Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 11-06-2009, 03:04 PM   #1 (permalink)
Question Long term Ambitions F350 Dually
I have an F350 Dually Crew Cab Long Bed that I am planning to customize. It's paid for, it sits in the garage, and I hardly ever drive it.
Here's what I want to do, first lower it 3-4 inches, second, performance brakes, slotted and/or cross drilled, new calipers, etc. Probably cap it, and a body kit, but still want to maintain the towing capability for my horse trailer, so the spring rates need to be the same or better(possibly air bag it).
Here's what my problem is, where the heck to find the parts to do it? I want to start putting together a budget for it, to know what I need to save up, and time frames needed and any work that needs to be done that isn't bolt on ready. I also want to fix the rusting oil pan without pulling the motor if possible, maybe POR15?
Lastly, has anyone replaced their dual wheels in the back with a wide rim/tire like those on some OTR trucks? If not, then are there wheel caps other than stock to cover up the lugs?
I may replace the door handles with Polished Aluminum ones, or go crazy and just shave the doors. Right now the truck is Tourmaline in color, and I am thinking that I don't want to change the color, but enhance it, get rid of the lower Prairie Tan paint, and go with a color very close to Tourmaline, but with a bit of Chromaline mixed in to deepen the blue/green angles. If you dont know, Tourmaline tends to look green under one light, and blue under another, with shades of blue/green at an angle. This I plan to keep but make it stand out a bit more, and plan on a graphic of some sort, maybe some ghost flames coming from the front, or a flare that comes off the front wheels and rides up the door to the ridge below the windows that runs all the way back to the tailgate, in a pearl over the Tourmaline base. Ambitious, I know, but I have access to a paint booth.
Reason I want to lower is I really don't need it as high up as it is, my garage door is 8' tall and the truck barely clears it, and the topper I want to put on will not clear the door as it sits now. It's 4x4, but I don't take it off road, only use it in snow, so lowering it wont be a problem for my use.
I am also thinking of some hood scoops on the side of the hood where the airbox is located and another one on the opposite side, and make them functional with a duct to run from one to the other and exit at the filter for fresh air intake. I have an AEM filter kit installed already. My other project will be getting the trans rebuilt, maybe attack that myself if I can find all the hard parts that need to be upgraded, unless Brian is still in business and I can afford it.
DD 2010 Ford Fusion Sport
relegated to garage duty
U.S.N. Paradise BB91904
'99 F350 CC LWB DRW
Mods, SuperHyper Improbability drive stage II.
Hypermax 5" turbo back system, triple pillar guages, Heater core shutoff. AEM Brute Force intake. 3.73 gearing. DP PCM with 80HP Installed!
ACD2 is offline
Old 11-07-2009, 09:28 AM   #2 (permalink)
dlblazer's Avatar
As long as theres metal left, POR15 is a good solution to the oil pan.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
dlblazer is offline
Old 11-07-2009, 09:39 AM   #3 (permalink)
Steve250's Avatar
Pics???
'92 F-250 7.3 IDI Diesel 4:10 (99k) 4x4 ext cab (Prodigy brake controller)
'98 Ranger 4x4 ext cab - wheelin' in the mud
John Deere 510D Backhoe - it's not a ford, but it's nice
Steve250 is offline
Old 11-07-2009, 10:13 AM   #4 (permalink)
Supporting Member
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Cool Not lowered but....
Here's what I did to mine so far.....
Pictures by powerstrokeconverters - Photobucket
Adrian
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
Wicked Wheel
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using SCT 100hp Performance tune.
Wastegate disconnected for now...
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Camera,DVD,Nav.,Satelite Music.
Jason smooth topper.
Here but not installed: 4'' Ported Housing,ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.,TRU Cool tranny cooler (no time )
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 11-09-2009, 09:43 AM   #5 (permalink)
That may be my first project! There is metal left, at least right now there it, and I HOPE it wont rust anymore while in the garage.
I found a pic of one to get some idea what I am looking for, just not with the massive wheels.
My father in law has a car just like the one in the back, but in blue.
'99 F350 CC LWB DRW
ACD2 is offline
Old 11-09-2009, 12:29 PM   #6 (permalink)
BlazinTimes's Avatar
Nice!
BlazinTimes is offline
Old 11-09-2009, 01:02 PM   #7 (permalink)
I don't care much for the wheels though, the thin tires are scary, that much weight on thin sidewalls on rough roads spells disaster in the making. I want to keep stock tire size, maybe change out the rims if I cant restore the factory ones finish. I dont care too much for the huge gap between the tire and fenders.
OTOH I don't want the tires up inside the wheel wells or the body sitting on the ground. The one I posted above it just about right, so if I can find a kit that will give me that height, that's what I am looking for.
'99 F350 CC LWB DRW
ACD2 is offline
Old 11-09-2009, 04:18 PM   #8 (permalink)
Check my photos lowerd 2 in the front 5 in the rear. ride is very good , also did rancho adj shocks .
2001 2wd CC Drw , 22.5 ALCOA CUT DOWN TO 22INCH ON 305/45/22 ,3inch mini tubs in rear, Lowered 1in ft & 4in rear , Roll&Lock bed cover, Rancho shocks ,air bags in rear, AFE filter, Jody Tipton flip chip ,IDM Mod,Hx Mod, CCv Mod, BB turbo,non EVB housing, Pre-pumptank mod, JNB Reg fuel system , Autometer gauges,Hughes tranny pan , John Woods trans,6.0 converter , 4in dyna flow muffler, 3.5 downpipe, Code alarm,Alpine cd-dvd, Alpine DVD changer,2 Mmats 12in subs in custom box ,2 ALPINE 1000 watt digital amp, 2 150 watt alpine dital amp , Dynaudio mids & highs,Alpine Headrest monitors, rearveiw mirror monitor, Back up camera,Suade headliner, Clear Cab lights, Train horn, PMT2. 08 FT END , 08 Tailgate & bumper , 08 Mirrors ,
Photos
http://community.webshots.com/user/damiangt
DamianT is offline
Old 11-09-2009, 04:26 PM   #9 (permalink)
Nice, what did you use to lower it with? Mine is 4x4 though, so that might make it tricky.
'99 F350 CC LWB DRW
ACD2 is offline
Old 11-09-2009, 04:31 PM   #10 (permalink)
Springs in the ft and shakles and hangers in the rear but it's 2wd , not sure how to lower a 4wd .
Photos
DamianT is offline
Old 11-09-2009, 04:56 PM   #11 (permalink)
ACD2, as an aside, if your garage door is the standard residential garage door, have you checked into getting a 12 inch radius rail instead of the standard 18 inch radius? I put them on my lake house garage to get maximum height for the garage door because of the back rail on the pontoon boat, and the garage door is up, out of the way, and I have my full 9 feet header height (garage has 10 foot walls).
Just a thought, if you're lowering the truck because of the garage door height.
The rest of the project sounds pretty awesome (although I'm not a big fan of lowering trucks. I've seen a 1/2 ton cheby around here that was lowered so low that there are certain railroad tracks that the owner can't cross).
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
