need help with shocks - Diesel Forum - TheDieselStop.com
Old 09-09-2009, 10:14 PM   #1 (permalink)
rockymtredneck's Avatar
Send a message via Yahoo to rockymtredneck
i need some help with shocks. i have standard front and rear shocks from les schwab on my truck. i have gone through 3 sets of fronts in 4 months and i cant seem to figure out what is causing them to fail. it has cost me 2 sets of tires and i have to do something quick cuz im getting ready to replace them, any ideas and suggestions on new shocks would be great. thanx yall
2002 F-350 140,000 MILES, 2" LIFT, AFE stage II INTAKE, 35" TOYO M/T's, dp tuner 5 posi chip no start stock 80 econo 120 20 HA tow, 4" TURBO BACK, glowshift gauges, now featuring powerflow 7" miter cut stacks
rockymtredneck is offline
Old 09-10-2009, 12:12 PM   #2 (permalink)
Feedback Score: 3 reviews
The les schwab shocks are the worst shocks I have ever seen...even makes Rancho look good! Get Bilsteing last shocks you will buy.
Cary
caryt is offline
Old 09-12-2009, 11:17 AM   #3 (permalink)
Here’s a second vote for Bilstein shocks. I have been very pleased with how the shocks work. My truck rides better and they have already lasted twice as long as my original equipment shocks. The shocks rebound damping was also a big improvement over stock.
2002 7.3 F350 CCLB
4" Turbo-back Pinnacle (Jerry Jardine) Exhaust
Racor 2 Micron / 90 G.P.H. Fuel Filter
Baldwin BT111 External Trans Filter
OilGuard EPS-20 Oil Bypass Filter
Baldwin B5134 Coolant Filter
Dual External Trans Coolers
DieselSite 203 Thermostat
D.I.Y. Nappa 6637 Intake
SuperChips 1705
Bilstein Shocks
Zoodad Mod
vetmxrider is offline
Old 09-14-2009, 05:02 AM   #4 (permalink)
thanks guys. im going ahead and buying a set or belstein 5150 series shocks and hopefully i can keep a set of tires on longer than a couple of months. thanxs for the advice exspecially since i was gonna go with the rancho series. good call. alot better shock for the about the same price.
Old 09-18-2009, 10:49 PM   #5 (permalink)
ckanderson's Avatar
5150 shocks are good.
buy the right shocks once and use them for a lifetime
2002 F-250 7.3 4x4
1964 Nova 400 w/350
ckanderson is offline
Old 09-22-2009, 07:10 PM   #6 (permalink)
ALR1955's Avatar
Send a message via AIM to ALR1955
Just ordered a set of Bilstein's for my truck. The Ranchos I have on the truck right now are giving a horrible ride. Guy I talked with at Bilstein said there would be a noticeable difference. I'm really hoping he is right - my teeth are starting to loosen up from the ride!! LOL
2006 F350 Lariat SDSC 4X4 DRW
4" Lift system w/ airbag leveler system
Bilstein 5150 shocks
Ameritrac LT235/80R17 tires
Banks turbo back 4" Monster exhaust system
AirAide Intake Filter
Accufab Polished Intake tube
AgriCover Bed cover
Romik SS Grill/Brush guard w/ PIAA Driving Lights
Kenwood 5120 Series Entertainment/Navigation system
Kenwood Sirius/XM Satellite Radio system
ALR1955 is offline
Old 09-22-2009, 07:21 PM   #7 (permalink)
Matt0987's Avatar
I put Bilsteins on my Excursion this weekend. What a major differnence. But then I was replacing factory shocks w/ 85,000 miles on them.
I also replaced the steering damper. It makes a major difference on control in a turn.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Matt0987 is offline
Old 10-09-2009, 11:41 PM   #8 (permalink)
I put the recommended Bilstein models all the way around my truck. The fronts were great, but the rears were a few inches shorter than stock. Although I admit the ride is noticeably much better, the rear also noticeably hits the hard stops on the rebound very frequently. I actually had to raise the frame ever so slightly to install the shocks. I thought I would have to compress them to install them.
Has anybody else experienced this with the same type truck (2wd CC dually)??
I did double and triple check the model numbers with what is recommended for my truck.
Any suggestions??
Thanks in advance.
'01 F350 Dually 2wd 6sp/PTO option and AIC.
LUK clutch, AFE intake, 4" exhaust, DI 4pos custom chip with high flow injectors.
oneton is offline
Old 10-10-2009, 12:00 AM   #9 (permalink)
Matt0987's Avatar
I had to compress mine.
Matt0987 is offline
Old 10-13-2009, 08:13 PM   #10 (permalink)
whats up with the 5150's are these a better model # ?? it looks like 2818 and C296 for my 04 F250
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
My Truck
2004/1997 Powerstroke Pics, Ford 9N Tractor,6.0 Bible
dwelch1 is offline
Old 10-14-2009, 09:33 AM   #11 (permalink)
Not any better just a small reservoir and more $$$. Stock truck just use HO's..unless you don't like the color.
Cary
Cary
caryt is offline
Old 10-14-2009, 11:20 AM   #12 (permalink)
ckanderson's Avatar
they have that small reservoir on the side. helps with heat management
2002 F-250 7.3 4x4
1964 Nova 400 w/350
Old 10-14-2009, 05:16 PM   #13 (permalink)
what about the steering stabilizer? is it worth replacing also? I have 95K on my truck, I think new shocks will help the ride.
My Truck
dwelch1 is offline
Old 10-14-2009, 05:30 PM   #14 (permalink)
Matt0987's Avatar
Stabilizer. Yes. Deffinately.
I just replaced mine with the shocks. I had 85K on mine. It was worn. Turns are not nearly as scarey as before.
I went with the Rancho because of availability and name branding.
Matt0987 is offline
Old 10-16-2009, 12:42 AM   #15 (permalink)
Most shocks in the US are made by the same company; Heckthorn. Monroe = Rancho = Rough Country = Sky Jacker = .........
wlrottge is offline
