Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 06-28-2009, 08:07 PM   #1 (permalink)
Need Brake Upgrade Advice Please!
Hi Folks,
I have a 2000 F-250 with the 7.3 PSD, of course. It is a 4x4 lariat model super cab. I absolutely love my truck! I only have about 70k on it, but a lot of those miles are pulling a 10,000 lb. fifth-wheel camper.
My brakes have been replaced once, and I was told that the rotors are probably not thick enough to turn again. They have started to shimmy a little and pull to the side when I'm towing, but I can feel the shake even empty.
I'd like to upgrade, and not just go with factory parts. Thinking about the EBC brake pads and rotors. But I'd love to here your suggestions before I buy. Please comment on what you have that works well, particularly in a towing application.
Thanks!
The Highlander
The Highlander is offline
Old 06-29-2009, 01:08 PM   #2 (permalink)
I tow a 12K 5er, so our load is about the same. My service brakes are still above 75% remaining and they are the originals. My advise is to get an exhaust brake and your service brakes will last a lot longer than what you are at present. My vehicle mileage is about the same as yours. I wouldn't leave home without the exahust brake. My .02
jgr
Y2K F350, Ecab, LWB, SRW, 4X2, ZF6, Full Gauges, Ebrake, Chipped 271rwhp/584tq, Scan gauge II, Coolantfilter, fumoto valve, oil by-pass filter, CCV mod with return to intake, dahl 100, 40 gal. aux tank, straight piped, PML cover, 203 stat and billet, AIS, Zoodad
pristine is offline
Old 06-29-2009, 02:14 PM   #3 (permalink)
woodnthings8's Avatar
I put on Powerslot rotors with Hawk Pads several years ago due to a warped rotor when I bought the truck. They perform nice and I have not had any problems with them towing a 9k trailer. They have a cad coating on them that keeps them from rusting too. So they stay looking nice, the brake pad contact is bare steel but the rest is plated. I want to say they were the same price as OEM rotors and pads when I got them.
2002 F-350 CCLB 4X4, HD4R100 , 4" Diamond Eye exhaust, Powerslot rotors, DP Tuner-F6, Autoenginuity, KCM S.S. HPX Line, S&B Filters intake, Autometer gauge pod, Inovations canopy,Banks Big Head wastegate actuator, 6.0L Trans Cooler, Zoo-dad, Dieselsite Coolant Filter, DVD and always looking to do more....
woodnthings8 is offline
Old 06-29-2009, 04:37 PM   #4 (permalink)
Thanks gentlemen. The exhaust brake may be an upgrade for the future, but right now I need to replace the brakes first! I think a part of my trouble with brakes is the 6% grade I pull up and down when we leave the house. Every where we go in the Southeast, I'm basically faced with at least one 2-4 mile 6% grade, and a few places we go have a couple of those.
Add the fact that my truck sits quite a bit and I have just always eaten brakes it seems like. That is why I'm looking for an upgrade.
I'd love to do an exhaust brake, but I don't see it in the budget this year. What type do you have, where was it installed, and about what price range am I looking at?
Thanks,
The Highlander
Old 06-30-2009, 04:56 PM   #5 (permalink)
aklim's Avatar
What about SS braided brake lines?
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, Van Turbo and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 06-30-2009, 05:26 PM   #6 (permalink)
My Photos: (10)
Try a DIY exhaust brake, very cheap. Actually free if you have the few parts lying around. If you have an auto, you will need to also lock the torque converter at the same time.
I just bought the Hawk Pads and PowerSlot rotors. I've been waiting over a month for the rear parts as they are on backorder. No idea what's going on here.
'02 F-350 "Babe The Big Blue Truck" 4x4, Ext. Cab, 8' bed
DP-Tuner 80T, ATS Compressor housing, DIY intake, openair CCV, 80HP 'pane shot, SBC DD all ceramic clutch, ISSPRO boost/pyro gauges, 4" lift, 255/70R22.5 tires, brake linelock, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, and who knows what else... oh and a Kennesaw Mountain front bumper (now tried and true)
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, D20, 3.5" WH sus. lift, 3" body lift, 35" BFG muds, Stock Dana 30 front with Lock-Rite, disk brakes, Warn Hubs, Stock Ford 9" rear with mini spool
BTBBT is offline
Old 07-01-2009, 03:33 PM   #7 (permalink)
Braided lines would look good, but how exactly do they improve braking performance? As for a diy exhaust brake, I don't have the time or inclination to do that type of work. I'm looking for comments on what brake pads/rotors/etc. that are available that will give me better braking while towing an 11,000# trailer.
Thanks!
Old 07-01-2009, 06:43 PM   #8 (permalink)
Braided lines are less prone to expanding under pressure when braking. Plus they are more rugged for offroad use. And like you said they look cool!
Old 07-01-2009, 06:53 PM   #9 (permalink)
aklim's Avatar
Thanks!
A more extreme example is the wife's car. Used to be, she stepped on the brakes and they didn't engage like they should and suddenly, they engaged. What I theorize happened is that as she gently stepped on the brakes, the hoses swelled till they could go no more then they let the pressure thru and the brakes felt like suddenly engaging. Now she puts a little pressure and the brake is there.
aklim is offline
Old 07-01-2009, 07:36 PM   #10 (permalink)
Look the only way to stop your truck is with the SSBC brakes ... I tow a 18,000 + and have 37 in tires on the truck the SSBC work great
industry66 is offline
Old 07-02-2009, 10:18 PM   #11 (permalink)
dikkstarr's Avatar
The easiest cheapest way to fix it would be powerslots and hawk pads, about $275.. I got these after my stockers warped. Now I can lock up my 38s. Just make sure all the air is bled out
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , white with 12" lift, flip steering, 38s on 17 10s, stock gears, superlift truspeed, fumoto, floating traction bars, airraid intake with elbow,4" turbo back, studded, powerslots, 55 watt HIDs 6000k heads and fogs,clear corners,7" NAV w/ back up camera, massive stereo, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,,coolant filter kit,hush panels and door seal mod,
dikkstarr is offline
Old 07-03-2009, 09:39 AM   #12 (permalink)
I'm having a tough time finding a part number for a 2000 F-250 4x4 PSD front rotors in the powerslots or EBC's for that matter. Everybody lists parts for the dang V-10 gassers, but not the diesels. Any suggestions would be appreciated!
Old 07-03-2009, 10:48 AM   #13 (permalink)
OK, nevermind. I just found the part number for the Hawk Superduty pads and Powerslot rotors and ordered them from Summit Racing. Should be here next week. I'll do an update on how I like them after they have been in for a few days.
Thanks for the help!
The Highlander
Old 07-07-2009, 11:42 PM   #14 (permalink)
Where are they for $275?
2003 7.3 PSD Crew Short bed - DIY Air Filter, 4in Turbo back MagnaFlow Exhaust, Turbo-master wastegate controller, Adrenaline HPOP, Auto Meter Z-Series gauges, EBV Delete, RiffRaff AIH plug, DP-Tuner 80 Econo
wrtaz is offline
Old 07-09-2009, 08:11 PM   #15 (permalink)
I've tried the Hawks and yellow EBC pads on my superduty. EBC pads worked better.
IRONMAN97459 is offline
