Silverstars gone after 9 months - Diesel Forum - TheDieselStop.com
Old 02-04-2006, 12:09 AM   #1 (permalink)
klhansen's Avatar
My Photos: (169)
Just replaced the second Silverstar lamp last night a MINUS 10 F [img]/ubbthreads/images/graemlins/mad.gif[/img] The first one went about 3 weeks ago. These are the ones I put in last spring with the headlight harness I built.
Definitely not very cost effective lighting. [img]/ubbthreads/images/graemlins/frown.gif[/img]
Hard or no-start? Check Here
klhansen is offline
Old 02-04-2006, 12:12 AM   #2 (permalink)
Re: Silverstars gone after 9 months
Its gotta be the harness, Ive had my Silverstars in for about 3 yrs. Now I just strewed myself, one will prob. go tomarrow or this week. [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2001 white F250 sc xlt psd," DI regulator kit, DI BIG fuel system, DI Mine-Me injectors, DI ATS BB Turbo, DP Chip,DI Valve Pressure Release,DI-adjustable IDM mod ",Terminator 2 HPOP R-IPR, APR studs, 910 valve springs, BTS Trans&Converter,6.0 Intercooler, AFE Stage 2 with zoodad,Power Elbow, Bully Dog full 4" exhaust with 5" tip,Fluidampr, hx mod,203t-stat, CCV mod, Fumoto Oil Valve,Cool-Max Trans Cooler, Autometer Phantom Gauges,Bilstein shocks, Rancho5406 stablizer, Edge 4" lift kit, Rear RoadMasters active suspension, EGR Slotted & Crossed Drilled Rotors with Carbon/Kelvar brake pads, Welds Cheyenne 8s, Roll & Lock bed cover, Sylvania SilverStar 9007& 9005s, Chrome Billet Grill, 2003 Clear Headlights, APC Clear corners, APC Euro rear lens, APC gas & brake peddles, Acetone Badges, Chrome Door & Tail Gate Handles, Oakley Seat Covers, Viper alarm, Cyclops Fuel Cut-off alarm.
[color:"blue"]MY TRUCK[/color]
joediesle is offline
Old 02-04-2006, 12:38 AM   #3 (permalink)
I have had mine with the upgraded harness for 12 months now, and I am using the Hi/Lo option with no problem.
wildbill1963 is offline
Old 02-04-2006, 04:21 AM   #4 (permalink)
Like it says over on the Slvania site. A bulb rated for X hours, some will die quicker, some will live a fair amount based on conditions and other will last forever. Probably some CYA there on their part but it is just advice. Some Times They Do, Some Times They Don't. It is a fact, any bulb will burn hotter with more power going to it. Bulbs are like car batteries, more heat equals less life.
2003 F250 SC Lariat FX4 6L; My Truck
AK6LPSD is offline
Old 02-04-2006, 02:56 PM   #5 (permalink)
My Photos: (14)
I've had mine for about 16 months with no problmes. They are better than stock, but I still need more light.
Doug
You didn't touch the bulb did you? I know you didn't, but I had to ask.
2005 Ford Excursion Eddie Bauer 6.0, 4x4
2002 Dodge Ram 3500 Ext cab 5.9, 6spd dually 4x4
2010 Volvo XC 90 AWD R-Design
1996 Corvette LT4 6spd
1994 Taurus SHO
1989 Mustang GT
2002 Gulfstream Conquest 32ft Class A
1998 Nitro Savage 884, Merc 150 EFI
Snug is offline
Old 02-04-2006, 05:37 PM   #6 (permalink)
The new injectors are making the truck so fast that the light is forced back into the bulbs!! This is a common problem and will always cause bulb failure.
DENNY
1999 F350 CC SRW LB 4X4 SIX SPEED.
DENNY is offline
Old 02-05-2006, 10:51 AM   #7 (permalink)
Feedback Score: 3 reviews
If ya want more light go here , Hella 80/100 are cheeper and way brighter than Silverstar's. Just make sure you install a new set of relays and wires to take the load off the stock switch.
