Overhead computer fix, it works - Diesel Forum - TheDieselStop.com
post #1 of 31 (permalink) Old 12-05-2009, 10:22 AM Thread Starter
428INTERCEPTOR's Avatar
I may be way behind the curve on this one but I stumbled across this a couple of weeks ago. It's a free step-by-step on how to fix the overhead trip computer if it flickers or does not light-up at all.
If you've seen it before I appologize, I just want to save someone from wasting a couple hundred bucks on a new one.
2000 Ford F-350 Diesel Powerstroke! Trip Computer Fix
2002 F-350, 4X4, LONG BED, CREW CAB, LARIAT (7.3 POWERSTROKE OBVIOUSLY)
GRAND JUNCTION, COLORADO
428INTERCEPTOR is offline
post #2 of 31 (permalink) Old 12-06-2009, 04:35 PM
elindley01's Avatar
Just want to second this post. I performed the fix on mine today and it works like a charm. I feel like I won the lottery not having to replace the entire overhead info center!!
2004 Harley-Davidson F-250 4x4 Crew Cab
6 inch Rancho suspension lift and 35 inch Pirellis
4 inch custom exhaust w/ 5 inch rolled tip
elindley01 is offline
post #3 of 31 (permalink) Old 12-14-2009, 11:31 PM
The overhead 'puter fix worked for me too. One of the capacitors was totally disconnected on one side. I sharpened my cheapo soldering iron and bought some super thin solder. The fix really worked. I'm a happy F250 owner now.
2000 F250 2WD 7.3L, 265,000 Miles, 6spd Manual, Hypertech programmer, 4" Flowmaster Exhaust,
, ITP Fuel Tank /
, Pioneer Avic-X710BT,
. 2006 Front and Rear axles and suspension parts installed.
vegoilrecycler is offline
post #4 of 31 (permalink) Old 12-27-2009, 04:38 AM
abjacq's Avatar
mine worked too! so did a buddys truck! thank god we did not have to buy new ones. saved us so much $ hah!
---2006 f250 king ranch, 200k miles, boss 9'2'' VXT plow, 2inch leveling kit, automatic airbags, 35's.
---1999 f250 ex cab short bed 4x4 350springs 170k built trans DP Tuner (stock, 60 tow, 80 econo, 140 aggressive) 4in banks exhuast glow shift guages 8ft boss plow
---2003 f250 crew cab lariat 4x4 240k miles, 9'2'' BOSS V plow
---2000 f350 cc sb 4x2 260k miles SOLD
1999 ex cab sb 4x4 305k miles SOLD
2002 f250 cc sb 4x4 355k miles SOLD
abjacq is offline
post #5 of 31 (permalink) Old 12-29-2009, 07:05 PM
intheclouds1977's Avatar
Nice write-up. Where is this circuit board located when in the vehicle?
2001 F-350SD CCLB DRW 4x4 4.10 7.3
- Magnaflow 3.5"/4" turboback
- S&B Intake
- Tekonsha P3 Brake Controller
- Eagle 034 Aluminum Wheels
- 10,000# loaded trailer, Class V hitch, 2-5/16 ball
-- Reese weight distribution hitch w/ dual cam anti-sway control
intheclouds1977 is offline
post #6 of 31 (permalink) Old 12-29-2009, 07:13 PM
EXODUS's Avatar
Nice... mine's messed up also, must of banged on that thing fifty times hoping it would magically come back on!
Going to check it out.
1999 F-350 7.3 Super Duty Dually
5" Exhaust, Edge Juice Controller
Tymar Intake
Bilsteins
350K (so far)
EXODUS is offline
post #7 of 31 (permalink) Old 12-29-2009, 09:58 PM Thread Starter
The circuit board is actually attached to the display itself. Once the cover is pulled off the overhead console, you’ll see where it is.
Just be careful when removing the cover in northern climates this time of year.
post #8 of 31 (permalink) Old 12-29-2009, 10:21 PM
STMPDUST's Avatar
Wow , mine just went out in the 05 EX .was at the dealer last week for coolant puking and they wanted over 500 to fix the trip comp.just fixed it in 10 min for free WOW!!!
2015 KR Dually CC 4X4 Bronze Fire HC
2011 KR Dually CC 4X4 Royal Red
2005 Eddie Bauer Excursion 4X4 ,White
STMPDUST is offline
post #9 of 31 (permalink) Old 12-30-2009, 04:52 PM
EXODUS's Avatar
Not the sharpest tool in the shed... O.K., how do you get the cover off of the ceiling?
I see the two tabs inside the cubby hole, do you lift, pull, push...?
Any insight from the successful removers?
Tymar Intake
Bilsteins
350K (so far)
EXODUS is offline
post #10 of 31 (permalink) Old 12-30-2009, 10:04 PM
STMPDUST's Avatar
put your hands to the front and pull down(front= closest to front window) it will pop and come down in the front, th rear has a little catch to it look close after the front part is loose and you will see. it also will need to be pulled down, but make sure you see the catch.
STMPDUST is offline
post #11 of 31 (permalink) Old 12-30-2009, 10:13 PM
EXODUS's Avatar
Thank you, I'll give it shot first thing in the morning.
It always makes me leary reef'n on plastic interior parts.
Tymar Intake
Bilsteins
350K (so far)
EXODUS is offline
post #12 of 31 (permalink) Old 12-31-2009, 11:59 AM
EXODUS's Avatar
Well, that was interesting. The center console comes off o.k. (little scary) but I managed to get the computor to my bench.
After cursing at my weller soldering iron I realized I was trying to use wire for my wire-feed welder as solder.
Back on track.
Found solder... of course its about 3/8 of an inch wide (not really but seemed that way). I had (5) resisters loose.
Put 'er back in and fired truck right up.
Went to giver a little throttle to bring up R's... no response (what the heck).
Realized NO gauges worked... 'bout crapped my pants!
Blown fuse, unplugged computor, change fuse, all is well.
Moral of story and question, where can I find another trip computor and do I need to start new post for that Q? Cuz I toasted that puppy good.
Tymar Intake
Bilsteins
350K (so far)
EXODUS is offline
post #13 of 31 (permalink) Old 01-02-2010, 03:02 PM Thread Starter
You probably have too much solder on the board and have managed to short across two thingies that shouldn’t be touching. You might not need a computer just yet. Remove it once more and try taking it to someone who knows circuit boards, like a TV repair shop. It'll be cheaper than a 150.00 e-bay salvage special that probably has the same problem as your old one.
post #14 of 31 (permalink) Old 01-02-2010, 06:05 PM
428, thank you for posting this! Just got done repairing my trip computer. There were 4 resisters broken loose. Works like a charm now!
- S&B Intake
post #15 of 31 (permalink) Old 01-03-2010, 12:07 AM
EXODUS's Avatar
That's exactly it, I'll give it another shot. I've worked worked on a few circuit boards before with good results. I do have to say, I've seen nicer factory work, my boards a little rough right out of the box.
Thanks for direction 428INTERCEPTOR, we shall overcome!
Tymar Intake
Bilsteins
350K (so far)
EXODUS is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
