Power Inverter & Upfitter Switch - Diesel Forum - TheDieselStop.com
Old 07-03-2005, 08:53 AM   #1 (permalink)
It would be nice to have a power inverter available at the back of the bed on a F250 - for air pumps, trouble lights etc. Possibly built-in to the bed of the truck on the side (inside of bed). Also, maybe have the "master switch" through the up-fitter switch to keep the power "Off" unless it is being used.
Any suggestions on how and where to install an inverter? Another, and maybe better option would be to install under the bed, so would not have to cut through the bed. Of course that would have to be protected from dirt and mud.
So I am looking for suggestions. Thanks.
2006 F250 4x4 Lariat CrewCab SB, FX4, 20" w/GoodYears
HoustonPerson is offline   Reply With Quote
Old 07-03-2005, 11:23 AM   #2 (permalink)
Re: Power Inverter & Upfitter Switch
being electronic i would not mount any inverter exposed to the outside elements. better to mount it inside the cab and buy a drop cord.
Frank
2004 6.0L PSD E-350 Superduty Ext. cargo.
http://www.imagestation.com/album/?id=4286001359
racerman_27410 is offline   Reply With Quote
Old 07-03-2005, 11:55 AM   #3 (permalink)
Steve Campbell's Avatar
I have one inside in the back for Xbox just remeber you are dealing with 120 volt so I also would not put one outside my truck.
2012 F250 Lariat 6.7 Golden Bronze 4X4, MBRP Filter Back Duals, Alpine INE-Z928HD Focal Amp and Speakers and a ton of Dyno Mat RetraxPro Clifford Alarm Recon smoked marker/clearance lights HID Headlights/Fog Lights
Protected by H&K
2006 Hummer H2 (traded for diesel hope never to go back to the dark side (gas)
2005 F250SD SB 4X4 6.0 Harley Edition (traded)
2003 7.3 F350 DRW 4X4 (traded)
2001 7.3 F250 4X4 (traded)
Steve Campbell is offline   Reply With Quote
Old 07-03-2005, 12:05 PM   #4 (permalink)
Send a message via ICQ to paconstruction
I mounted my inverter (4000 watt) inside my cross box tool box. I have the wiring ran to the battery but don't have it switched yet, I have jumper cable ends on it and just hook it up when I need it. Eventualy I am going to mount a solinoid or relay of some sort so I can have a switch inside the cab that will supply power to the inverter. I made a cage out of expanded metal to keep tools and stuff from laying on top if it and will later install a weather proof outdoor plug and box at the rear of the bed.
I would not recommend mounting one under the hood due to heat, water and dirt.
Lee [img]/ubbthreads/images/graemlins/smokin.gif[/img]
#1 <font color="red">'99 F350, CC, DRW, 6 speed, Proguard 7 open eliment, SCMT High Performance, Fuel regulator shimed to 70#'s, Hypermax EGT/Boost combo, B&W Turnover ball gooseneck, Tow Champ 16K 5th wheel, <font color="blue">Sirius sattelite radio,</font>, laptop desk, 2400 watt 110V power inverter.</font>
paconstruction is offline   Reply With Quote
Old 07-04-2005, 05:36 AM   #5 (permalink)
As anyone yet, connected an "inverter" to switch on and off from the upfitter switch?
Old 07-04-2005, 01:23 PM   #6 (permalink)
Easy to do. Get a high current relay (a Glow plug relay will do the trick), run your power straight from the battery through the relay, and then out to the inverter. Then use the upfitter switch of your choice to open/close the switch circuit on the relay.
~matt
2001 Excursion Limited, PSD, 4x4, DR Lift, Pro Comp tires/wheels
msaskin is offline   Reply With Quote
Old 07-04-2005, 06:15 PM   #7 (permalink)
Thanks for the input.........I have a lot of choices to make, may just keep the inverter inside the cab for safety etc.