Cary
Cary
caryt is offline
Old 02-05-2006, 11:04 AM   #8 (permalink)
RexaFORD's Avatar
DENNY
Yep, I hear ya'. The high G forces, both acceleration and braking, the bulb filament are subjected from these Powerstrokes just naturally shortens bulb life. Does wonders for hairdo's and smiles also! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Plus, all the reading I've done tells me the Silverstars have a shorter life expentancy than the stock bulb. [img]/ubbthreads/images/graemlins/frown.gif[/img]
Rex
Orig. Name: Rex-a-FORD
Reged: 2/22/01
Post: 1878
Early 99 [3/98], F-350, XLT, PSD, DP Tuned PMT1 6-Pos, 10.5 MPG Avg., 60,576 miles, CC, DRW, 4x4, ESOF, 4.10LS, BTS To Be Installed 9/7/11, TT & C-Betr Mirrors, 4" DP & Exhaust, Isspro Gauges, DEI Sidewinder Remote Start & Keyless Entry
My Truck - - My Authentic Dale Isley Tymar Intake - - My Heater Control Valve Mod
Email: rhansen@machlink.com
RexaFORD is offline
Old 02-05-2006, 02:09 PM   #9 (permalink)
I've got 40kmi on mine, and I usually drive with the lights on, day or night.
I think the key is to put the stockers in the glove box for spares. It keeps murphy away... The only bulbs that blow are the ones you don't have spares for.
I seem to loose oberhead marker bulbs alot. I think I need to change my remote start to a steady light rather than a flash.
I would suspect the harness, if you're driving them brighter, they they'll burn up that much faster.
2000 F-350 NVK5, XLT Island Blue 7.3 PSD 3:73LS Reg Cab LB, STOCK EXCEPT:BTS Transmission,Ummmm... Injectors, Home made HUGE Tymar,TC-Lock Mod, CCV mod, Heater-plug mod,6-Pos "Chip", Autometer Z-Series/ISSPro Gauge pod,407hp/849.1FtLbs
http://powerstrokecommunity.com
1/4 ---13.686 @ 96.69
1/8 ---8.625 @ 78.17
60' ---1.877
#51
MrPlowJr_EZ_V is offline
Old 02-05-2006, 03:37 PM   #10 (permalink)
FMTRVT's Avatar
My Photos: (16)
Kevin,
I had basically the same results as you with two trucks. With an upgrades harness, the life at the higher voltage is, well, consistent but short. Then I looked at the economies.
Since I an running a harness, and have both high and low when the "highs" are on, I went back to the second in line bulb. It has a much longer life and honestly, is bright enough for me.
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
Old 02-05-2006, 04:24 PM   #11 (permalink)
DENNY
HAHAHAHAHAHA! Good one!!! [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
Larry
02 F250XLT SD CC LB 4X4, Silver, SD Air Lifts, 4R100, Westin Sportsman grill/brushguard, Leer Shell, AIS Severe Duty w/added fender intake, Edge EVO running 80 HP, ISSPRO's w/cubby mount, Rancho 9000X's, Banks 3 1/2" downpipe, BTM, 3 1/2" exhaust front to rear with 5" stainless tip. Sonnex and Tricum's. Fumoto Valve. Royal Purple ATF. Tru-Cool 4590. Tekonisha Prodigy. SP Diesel SSEBTC Exhaust Brake. Like new 88 Vacationeer 11.4' or 2008 Cardinal 31SB, 1992 Bayliner Trophy and the itch to go, baited hooks and the need to fish, loaded guns and the need to hunt.
Larry P is offline
Old 02-06-2006, 01:01 AM   #12 (permalink)
Kevin,
I with everyone else. I have had mine in for 2 years. I think the bad vibes coming from those bad injectors did them in.
My Wife's Truck is a 2000 Super Cab, 7.3, DRW, XLT, 4X4,PSD, 6spd, 3.73, Dark Toreador Red, 4in DP, no muffler, 5 inch Black Cloud Slant Cut Stacks, SWAMPED, Stage III's plus a Custom Burned 6 position chip.
'05 Ordered 11 Jan 05, Deliveried 03/12/05, Lariet Luxuary Group, Black, Crew Cab, DRW, Power Slider, Moon Roof, Camper Package, 6 Speed, 4.10 LS, 15,000lb reciever. MBRP Dual exhaust, AFE and gauges
Big Boy w/ Big Toys is offline
Old 02-06-2006, 01:28 AM   #13 (permalink)
My stars went with my last truck, (won't fit the '06) they were in for 3 years and 2 trucks!!
Ron
aussiekeeper is offline
