Red head steering gear scam???? - Diesel Forum - TheDieselStop.com
 2Likes
post #1 of 21 (permalink) Old 08-05-2010, 03:15 PM Thread Starter
Just ordered a redhead steering box and when looking back over the internet for their information found two identical websites with totally different phone numbers and email addresses. Now I am worried I may be getting scammed by a false site and wonder which is real (or if both are). I have tried the other number but the answering machine says that all lines are busy to leave a message. Is the number 1-888-741-0159 or 1-800-808-1148. Thanks for your help.
DBO77 is offline
post #2 of 21 (permalink) Old 08-05-2010, 03:38 PM
MPH
I did not have any luck with their web site. I phoned them and got what appeared to be a young man that referred my questions to Harry who is the old guy that actually builds the boxes. They are not a large scale operation so you may have to leave a message with a call back number. I have sent my core back to them and if my credit card gets the $150.00 core credit applied, I can say my experience with them was outstanding.
Carlos Marin likes this.
1999 april build date F-250 S/D, CC, SRW, 4x4 Updated Diablo Predator 60 hp, ZOODAD mod,Magnaflow downpipe & muffler,crankcase bypass with filter system,ART rotors & Performance Friction Pads,Rancho 9000's & stabilizer,Mag-Hytec rear diff cover,Tymar intake,Sonnax Valve & Tri-Springs,Magnafine trans filter,203* T-stat & billett housing,ATS housing,Banks Big Head actuator,boost control valve, Red Head Steering Gear .
MPH is offline
post #3 of 21 (permalink) Old 08-14-2010, 02:24 PM
JAKKERS's Avatar
red head steering
used them alot when ihad a shop in seattle. very good try calling local number 206-364-3333
hope this helps
JAKKERS is offline
post #4 of 21 (permalink) Old 08-24-2010, 08:06 PM
sorry for hijacking your thread, i am in need of a new steering box, is this supposed to be the best thing since sliced bread? does it improve driving behavior over stock? are there other boxes to consider? thank you.
edit: what is the price for one of these boxes, just ball park, please.
Ken
2002 F350 7.3 cc lb drw, 4wd, 190k, b&w gn hitch, auto, no other mods yet
sold 1996 F250 7.3 CC SB 239k Line-X'ed bed liner, cold air intake
bitbreaker is offline
post #5 of 21 (permalink) Old 08-28-2010, 09:05 PM
Just go to O'Reilly's and buy the Cardone one that is lifetime warranty for $189. I just did one in mine along with new hoses, ps pump and the MOOG swaybar links. Everything cost me $484 OTD.
2003 Eddie Bauer 7.3L Excursion 4x4-Estate Green/Gold, Banks CAI, Pro Comp 4" Lift, Magnaflow Performance 4" with 5" Tip Exhaust, 05 Bumper/Grill, Powerslot Cryo Rotors/Hawk LTS Pads, Edge Evolution CTS, 35x12.5R20 Toyo MT's, 20x10 Fuel Hostage Wheels.
KIMMER is offline
post #6 of 21 (permalink) Old 09-11-2010, 11:16 PM
Ky_0686's Avatar
Do the steering gear boxes on the 99-03 trucks wear out fairly easy? I have a little more than 160k mi. I bought the truck with about 130k mi, and for all of those miles I have been trying to figure out why I have sooooo much steering wheel play. I have adjusted the box several times, I have done the ball joints, drag links, tie-rods, had a wheel alignment, I am basicly new up to the pitman arm. I know this would obviously mean that the box needs replaced, but my father-in-law says that the box is properly adjusted, and he doesn't think it's at fault, and he doesn't know that I'll ever get rid of the steering play. I don't really agree, but can't really come right out and say it, if ya know what I mean. I really want to give a go at replacing the box, but I've been laid off for 8 mos, and don't have the cash. Does the steering box make logical sense?
2002 F-250 CC LB 4x4 7.3L 183k mi
Pace Edwards Roll Top Cover
2-12" 500W Pioneer Subs w/ 760W Amp
Muffler is Gone!
DIY 6637 Air Intake
Hutch and Harpoon mods
1990 VW Jetta 1.6L NA 5sp 224k mi
Beater with a heater commuter car
Slower than hell, but cheap on fuel.
Ky_0686 is offline
post #7 of 21 (permalink) Old 09-13-2010, 06:18 AM
dlblazer's Avatar
You can only adjust the steering gear so far. As the gears wear internally, they will wear close to the "straight ahead" position most, while the "full turn" position will not show a lot of wear. If you adjust the gear lash for a worn out, "straight ahead" its likely the gears will bind at full-turn.
Without seeing the truck its difficult to be certain of anything, but the steering gears do wear out, and they cannot be adjusted into infinity.
Current truck: 2002 PSD 4x4, CC, XLT, F350 dually, 4.10 gears. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO gauges (boost, EGT, trans, fuel pressure), PHP Hydra, full EBPV delete (pedestal & outlet), CNC Fab HP & HPX lines, Riff Raff FRX, Riff Raff IC boots, CCV mod w/catchcan, Reese Titan, AIS, ITP pre-pump filter kit, in-tank mods, Redhead steering box.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, CCV mod, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, ITP pre-pump filter kit.
dlblazer is offline
post #8 of 21 (permalink) Old 04-06-2015, 06:40 PM
Nyghtryderz's Avatar
I would say it's your steering box and need a new one as you have adjusted or replaced everything up to or to the box.
