Removing Rubber Bumpers Behind Bug Shield - Diesel Forum - TheDieselStop.com
Old 02-20-2008, 10:18 PM   #1 (permalink)
My Photos: (5)
My old plastic Ford accessories bug shield has cracked so I bought a new Stampede plastic chrome shield to replace it. Looks pretty cool but when I went to install it I ran into a glitch.
The old Ford shield had rubber bumpers that affixed to the hood to prevent the shield from coming into contact with the hood. The new chrome shield is a lower profile unit and does not need the bumpers.
Does anyone have a technique, solvent, or other product they can recommend to remove those old rubber bumpers from my hood and not damage my truck's paint?
Thanks for the info.
2000 Ford F-250 XLT Supercab 4x4
Ford AIS intake, ITP 4" exhaust with Magnaflow muffler, Isspro pyro, tranny, & turbo gauges, SCMT 1705 Max Microtuner
1997 Lincoln Town Car, old guy car driven by a young guy.
TurboTim is offline
Old 02-21-2008, 01:10 AM   #2 (permalink)
Brian_444's Avatar
They should pull off pretty easily, then use something mild like WD-40 to get rid of the any left over adhesive. Just keep in mind this will also take off any sealant/wax, so when you are done make sure you go over that area again with sealant/wax/LSP of your choice.
'02 DSG F-250 XLT 4x4 Supercab longbed 7.3/4R100* 6.5" Pro Comp lift with dual resorvoir shock setup and traction bars* 37x13.50x18 Mud Grapplers* black powdercoated 18x10 MB Rockers* black RanchHand bumpers* '08 TT mirrors* black NFab step bars* Factory Tech valve body (full BTS when this one goes out)* super special ultra hybrid tunes from Tony* Dipricol Optix triple pillar mount gauages* 4" MBRP turbo-back exhaust* ATS turbo housing with wicked wheel* DieselSite Turbo Master wastegate controller and map "boost fooler" (POS doesn't work)* AFE intake*
Dad's '02 F-350 XLT 4x4 6-speed, lightly modded
Brian_444 is offline
Old 02-21-2008, 06:15 PM   #3 (permalink)
If you have a heat gun, use it to soften the bumpers / adhesive. Careful not to bake the paint. It will bubble off if you don't pay attention. Then follow Brian 444's advice with solvent and rewax.
HeavyDriver is offline
Old 02-21-2008, 08:04 PM   #4 (permalink)
Meatco1's Avatar
A hair dryer will work fine for heating up the rubber, and it is not nearly as likely to bubble the paint.
Richard
2001 C/C, 4x4, S/B, 3:73 L/S
John Wood Transmission
Tru-Cool Transmission oil cooler
DP Tuner with No Start, 20/40/60 Tow
80 Econ., 120 Race
AutoMeter 3 Guage, Pillar mount
6637 w Pete's Cover
Euro Chrome Clear Headlights
Euro Clear Signal Corner Lights
Bright Box Upgraded Headlight Harness
Defiant Light Bar w 2 KC Pencil Beams & 2 KC Driving Lights
Fumoto Drain Valve
Coolant Filtration System
Meatco1 is offline
Old 02-21-2008, 08:09 PM   #5 (permalink)
phillbo's Avatar
Hair dryer and some Goo B Gone... then wax.
2006 F-250 XLT FX4 CC 6.DOH
phillbo is offline
Old 02-22-2008, 03:02 PM   #6 (permalink)
High PSI's Avatar
My Photos: (18)
A hammer and chisel then alot of wax!
'02 Black F350srw,Lariat,CC,SB,OR. - BTS TRANS,Coated 1.00 BB TN-non EBP-6.0 Spearco IC-DP Tunes(stock,HI,60T,80E,120R)MAP maximizer-ITP reg ret.-AirDog-Fluidampr-BWD coated/ bellowed pipes-AFE2-4" Magnaflow-Dieselsite coolant filter&ESOF SS lines-Billet/203*stat-Fleetrite ELC-Bilsteins-Hawks&Cryo's-Centramatic-Billet-Extang-Husky box-Husky Liner-EGR-LineX-Alpine-Kicker-PIAA-Dynamat-Sirius-Viper-ES Poly's-BFG 315/75/16 AT's-DTS 4.56LS-31 row 6.0 Cooler-UltraLite trans,pyro,boost-DiPricol fuel-PML pan-Mag-Hytec cover-Powerslot-Hawk. Marinco,Snowman,Harpoon,AIH,CCV,foil,door ding,console mods. http://good-times.webshots.com/album/557543120DKiWId
High PSI is offline
