Ok I have an 05 F350, I installed one of these
Light Bars on my truck on top of it I put 2 of these
Lights the bumper uses the two bolts on either side of your tow hooks. Ok so I followed the wiring diagram to put in a bosch type relay. pos 85 went to my Upfitter switch #1 post #30 pos battery 30amp fuselink post #86 ground to body post #87 went to lights Black wire. Post #87a empty and the white wire from lights went to a ground on frame. Now every time I switch on the lights I blow the fuse for my Upfitter, so I bypassed the relays and went Upfitter switch to black wire and lights and Pop fuse again. Is it possible the lights are double grounded or is there such a thing I dunno but I have blown 3 Upfitter fuses and $2.99 a pop aint cheap. help
I've done this enough I should know but CRS settin' in:
Check your lights black and white wires, which one should go to hot vs ground.
Check the side of the relay, it should have a wiring diagram. #30 is the 20/30 amp power input and I believe #87 is correct.
Hope this helps.
Al
