Low Beams & High Beam Simultaneously - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 02-13-2010, 11:45 PM Thread Starter
cut7's Avatar
Some time ago, I read on this site that there was a company making a harness that allowed the low beams to stay on when the high beams are on. Does anyone know anything about this company? Contact info?
Thanks,
Tom
2006 F-250 CC 4WD King Ranch
2005 Excursion 4WD
cut7 is offline
post #2 of 18 (permalink) Old 02-13-2010, 11:57 PM
TxFireman1972's Avatar
called a brite box:
Innova Design & Distributing, Inc. - The Brite Box, Bulbzilla / Fogzilla, Diesel Turbo Lifesaver, Eclipse Sun Shade
2005 F350 Crew Cab 4x4
PMF 08 Rear Leaf Spring Conversion
20" Harley Wheels w/275/65/20 Nitto Terra Grapplers
SCT X3 w/GearHead Tunes
Amp Research Steps, Bed Rug, Hellwig Rear Swaybar
Truck pic:
"Two in the heart, and one in the head, I don't like repeat offenders, I like dead offenders!" -- Ted Nugent
TxFireman1972 is offline
post #3 of 18 (permalink) Old 02-14-2010, 12:14 AM
jacksonbend's Avatar
This place is $94
Brite Box - TruckCustomizers.com
'03 F350 CCSB 27k
6spd,4x4floor
285/75/16 +2"front
RCD EGR Delete,AEM Intake
Sold:
'06 F350 CCSB 87K
6spd 4x4manual hubs
6"Fabtech w/35"s
'01 Stroke CCSB 112k 6spd
5" lift, 35" tires 4" straight
NAPA 6637 Intake, Wicked Wheel
TS T6 Pyro/Boost Gauges
AIH/EBPV Delete
2005 6.0, 2001 7.3, 2-'99 7.3, '97,'95,'92IDI, 3-Cummins
jacksonbend is offline
post #4 of 18 (permalink) Old 02-14-2010, 04:38 AM
My Photos: (35)
There is that, then there is a fuse and a relay wired in so that when high beams go on the relay puts power to the low beams .. Have had this set up on my 96 gasser E350 and moved it over to the 7.3 00 E350 back in 03.... still working today..
2000 E350 7.3PSD, Hellwig Stablizer bar, 1.5"spacers from old Correct track OR,140 Lightforce with covers, 5x7 LED's From Truck-lite, extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E, My Photos
"FAILURE IS NOT AN OPTION"
It riles them to believe
that you perceive
the web they weave
And keep on thinking free
Alaskapsdvan is offline
post #5 of 18 (permalink) Old 02-14-2010, 08:17 AM
CriticalRick's Avatar
Hey AKPSD, this relay fuse setup is some DIY brite box? I've been thinking of making one but never got aroud to it. $90 seems like a lot for a relay and a switch.
2000 CC/SB 4x4, MBRP stainless 4", Aero Turbine muffler, HPX, CCV, 6637, Edge Evolution, AutoMeter gauges, 2009 mirrors, 17.5 MPG!
CriticalRick is offline
post #6 of 18 (permalink) Old 02-14-2010, 02:19 PM
My Photos: (35)
An Auto parts store here that is no longer in business had this bright box type thing.. relay and fuse as a kit... after looking at it for awhile I figured out how to use the relay that I had from a extra driving light set up from my old caddy and well.... the rest is history.
That kit might still be out there some place , a number of years ago that kit was only about 35.00, it still might be close to that price.. For the life of me I can not remember the name of it or the company that did it.
If one looks at the wiring for the headlights there is the com, hot for low and the hot for high. When going to high the power is changed from low to high, the box or relay puts power to the lows along with power to the highs.
Any of this should be done with care...
With the newer head light setups today this may not work like it did years ago.
that you perceive
the web they weave
post #7 of 18 (permalink) Old 02-15-2010, 10:04 AM
Feedback Score: 3 reviews
Do not use any kit on a '05 up truck to allow both lows and highs!!!
The The H13 blubs used on these trucks are quite possibly the stupidest design for a bulb ever foisted on the public.
The terminals are so small that they overheat, even at stock wattages, and melt the plastic
housing of the connectors. Higher than stock wattage bulbs are offered, but not recommended
and no harness will fix the problem of to small of terminals.
caryt is offline
post #8 of 18 (permalink) Old 02-15-2010, 11:15 AM
what about a set up to keep the fogs on with the highbeams?
Truck pic:
post #9 of 18 (permalink) Old 02-15-2010, 12:51 PM
My Photos: (35)
There might need to be a re-wire of some items..
My Lightforce are on one switch to be turned on or off at will.
The extras down in the plastic part of the bumper are on their own switch and can be turned on or off at will...
Mine is a 2000 with the 9007 , so it looks like I and others with the 9007 lights can do things that others can not do..
that you perceive
the web they weave
post #10 of 18 (permalink) Old 02-15-2010, 04:18 PM Thread Starter
cut7's Avatar
Thanks for all the replies. Yes, Brite Box (Innova) is the company I was looking for. I could have designed a circuit that would do the job, but for $90 to have a plug & play circuit, it's not worth it to do it myself.
That is simple; just ground the fog lamp relay. It's behind the fuse box under the dash. It should take you about 15 minutes to do the job.
2005 Excursion 4WD
cut7 is offline
post #11 of 18 (permalink) Old 02-15-2010, 11:19 PM
dwc032's Avatar
Dont mess with any of that crap. Ive had the bright box, silverstars, Goss upgraded harness and it was still total crap. The light output was maybe 10-15% more then the stock output. I went and bought a 55 watt HID kit from Retro Solutions and it was a night and day difference......NO JOKE!
Never shall I fail my comrades. I will always keep myself mentally alert, physically strong and morally straight, and I will shoulder more than my share of the task, whatever it may be. One hundred percent and then some.
dwc032 is offline
post #12 of 18 (permalink) Old 02-16-2010, 10:58 AM
Can you elaborate on that at all?
Truck pic:
post #13 of 18 (permalink) Old 02-16-2010, 09:09 PM
dikkstarr's Avatar
I did both and there was so much heat that it burnt the chrome inside the headlight housing, turned it gold around the bulb.
If you want to see more at night and not wreck your truck....get HIDs.
Thank you.
2004 F-250
dikkstarr is offline
post #14 of 18 (permalink) Old 02-16-2010, 10:50 PM
dwc032's Avatar
Thank you.
Yah I forgot to mention that. The same thing happened to my lights. Not to mention they suck, they also will ruin your headlight assembly.
dwc032 is offline
post #15 of 18 (permalink) Old 02-17-2010, 12:09 AM
http://www.powerstroke.org/forum/gen...-override.html
Truck pic:
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