2015 F-350 lariat Crew Cab SRW LB 4x4
6,000 miles
5000K 55W HID headlights
5000K 55W HID fog lights
6000K 50" LED light bar
2001 Ford F-250 Diesel 4x4 XLT Super Duty
DP Tuner AIS intake
6" Lift with Bilstein shocks
38" Toyo Open Country M/T
5000K 55W dual HID headlights
5000K 55W HID Foglights
6000K 50" LED light bar 48,000 Lumens
Prodigy P3 Brake Controller
Warn Premium Hubs
160,000 miles
Tow four horse gooseneck with living quarters
flatbed hay hauler
Last edited by klhansen; 04-07-2015 at 04:53 PM. Reason: removed reference to another member's post
Nyghtryderz is offline
post #9 of 21 (permalink) Old 04-06-2015, 07:29 PM
dlblazer's Avatar
I too got Redhead to send me a rebuilt box. The box was as advertised and is a quality rebuild.
If I had any critiques, I would say they were very slow in refunding my core charge after they received my old box.
dlblazer is offline
post #10 of 21 (permalink) Old 06-16-2015, 04:11 PM
The 2 website thing is very confusing, but they actually link to each other. I ordered a box from them a couple weeks ago, got no order confirm email or anything. Had to call them to track it, but they did ship it super fast. Also no invoice in the packaging so I had to contact them again to get an invoice to return the core. The box is certainly better than what I had in there (1 y.o. NAPA reman), but there is still some play in the steering. I suspect it's the tie rod ends and will be replacing those soon as well.
01 F250 Crew Cab 7.3, BTS, DP Tuner, AFE Stage II
BigDaveZJ is offline
post #11 of 21 (permalink) Old 06-16-2015, 09:11 PM
I replaced the box with a redhead in June of 2014. after the install, I was so happy I called them and complimented them. Through the months it started getting worse. Mechanic said everything looked good up to the box. If you adjust the box, the warranty would be void. I will call tomorrowbc the warranty runs out on the 23rd.
2003 Ford Excursion 6.0 139,000 Miles...F-650 Dash
4-2-2015 Bulletproofing completed:
Completely Rebuilt and O-Ringed Heads.... ARP Studs....OEM Oil Cooler....RCD EGR Delete....OEM Head Gaskets....Glow Plugs....Glow Plug Harnesses....Injector O Rings....Thermostat & Housing...Valve cover, Exhaust, Intake Gaskets....Riffraff Blue Boots....Turbo drain Tube.... Sinister Oil Filter, Sinister Coolant Filter, Fumoto Valve Oil & Block....Fuel Pressure Gauge.... Coolant Temp Gauge....Oil Temp Gauge....Blue Spring....FICM.Com W/Atlas 40....Aluminum Radiator
Marinco Plug Mod
08-10 Side View Mirrors
Firestone Rear Air Bags
Harpooned/ Zoodad Mod
Redhead Steering
Leveled
"If you're lucky enough to live in Texas, you're lucky enough"
blackrod is offline
post #12 of 21 (permalink) Old 06-18-2015, 12:02 PM
I dont see the problem here. I called Redhead, Joel answered, I advised him of the problem, he made a few suggestions, and made notes and said it will be taken care of. I was satisfied.Call the 206 area code number.
Marinco Plug Mod
Redhead Steering
Leveled
blackrod is offline
post #13 of 21 (permalink) Old 06-20-2015, 10:47 AM Thread Starter
In an attempt to kill this post, I would like to thank MPH and Jakkers for their help 5 years ago. My transaction went smoothly and, although the box didn't cure my problems, I feel that it was quality but I had little wear issues everywhere, which when added together, made for horrible handling by the time it got to the steering wheel.
In reply to blackrod's "I don't see the problem here", the post was started 5 years ago. Ecommerce and websites have come a long way in that amount of time so the issue I had with duplicate websites listing separate phone numbers may now be gone. I simply noted two websites subsequent to ordering and payment (prior to receiving the box) and couldn't reach anyone via telephone to ensure I wasn't being scammed.
DBO77 is offline
post #14 of 21 (permalink) Old 10-24-2015, 12:12 PM
I had a lot of play in my steering, so bought a redhead three years ago. It didn't improve the steering at all. I took my vehicle back to their shop and the owner tried adjusting the gear box, which improved it a little. But it still wasn't any better than a stock gear box. Now, after only three years, the gear box is leaking so bad I have to refill the power steering fluid every day. Today I'm replacing the Red Head with a gear box that has a lifetime guaranty from Oriely's Auto Parts.
akbshplt is offline
post #15 of 21 (permalink) Old 10-28-2015, 08:38 AM
After replacing all the joints and tie-ends I still had vague steering which was tough with a big trailer.
Then had a blowout which damaged my original box, shop installed a new "OEM Rebuild"and it was even worse.
I bought and installed the RedHead and WOW what an unbelievable difference. Precise, accurate steering I can trust. Totally impressed. Huge difference for me. And they were straight-up to deal with. Zero issues.
2003 F250 7.3 CC LB 4X4 Tow rig
Red Head Steering, Foxs,
Tjyak50 is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
