lowering 4by4 - Diesel Forum - TheDieselStop.com
Old 03-01-2005, 11:10 PM   #1 (permalink)
lowering 4by4
I just bought a fithwheel and my truck sit's to hi. I bought my truck used but it seames like it sit's higher then most I'v seen.I don't know if it has a lift kit or not is there any way I can tell thanks. early99 350 crewcab drw 4by4 6 speed lariot
bob3710 is offline
Old 03-02-2005, 02:03 AM   #2 (permalink)
My Photos: (19)
Re: lowering 4by4
Diesel Innovations sells drop shackels for the back. www.dieselinnovations.com
hope this helps
redrocket
*SOLD* 2001 F-250,Toreador red,ext cab,4x4,BB turbo/1.15 housing,Mini Me's,pushrods,headstuds,AirDog,ATS Stage 5 tranny,DI headers,Hypermax Tapercore,471hp/lost the tq(Dynojet)
*NEW* 2004.5 Dodge Cummins,LB,QC,4x4,Laramie
redrocket is offline
Old 03-02-2005, 02:06 AM   #3 (permalink)
Re: lowering 4by4
If the rear blocks are 4 inch you can swap them for the F250 2inch blocks.
DENNY
1999 F350 CC SRW LB 4X4 SIX SPEED.
DENNY is offline
Old 03-02-2005, 08:58 AM   #4 (permalink)
Re: lowering 4by4
Ive never heard of this problem with a ford before. I know alot of the 99-era dodges had recalls because the rear end sat too high for alot of fifth wheels.
2005 F-350 SRW, Lariat, crew cab, 6.75 ft bed, 4x4, auto, True Blue, 70k miles, stock.
Sold: 2004 F-350 Reg-Cab XLT, 4X4, SRW, 6.0 PSD, 6 speed, manual transfer case, Dark Shadow Grey, 285/75R16 Cepeck FC-II's on 16X8 Centerline wheels. built 3/23/04, 125K miles.
Canyonero02 is offline
Old 03-02-2005, 10:16 AM   #5 (permalink)
Send a message via ICQ to MudHog
Re: lowering 4by4
From our very own FAQ under the 99+ Super duty TSB section:
99-14-5 - Rear Suspension too high/low with a 5th Wheel
Problem - Clearance concerns may occur when using the vehicle to tow certain gooseneck trailers
Action - Ride height may be reduced or increased ON SOME VEHICLES BUILT ON OR BEFORE 2/14/99. The only authorized adjustments allowed are:
Lower the vehicle by changing the 4" (10 cm)spacer to a 2" spacer (5 cm) along with the other rear suspension hardware.
Raise vehicles that are percieved as riding too low and that have had TSB 98-17-2 performed with the 2" spacer (5 cm) block along with other rear suspension hardware
'03 F150 Supercrew FX4. Little 1/2ton that gets 15 MPG on 23 gallons.
'06 F250 FX4 CC SWB
MudHog is offline
Old 03-02-2005, 04:33 PM   #6 (permalink)
Re: lowering 4by4
I know I have 4" blocks on back if I take them out truck will sit high in front.any way to lower front thank's.
bob3710 is offline
Old 03-02-2005, 07:54 PM   #7 (permalink)
goldrush's Avatar
Re: lowering 4by4
i had the very same problem as you. my original blocks were 4". ford removed them all together, which made the back sit lower than the front, looked like crap and caused driveline vibration. they then put 2" blocks in and i think had to shim the carrier support some, everything is fine for me now. my 5'er has adjustable spring shackles and i have it set to the tallest position. hope this helps.
2008 f350 crew cab lariat 4x4 v10
previous: early 99(6/98) f250 xlt 4x4,psd,xle4,auto,sc,lwb.
99.5 air box, scorpion spray in bedliner, isspro ev pre-turbo pyro,trans,and boost,a-pillar mount. rancho rsx shocks,
superchips microtuner(2 program), magnaflow 3.5" dp 4" back exhaust, zoodad mod,
31' jayco 5'er
goldrush is offline
Old 03-02-2005, 08:35 PM   #8 (permalink)
Re: lowering 4by4
I'll have to try it and see I have 5 spring's on the front is this normal I looked at some 02 they all had 2 on the front.
bob3710 is offline
Old 03-02-2005, 09:42 PM   #9 (permalink)
Re: lowering 4by4
Don't know your current setup but a common modification up here is to move your trailer axles to the bottom of the spring if your trailer's axles are above the spring. This usually makes a 5th wheel trailerable behind a stock F-350.
We towed a swapped axle 5th wheel behind a 2003 F-250 with a 4" lift and 35's with no problems.
You're sticking out in the wind a bit more but I guess it just depends on what you want.
07' F-350 Crew, long box Lariat. 4" BDS lift, 20X9 MKW rims, 35x12.5x20 Toyo Open Country, stereo, Winch from old truck, Magnaflow exhaust etc. No tuner on this one. New Addition! - 2012 Mustang GT, 6 spd.
Old Truck
04 F-350 Lariat 4X4 Crew Cab 6.0, literally everything but moon roof and PTO. Good stuff: 4" lift w/35" BFG muds, Intake, exhaust, Edge-Juice/Attitude, AIC, Warn 12k Winch, stereo work etc, etc. http://community.webshots.com/album/282528994AiGTsv
(Latest pics at the end of others)
nuclrslug is offline
