Rear speaker install in F-350 Crew Cab??? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 06-10-2007, 01:51 AM Thread Starter
Hello All,
Just bought a F-350 Crew Cab and wanted to replace the stock speakers. How do you remove (without breaking) the panel covering the rear speakers?
Thanks for the help,
Matt
2005 F-350 Crew Cab,6.0L,Auto,4x4,King Ranch,White and Arizona Beige,Edge Evolution, MBRP 4" exhaust, 2.5" Donahoe Racing leveling kit,LT305/70-18 Dick Cepek Mud Countrys,Pro Flaps,Husky Liners,Draw Tite gooseneck hitch.
Sold: 2000 F-250,4x4,SC,XLT,Island Blue,Auto, Autometer Z-series Pyro, Tranny, and Boost gauges,
AFE Magnum Intake with Pro-Guard 7,TS 4-position (stock-50-75-140) Flip Chip,DPPI 4" exhaust w/ 3.5" downpipe,Sonnax/Tricumulator springs mod, TruCool Max,Edge 3" leveling kit w/4" blocks,16.5x9.75 Weld Typhoons,35x12.50x16.5 BFG A/T, Westin chrome nerf bars,Pro Flaps,B & W Turnover Ball,Husky Liners.
pwrstroker00 is offline
post #2 of 8 (permalink) Old 06-10-2007, 07:13 AM
JimTJr's Avatar
My Photos: (20)
Re: Rear speaker install in F-350 Crew Cab???
easiest with the seat out, you need a LARGE torx for the seat and another size for the seat belt on the pillar, remove those, then try and firmly grab the interior piece and pop it off, looking underneath for the next tab and either grab real close to that, or reach under and pry with your hand, (they do NOT Come off easy, I just went through it myself) I think the seat was a 60 and the seat belt was a 55, I MAY be wrong on the Seat belt, but I had to GO buy the 60, I had a 55 and a 65, and it was in between those sizes.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #3 of 8 (permalink) Old 06-10-2007, 07:57 AM
haul_n_horses2's Avatar
My Photos: (17)
Seats are 55 so the seatbelt must be 60.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #4 of 8 (permalink) Old 06-10-2007, 01:13 PM
Layson's Avatar
My Photos: (28)
Just take the seatbelt off. Then pop off the door sill cover...right where you step in. I think that overlaps the cover for the speaker. Then start popping it out from the bottom up. It should come right out...
The first time I did it I didn't remove the seat belt. It was a pain but I got it done...
good luck,
Steven
01 F350 CC LB - 14" OUO 525 Series, 38x15.5 Toyo M/T's a 20x12 Weld Cheyenne's. BTS, Terminators, Hybrids...
Layson is offline
post #5 of 8 (permalink) Old 06-11-2007, 09:52 AM
NCHornet's Avatar
Layson has it right, but I did break one of my tabs, but I yanked hard instead of gentle prying.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #6 of 8 (permalink) Old 06-11-2007, 04:51 PM
My seatbelts were t50 and that was all I did and then just like described with the rest of the panel, but I didn't removed the seat. This was an 05 by the way
2005 F-250 Dark Toreador Red, Lariat Lux. package, 6.0 PSD, TNN0 Pcm code, Torqueshift auto trans, 4x4, ESOF, tow command, Fumoto valve, Magnaflow 4" turbo back and no kitty, Sirius Satellite radio, Retrax bed cover, Harpoon mod, ccv mod, GOS headlight harness, Fog Light High Beam Mod, Heated mirrors upfitter #1, AIC upfitter #4, Wix Powertrap with no mass airflow sensor, Direct Injection Performance Coolant filter, Oil Guard by-pass, and Schaeffers 5w40.
refuse2 is offline
post #7 of 8 (permalink) Old 06-11-2007, 05:33 PM
Layson's Avatar
My Photos: (28)
I didn't take the seat out either... that is a pain by yourself..
Layson is offline
post #8 of 8 (permalink) Old 06-12-2007, 10:44 AM
FWIW. The seats are a T55Plus, but a T55 will work.
01F350 CC 4WD 6SPD Arrow Canopy, 305/70/16's on 16"X8"wheels, HX mod, IAH plug, AFE Stage I w/pro guard 7 filter and overcoat. Evo tuner, WW, 4"exhaust,zoodad, Amsoil, Isspro gauges, GOS headlight harness,coolant filter
Endowment Member NRA
01crewcabtg is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
