Sounds like someone is hitting my floor board with a ball ping hammer - Diesel Forum - TheDieselStop.com
post #1 of 37 (permalink) Old 11-16-2007, 07:51 PM Thread Starter
Ok so I lifted my truck about 4 months ago and it made this noise every once in a great while, this was with the stock tires. On Monday I had 4 Wheel Parts put some 35" FC II's on her and do the alignment. Now almost every time I make a turn and there is some small or large bump I hear a bang sound that sounds as if it is coming from right under the driver seat the sound is almost as if someone is hitting the bottom of the cab with a ball ping hammer I have checked everything in the area and in the front end to make sure all was tight I also had my buddy turn the wheel both ways to make sure all components cleared each other I also get the bang noise every once in a while on a strait away during or right after hitting a bump in the road I am stumped and so is my dealer and 4 Wheel Parts so if anyone has any suggestions I would love to here from you Also note that it was just in for head gaskets and the dealer did a cab off job they messed a lot of stuff up and i ended up going back to them with a full page of things they needed to fix i.e.: body ground not connected residual fluid all over a huge gouge in my door that they tried to paint and over sprayed the rest of the truck so it could have easily been something they did during the cab off head job I wish they would help me diagnose this bang noise without the chance of being charged an arm and leg
THANKS IN ADVANCE
2005 F-350 Lariat 6x6 Dually Blue
Exhaust:
5 inch into 5 inch stack
Programmer:
Edge Juice
Intake:
AFE Stage 1
LIFT:
front- 5 1/2 inch pro comp coil spring lift w/ radius arm drop
rear- 6 inch pro comp leaf springs removed stock blocks
Tires:
6 35" x 12.5" Dick Cepek FC II's on stock 17x6 rims 2" spacers on duallys
Other:
28"air horn :woot :woot
Ford Alarm
Tool Box
On board Air 2 tanks
2 10" Kicker Comp VR's and a Kicker ZR240 amp in custom box behide rear seat
all this and i've only put $2500 into it not including tires everything off Craigslist other than tires
RipperF350 is offline
post #2 of 37 (permalink) Old 11-16-2007, 10:06 PM
F350Lariat's Avatar
Re: Sounds like someone is hitting my floor board with a ball ping hammer
I don't really have a clue. However if you mounted 12.5 x 35s on 6" wide rims as indicated in your post, it could be the sidewalls bulging and hitting the driveshaft when you turn. [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img] Your tires have to look like an overinflated river raft.
2004 Ford F350 Crew Cab (SOLD MARCH 2012)
4WD Lariat 6.0L PSD Torqshift SRW
Med Wedgewood Blue / Arizona Beige
Tuff Country 1.5" Leveling Kit ... Hardcover Tonneau
Pro-Flap Mud Guards ... Toyo M55 LT285/75R16 Range E
GOS Racing Headlight Harness with Silverstar bulbs
Factory Ordered and Delivered: Feb 7, 2004
F350Lariat is offline
post #3 of 37 (permalink) Old 11-16-2007, 10:22 PM
If the cab was off recently I'd inspect the body mounts. Make sure they are intact and the bolts are all tight. If you have a Super Crew there are 6 bolts and 2 nuts. Both nuts are below the inlet and outlet for the intercooler, the first set of bolts are right underneath where your feet would go, the next set are right behind the driver's and passenger seats, and the last set are behind the fold down rear seats. Also check the radius arm bushings for cracking.
