet, nice riding, and the tread siping goes all the way through the lugs so as your tire wears down you don't lose the siping as you do on other tire brands. I also pull a four place fully enclosed snowmobile trailer in the winter and a 5'er in the summer. I looked at a lot of tires and the TOYOs' won out for me. Hope this helps. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2001 F-250 CC shortbed 4x4 3.73 Ls,MBRP 4" 409 SS, AFE stage 1,Garrett GTP38R,DI's regulated fuel return,Dieselsites' 203* thermostat and Billet housing,AC heater bypass kit,CCV Mod,Fumoto drain valve. AIH delete, Zoodad,Autometer Ultra lite boost, trans, and pyro,<font color="red"> Jody Tipton 120hp tune,</font> Sonnax kit,air pressure regulator in MAP line set at 22psi.1987 Mustang LX 466 cui big block 621 hp 9" rearend spooled and disk brakes,etc....$$$$$$
04xcsp is offline
post #8 of 12 (permalink) Old 02-06-2006, 02:15 PM
I too am running The Toyo AT's. I believe they're rated at 3550lbs at65psi. Don't have my truck at work today so I can't run out and look. I normally run them at 55psi front and 50psi rear. I'm getting good wear and not too bad a ride.
01F350 CC 4WD 6SPD Arrow Canopy, 305/70/16's on 16"X8"wheels, HX mod, IAH plug, AFE Stage I w/pro guard 7 filter and overcoat. Evo tuner, WW, 4"exhaust,zoodad, Amsoil, Isspro gauges, GOS headlight harness,coolant filter
Endowment Member NRA
01crewcabtg is offline
post #9 of 12 (permalink) Old 02-07-2006, 01:50 AM
I will have to second with banshee, if you want the E range tire in the 305 the only one I found is the Nitto Terra Grapplers. I have em and love em. A lot of others have the higher weight rating, but the sidewall does not meet the E range ratings specs and therefore only fall in the D range. That is why I went with them and have no complaints in the snow and ice up in Truckee Donner Tahoe area. They are quiet and have had them for 34k and expect about another 5-7k before I have to replace. I even tow a 30' TT and love them. FWIW.
IN MY DRIVEWAY:
04 4X Excursion 6.0 Black,Limited, everything except 2nd row captains & chrome tubes, XD Revolver 17 Matte Black wheels, 315/12.50/17 Toyo MT, 4" ProComp leafs front, 04 B-Codes with 5 1/2" tapered block in rear, 30mm rear sway bar, Billet badges & fuel door, Superduty Harley Grille, C'Btr mirrors
05 Fleetwood Prowler 300BHS Travel Trailer, Reese WDH with dual cam sway control
80 Pontiac T/A Turbo
rechinca is offline
post #10 of 12 (permalink) Old 02-07-2006, 04:56 AM
Toyo 305's are E and BFG has a 285E.
AK6LPSD is offline
post #11 of 12 (permalink) Old 02-07-2006, 01:24 PM Thread Starter
How do the Toyos' handle off-road? Anyone tried the Trailcutters?
rdr99 is offline
post #12 of 12 (permalink) Old 02-07-2006, 04:17 PM
I have the AT's, new tread was about equal to BFG AT's. Nothing radical offroad, just a few trails to my favorite fishing holes in AK and sandy muck of central FL. In all, I think I only needed 4 wheel drive once. The Toyo rubber is a little softer compound so pavement grip is better but wear is a little faster. Highway noise was suprisingly quiet for the size.
AK6LPSD is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
