need longer brake lines HELP!!! - Diesel Forum - TheDieselStop.com
Old 07-10-2009, 12:41 AM   #1 (permalink)
sjac9999's Avatar
i need longer brake lines im putting a 12" lift i cant find or even know where to look for the braded brake lines help please send me a link thanks
2001 F250
DP F5 tuner
BTS tranny
15" PMF custom lift
39.5" Interco tires
20" Chrome rockstars w/ white painted stars
05 frontend
08 mirriors
Nathan P5 train horns 200psi
soon to come 08 tail gate and bumper
Looking for
1.gauges
2.
Last edited by Dick Cutting; 07-10-2009 at 10:13 AM. Reason: Corrected 3 spellings of the word Brake
sjac9999 is offline
Old 07-10-2009, 03:43 AM   #2 (permalink)
BLOWINSMOKE99STROKE's Avatar
try here:
Ford extended brake lines
Russell Street Legal Stainless Steel Brake Lines for Ford Trucks & SUVs
Or even:
Let me google that for you
EARLY 99 F350, CREW CAB, LONG BED. 4X4 7.3L AUTOMATIC. EDGE JUICE W/ ATTITUDE. 4" EXHAUST, NO MUFFLER, 6" TIP, COLD AIR INTAKE, BD: CCV KIT (WON ONLINE, THANK YOU BD). DVD PLAYER, PS2, IN DASH TV, POWER INVERTER, 2-10" INFINITY SUBS IN PORTED BOX. CLASS 5 REESE TOW PACKAGE, FLIP UP GOSENECK HITCH. CB/PA, WITH DUAL TRUCKER WHIPS. TOW MIRRORS, AND CAB LIGHTS, RECON LED TAILGATEBAR W/ REVERSE LIGHT, BUG GUARD AND WINDOW VISORS. 05 GRILL AND HEADLIGHT SWAP, 08 TAILGATE, 285/75 BFG ALL-TERRAINS, SHACKLE LEVELING KIT, AND BILSTIEN SHOCKS. 5% TINT ALL THE WAY AROUND, AND 50% ON THE WINDSHEILD.
SOON TO COME: 08 TAIL LIGHTS, CLEAR CABLIGHTS, RECON ESCALADE STYLE 3RD BRAKE LIGHT, STROBE LIGHTS, PROJECTOR BACKUP LIGHTS, 33X12.50 BFG ALL TERRAINS ON BLACK DICK CEPEK 17" RIMS, EDGE EVOLUTION PROGRAMMER (STACKED), RAPTOR HIGH PERFORMANCE FUEL PUMP, HIGH PERFORMANCE HPOP, POSSIBLY 10" STACKS!
BLOWINSMOKE99STROKE is offline
Old 07-10-2009, 04:40 AM   #3 (permalink)
BubbaZ71Tahoe's Avatar
Offroad Design has some really good ones...
ORD Braided Stainless Brake Line Kits, Extended Brakelines
2002 f250 ecsb 7.3,4r100 triple disc converter shift kit, amsoil atf, 60/10.5 DIY Tymar, (ISSPROboost, trans, Egt) PHP FU.
AutoEnginuity in the Lafayette-Houma area
BubbaZ71Tahoe is offline
Old 07-10-2009, 09:59 AM   #4 (permalink)
sjac9999's Avatar
on both of the sites the lift size only go's up to an 8" lift im puting a 12" on mine will they will work?
2001 F250
DP F5 tuner
BTS tranny
15" PMF custom lift
39.5" Interco tires
05 frontend
08 mirriors
Looking for
1.gauges
2.
sjac9999 is offline
Old 07-10-2009, 05:56 PM   #5 (permalink)
ORD will custom make them... Call them up
Old 07-11-2009, 01:40 AM   #6 (permalink)
Call ORD, like bubba said, or call those sites to see if they can confirm if they would work or if they have ones that will.
Old 07-11-2009, 10:15 AM   #7 (permalink)
My Photos: (19)
If you are worried about 2", don't be. I'm running a 3"+ lift and haven't changed my brake lines yet. There is play and room for adjustment with the stock lines.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 07-12-2009, 12:25 AM   #8 (permalink)
He's goin with 12".. I think you misread...
Also I noticed that changing from rubber hose lines to the stainless it felt like I had better braking... that was on my tahoe with 38s