Gofaster23 is offline
post #4 of 37 (permalink) Old 11-16-2007, 10:55 PM Thread Starter
F350Lariat.... I do have 35 x 12.5 tires mounted on my stock 6" rims they crown a little but not to bad I'm guessing I'll get at least 35,000 out of them but I'm hoping for 40k I got 55k out of my last set but they weren't as big as for them hitting the drive shaft um.. that is impossible being that they would have to go through the frame to do that plus I've checked them a few times for clearance lifting the truck at different points and turning the wheel in both directions being that I do take it off road in the dunes I wanted to be sure most people say you can squeeze 37's with a 6 inch lift but I think that's crazy
Gofasterdammit... your post name is awesome and we need a tech like you here in Morgan Hill these guys have destroyed my poor truck I have checked the body mounts but only from underneath they all have bolts coming through them but should I check the other side are they under the carpet they must be ? Also checked the radius arm bushings they look good I'm going to shoot em with some lube tonight and see if that cures it
Exhaust:
Programmer:
Edge Juice
Intake:
AFE Stage 1
LIFT:
Tires:
Other:
Ford Alarm
Tool Box
post #5 of 37 (permalink) Old 11-16-2007, 10:59 PM
darsey715's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RipperF350</div><div class="ubbcode-body">F350Lariat.... I do have 35 x 12.5 tires mounted on my stock 6" rims they crown a little but not to bad I'm guessing I'll get at least 35,000 out of them but I'm hoping for 40k I got 55k out of my last set but they weren't as big as for them hitting the drive shaft um.. that is impossible being that they would have to go through the frame to do that plus I've checked them a few times for clearance lifting the truck at different points and turning the wheel in both directions being that I do take it off road in the dunes I wanted to be sure most people say you can squeeze 37's with a 6 inch lift but I think that's crazy
Gofasterdammit... your post name is awesome and we need a tech like you here in Morgan Hill these guys have destroyed my poor truck I have checked the body mounts but only from underneath they all have bolts coming through them but should I check the other side are they under the carpet they must be ? Also checked the radius arm bushings they look good I'm going to shoot em with some lube tonight and see if that cures it </div></div>
take your truck to marc at tiffany ford in hollister from now on. tell him david darsey sent you. he's an admin on powerstroke.org. I'm from mh but going to school in chico.
2003 6.0 f250
darsey715 is offline
post #6 of 37 (permalink) Old 11-16-2007, 11:00 PM
darsey715's Avatar
ford store in morgan hill is a joke.
2003 6.0 f250
post #7 of 37 (permalink) Old 11-16-2007, 11:48 PM
F350Lariat's Avatar
Okay ... joking a little bit with the sidewall hitting the driveshaft.
I hope your truck is for show and not intended to carry the payload of a 1 ton dually. Those tires are UNSAFE. The federal rim matching size for a 12.5x35 tire is 8.5"-11" (Recommended 10"). [img]/forums/images/%%GRAEMLIN_URL%%/crazy.gif[/img] You are a full 4" under the recommended rim size. I hope for your sake and possibly someone else that the tire bead never seperates from the rim under load.
It sounds like GoFasterDammit's experience may narrow down the sound (popping) issue.
post #8 of 37 (permalink) Old 11-17-2007, 02:03 AM Thread Starter
So I shot the bushings with some silicone lube and checked for cracks but its still get the noise. My buddy heard it for the first time and didn't know what to say, he was astonished.
I did find a TSB 06-6-6 that basically said faulty bump stops will cause a bang noise so I order the revised parts, a bump stop and the metal cup it sits in, but I really don't think that's what it is. Tomorrow I'm going to get under there and re-torque all suspension and steering components I hope I find something this bang is driving me crazy!
Thanks for the info David I was already planning to go to Hollister, but I would hate to bring the problems Morgan Hill caused over to them, warranty wont cover it, they wont cover it, and I sure don't want to. But I'm definitely going there from here on out I might even trade in there just to start over
As for the truck she is on the road all the time about 35k a year and when its not its in the Sand at pismo those stock pinter were always getting me stuck when I had my trailer I'm not worried about the bead separating I saw how hard the tire machine had to work to get them over the rim, I've also talked to quiet a few lifted dually owners with oversized tires and they have gone through a few sets of tires without problems well other than only seeing 35k out of a $3k set of tires its worth it to me to not have to worry about the sand eating my truck again
Exhaust:
Programmer:
Edge Juice
Intake:
AFE Stage 1
LIFT:
Tires:
Other:
Ford Alarm
Tool Box
post #9 of 37 (permalink) Old 11-17-2007, 11:20 AM
My 2005 F350 did the exact same thing. Something would "pop" right below the drivers seat. All stock suspension and stock size tires so it has nothing to do with that. I always suspected it was a body bolt also but never took the time to track it down. Seems like it usually just did it when going up into a driveway or small incline at an angle.
