REMOVING THE DASHBOARD AROUND THE RADIO ON 2005 F350?? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 04-09-2006, 08:49 PM Thread Starter
is anyone here ever removed the dash around the radio i want install a Interface for my Ipod to works with the factory radio and i need to removed the radio ,but don't know how to to remove the dash around the radio.Thx for your input.
2005 F350 DRW 6.0 81000 miles (SEPT 2010)
2005 34 ts Cardinal fifth wheel(12500 LBS)
Jose M. Dias
M:.M:.
Associate yourself with men of good quality if you esteem your own reputation; for 'tis better to be alone than in bad company. — Brother George Washington
delta95 is offline
post #2 of 9 (permalink) Old 04-09-2006, 08:53 PM
FamilyRide's Avatar
Re: REMOVING THE DASHBOARD AROUND THE RADIO ON 2005 F350??
If I'm not mistaken, all you need is the radio removal tool and slide it out.
I'll say though, I have the tool and can't get the sucker to slide out! [img]/ubbthreads/images/graemlins/blush.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #3 of 9 (permalink) Old 04-09-2006, 09:09 PM
FINE69's Avatar
05's are different, you have to remove all the trim around the dash. I've read somewhere on here how to do it, from what I remember, the trim just pulls off. You need to tilt your steering wheel all the way down, if you have an auto. tranny, put it in first gear. Then carefully start at the lower left of the dash, and pull the trim straight out. Be careful, as the wiring for some of the idiot lights, is connected to the back of the trim. The little clips that hold the trim on can be tough, but they'll come off. The radio then unbolts. Try doing a search if you need more detailed directions.
2009 F350 CCLB Larry-at, 6.4, all the toys....
FINE69 is offline
post #4 of 9 (permalink) Old 04-09-2006, 09:09 PM
pull the surrounding dash outward, tilt steering wheel in down position, shifter in down position, disconnect all connectors behind dash panel dont worry they only fit in the appropiate spots, I believe youll need a 7mm socket to remove the stereo hope this helps
aetcmh is offline
post #5 of 9 (permalink) Old 04-09-2006, 09:10 PM
overfly's Avatar
My Photos: (16)
I think the 05-06 models are different than previous years for radio removal - the DIN tool isn't required but you do have to remove the dash face. Have not done it personally but I hear it just snaps on and off.
Family Ride - After you snap the DIN tools into your radio (you should hear a snap), apply inword pressure to the tools and pull straight out.
2006
- Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
overfly is offline
post #6 of 9 (permalink) Old 04-10-2006, 10:12 AM
The dash does just snap off. Like was previously said, tilt our wheel down and put tranny in first (auto). If you are careful like I was, you will not have to disconnect any of the plugs connected to the dash. You will still have enough room to remove the radio.
06' F-250, 6.0L PSD, AUTO, CC, SRW, SWB, 4WD, ESOF
4" turbo back MBRB exhaust
x-monitor
Air horns
cvucich is offline
post #7 of 9 (permalink) Old 04-10-2006, 02:50 PM
My Photos: (5)
If you have average sized hands, you can take out the hook panel (2 screws) and then the cup holder (4 screws, 2 underneath) and reach up behind the radio and plug in the PIE adapter. You need to run a 12v connection to it as well so just tap into the wires for the cig lighter while you have access.
2009 F-250, CC, SWB, 6.4 PSD, 4X4(ESOF), AT(3.73) Big Blue Monster Rollin' On 20" Wheels...........
HeliPilot is offline
post #8 of 9 (permalink) Old 04-11-2006, 07:59 PM
Since it was mentioned - where does one buy the PIE adapter? My local electronics stores have no idea. Does that allow the AUX button to be used with an IPod or Sat radio adapter?
2005 F250 PSD Lariat 4x4 FX4 3.73, MBRP 4" turbo-back
ISSPro EGT and Tranny
Oilguard Bypass
SCT Tuned by Innovative
ryandye is offline
post #9 of 9 (permalink) Old 04-11-2006, 08:14 PM Thread Starter
http://www.discountcarstereo.com
for a 2005 F350 is not out yet at least the type that u can use the steering wheel controls and recharge the ipod at the same time,and yes u can use the aux button with the ipod, they told me in few weeks. 2005 F350 # PA11 FORD3
here where i got from the web page :
FORD began using a Controller Area Network (CAN) Bus for intercommunication between most every system in at least 5 vehicles, namely: 2004-Up Escape, Mustang, F150, Freestar, Monterey, 2005-Up F250, F350, 500, Montego, Freestyle, 2006 Explorer, Mountaineer.
Integrating aftermarket products into these vehicles has posed a challenge, however USASpec (among others) have answered the bell. Introducing the PA11-FORD3 iPod interface for Ford's CAN-BUS radios with "AUX" button. The PA11-FORD3 lets you connect, charge and control iPod products from the factory radio. No need to fumble with the iPod™ for any reason, you can stow your iPod in a non-visible location and enjoy hours of music because the PA11-FORD3 also charges the iPod's internal battery. No more Cassette Adapters, FM Transmitters, or Cigarette Lighter Chargers.
The PA11-FORD3 will not work with vehicles that have SIRIUS Tuners.
(MORE PRODUCT DETAIL FORTHCOMING)
Jose M. Dias
M:.M:.
delta95 is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
