Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - General
Upgrades and Aftermarket - General Upgrading and adding aftermarket equipment to your 1999-2007 Super Duty. Please confine discussion of topics in this forum to those items that are not engine-specific.
Old 11-04-2009, 01:25 PM   #1 (permalink)
Seat Conversion
2000 F250 SD
I just traded my 40/40/buckets and console with a 40/40/20 out of a 2003 F350 SD. My driver side was power and passenger was manual. The new seats are both powered and....have heat. I pulled the wire harness off of the F350 but it has more wires on the drivers side than the passenger. The passenger has one more than was on my F250. Can I just make sure the ground wire is grounded and run power to all the wires or is there something special I need to do?
glock22 is offline
Old 11-05-2009, 12:30 AM   #2 (permalink)
power seat answer
It didn't take me long to realize that there are 5 wires on the driver side. Three match up perfectly. There is an extra red w/a black and a brown with a blue stripe. The two extra wires I just ran in with the green hot wire and everything runs great. I then ran a ground wire to the passenger seat and ran the other three wires it had into the hot lead from the drivers side. It works perfect.
glock22 is offline
Old 11-05-2009, 08:32 AM   #3 (permalink)
dlblazer's Avatar
Sounds good, glad you got it figured out.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
dlblazer is offline
Old 11-05-2009, 02:49 PM   #4 (permalink)
Maybe the extra two wires are for the power to the heater to come from a relay, so you don't run the risk of burning your biscuits?
Don't know, never wired one, but just a thought.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 11-05-2009, 02:51 PM   #5 (permalink)
Also, is the heater in the seats adjustable? On my Tig, there are two sets of controls....one for the driver and one for the passenger. If you don't have any type of rheostat dial, then it may be giving you 100% heat juice all the time.
short_stuff