Old 07-04-2005, 10:28 PM   #8 (permalink)
Kanman's Avatar
When you figure everything out, would you please post your results. Photos would be very nice [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Kanman is offline   Reply With Quote
Old 07-17-2006, 03:09 PM   #9 (permalink)
I am looking to install an inverter too, I have a cobra 3000 watt that I had under the back seat in my 2000 but now I can't find a place to mount one. I have the bench front seat and it will not fit under the center seat. Has anyone found a large inverter to mount under the front bench seat?
2006 F-350 6.0 Lariat Crew Cab FX4 8'Bed White/Beige Power Sliding Rear Window Heated Seats Upfitter Switches Towing/Camper Package 40/20/40 Bench Seats Jotto Desk for Laptop RKI Cross Box Single Lid Warn 9.5TI waiting for full replacement bumper [img]/ubbthreads/images/graemlins/frown.gif[/img]
Sold
2000 F-250 7.3 138,000 Same Color and all short Box (Have Juice with Attitude from it for sale)
TexasStroke is offline   Reply With Quote
Old 07-18-2006, 08:18 PM   #10 (permalink)
I don't see the advantage to using an upfitter switch. The unit has a switch on it. I mounted a circuit breaker with reset on it under the hood close to the battery. I can easily open the breaker if I wanted to, but I never had.
If I remember correctly my inverter draws 300 mA on, but with no load. With the switch off it essentially draws no current at all.
Now that I think of it, maybe if you mount it somewhere not easily reachable I can see the need for a switch.
2002 F250 Crew Cab, 2WD, Auto, 100k miles, 80hp Econo PCM, ISSPro Gauges, Ford AIS, Walker BTM.
ramblin_wreck is offline   Reply With Quote
Old 07-18-2006, 10:56 PM   #11 (permalink)
QtrHorse's Avatar
Most inverters will always draw a very, very small amount of power, even when there turned off. It would most likely not cause any problems unless you let your truck sit for 5 days or more.
99.5 F250 XLT S/C 6SPD
ITP Intank ModsLUK clutch w/ Kevlar pilotAFE Stage1Red Top OptimasReflexxion Cowl Hood
Truck Pic's
QtrHorse is offline   Reply With Quote
Old 07-19-2006, 11:02 AM   #12 (permalink)
Supporting Member
My Photos: (24)
I wired my 1750W inverter with 4/0 welding cables, thru a 175A type "T" fuse, at the battery. At full load the unit draws 170 amps from the battery.
2001 F-250 (pcm PMT2) ISS Pro EV tranny, boost, pyro gauges. TS Performance flip chip. Banks MONSTER exhaust, Maghytec rear diff cover, ITP H/X kit, Whelan 52" Strobe Bar, Fisher 8.5' Snow Plow, 3 Weatherguard tool boxes. HUTCH fuel tank mods, REMANFACTURED Ford transmission.
CPSS is offline   Reply With Quote
Old 07-19-2006, 11:42 AM   #13 (permalink)
I can think of ways to assure it is zero. If a mechanical switch is used, then all the batteries see is a wire hanging off them, right? I design electronics with much, much lower current drains so I don't know how they disconnect them from the batteries.
Are you sure your not thinking of the state where the inverter switch is left on, but without a load attached? I remember seeing a spec for that case, but have never seen a spec for off current drain. If you know of one please share
Since I don't know what kind of switch mine uses, and don't plan on taking the time to learn - I can just open the breaker up if I don't plan on starting the truck for more than a week (which I never do anyway).
Old 07-19-2006, 06:05 PM   #14 (permalink)
the way i was going to wire mine was to take the wires for the switch on the inverter and run them through the upfitter switch, all it would have taken was to cut the power to one of the switches and use it as an open or closed switch between the two wires for the power inverter. i got lazy and decided not to do it. should have worked great though
Ford Truck Enthusiest!
2003 F-350 lariat crew cab long box.
My Vehicles
justinthurn is offline   Reply With Quote
Old 08-04-2010, 08:39 AM   #15 (permalink)
I'm pretty sure that you should use a relay instead of pulling this kind of load through the upfitter switches but I'm no expert
trunderw is offline   Reply With Quote