2009 F-350 6.4 4X4 CC SRW King Ranch
2005 F-350 6.0 4X4 CC DRW King Ranch
2000 F-350 7.3 4X4 CC DRW Lariat LE
SPL2K is offline
post #10 of 37 (permalink) Old 11-17-2007, 11:45 AM
NCHornet's Avatar
Swaybar endlinks!!!
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #11 of 37 (permalink) Old 11-17-2007, 01:17 PM
I had what sounds like the same noise. The rubber bushings that surround the front sway bar where it passes through the bracket attached to the frame had worked their way out allowing the sway bar to rattle against the steel bracket. Dealer pushed them back in and all is well now.
2006 F-350 CC/SB/6.0/OREGON"GO-DUCKS"YELLOW(AMARILLO DECAL-DELETE)/A.R.E.MATCHING CANOPY/TOYO MT 35's/LEVELED/ABSOLUTELY GORGEOUS.
72 BRONCO H/C (PROJECT)
tahkenitchthunde is offline
post #12 of 37 (permalink) Old 11-17-2007, 02:11 PM Thread Starter
Just checked the sway bar all bushings are where they need to be and not worn out. I'm starting to think its something in the steering just because it dose it a lot more when i make right turns but it still dose it in a left turn as well the sound seems to be coming more from the driver side how can you tell if the end links are good or not
Exhaust:
Programmer:
Edge Juice
Intake:
AFE Stage 1
LIFT:
Tires:
Other:
Ford Alarm
Tool Box
post #13 of 37 (permalink) Old 11-18-2007, 09:04 PM
Carbon_Bigfoot's Avatar
My 03" did the same thing. It was the sway bar end links. I pried and pounded torqued and lubed but sure enough,End links. Got mine from a local shop that installs lifts for $20 each. M ines stock height
03" F-350, 7.3, Lariat CC SRW 4x4 SB
-Bully dog 6, BTS trans w/ 6.0 cooler, 175 cc single-shots from Swamp's Diesel, 4" turbo-back, AFE Stage Two w/ Pro 7, Autometer pillar gauges, DB starter, foil delete, 3" Tuff Country level kit, on board air, truck horns, bellowed up pipes, big ball in the bed.
!!BTS BUBBA!!
Carbon_Bigfoot is offline
post #14 of 37 (permalink) Old 11-18-2007, 09:32 PM
I gotta be the ass here. LOL
It's a ball peen hammer...not ball ping.
Sorry...I couldn't resist. LOL
As for the noise...I'm no help. My 2wd has done it since I got it...stock height and also dropped. I've checked everything that moves under there...the cause still hasn't been found.
...coming soon...
2004 Twin Turbo 5.9 F250
Hellmann Performance
Direct Injection Performance
TS Performance
DI Performance
Greg Hogue
Grand Rock Exhaust
Dynomite Diesel
DC Customs
UNBROKEN is offline
post #15 of 37 (permalink) Old 11-18-2007, 11:08 PM
The noise is the body mounts sliding a bit. I also have this noise. Since it is mounted in a rubber mount the bushing flexes enough to allow some movement. The only way to help would be to find some urethane bushings that would hold the pressure better.
02 F250 4X4 Ext. Cab with 238K 4" Procomp Stage II lift, Banks turbo housing, 4" Exhaust W/single 5"stack, Microtuner, Harpooned fuel tank, and a lead foot!!
noall8ball is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
