Optix pyro problem - Diesel Forum - TheDieselStop.com
Old 07-12-2009, 11:36 AM   #1 (permalink)
locknload223's Avatar
Optix pyro problem
Yesterday was my first hour plus trip. A few miles before my destination I noticed the pyro would drop below 400. It idled 5 min and still no drop. I shut it down, turned the key on, off, then back on at the pyro reset at 200 which from the past I noticed was common at idle on my truck.
On my way home comming through a small town with a 35mph limit, I just happen to notice the pyro was pegged at 1600. ??? I let off a bit and it would drop to 1500 but as soon as I gave it a touch of throttle it would peg again at 1600. I pulled right over, reached through the wheel well and felt no abnormal heat. Popped the hood, heat felt fine. I performed the same shut down/reset as before and the needle went to 400. Any ideas???
No trailer, just the X. I installed the gauges with their built harness and I am completely anal when it comes to this stuff. Any ideas before I call Danin? Thanks.
'00 Excursion Limited- 4" lift, Vcodes/F350 block, 315/75/16's, airbags, ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80tow, Drive-Thru, 80econo, 120race, 4" MBRP, 6637, 6.0 I/C, AIH delete, Foil delete, Auto Enginuity .
locknload223 is offline
Old 07-12-2009, 11:55 AM   #2 (permalink)
Check for burned, chafed, or loose wires. Other possibilities could be gauge or probe problems.
2002 F-250 XLT PSD 4x4 CC LB.
285/75/16 BFG Allterrains.
GTP38R BB Turbo.
AIS intake.
ISSPRO EV Gauges: Pyro, Boost, Trans temp.
4" MBRP turbo back.
DP Tuner: 1,200HI, 80E, 120R, 80tow, 60tow.
Overboost Annihilator.
ISSPRO Turbo Temp Monitor.
IH Bellowed up-pipes.
BTS 4R100. -10/11/2010
diablo53 is offline
Old 07-21-2009, 07:08 AM   #3 (permalink)
I spoke with Danin and they're going to send me a new gauge as soon as their shipment arrives. Stay tuned.
Old 07-21-2009, 11:06 AM   #4 (permalink)
fxdwgi's Avatar
Just an FYI, I am sure you checked this, but the power to the gauge has to be a key hot. If not, the gauge will do exactly what you are talking about.
Don't ask me how I found out.........lol.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 07-21-2009, 11:53 AM   #5 (permalink)
Yep, first thing I checked. It's powered by 'key on' power. Danin verified that's it's correct by the fact that when I shut the motor down, key off, then key back on, the needle resets to zero.
Not only does it climb unusually high but it will freeze at 400, 600, 1000, where ever it wants to. When I shut it down and cycle the key, it frees up. Thanks.
Old 07-22-2009, 09:25 AM   #6 (permalink)
fxdwgi's Avatar
Pain in the arse, but at least they are sending you a new one.
fxdwgi is offline
